Original XBOX: DVD drive replacement? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-28-2008, 11:47 AM - Thread Starter
getme's Avatar
Well I picked up an original XBOX for $30 and everything works except that the drive tray is a little "iffy". At first it would not eject at all but once I popped it free with a screwdriver it ejects just fine. Now the issue is that the tray will not close without a slight nudge to push it closed.
So my question is this: Is there anyway to use a standard "off the shelf" dvd drive as a replacement? I am willing to go as far as a "softmod" for now but I really want to spend as little $$ as possible (remember it only cost me $30 to begin with).
Thank for the help.
the arrogance of officialdom should be tempered and controlled... People must again learn to work, instead of living on public assistance. Cicero , 55 BC
getme is offline
post #2 of 11 Old 07-28-2008, 12:03 PM
HeadRusch's Avatar
Quoted: 119 Post(s)
Liked: 90
In a word, no.
You can replace it with an xbox-specific drive, usually on ebay.....Thompsons are the cheap and unreliable ones that everyone wants to replace...then come the other manufacturers with Samsung xbox drives the hardest to find, and most reliable.
Xbox Live / PS3 / Steam: HeadRusch1
Keeping the world safe from the evil antics of Bernie Tanaka and Mel Fujitsu since 1986
HeadRusch is offline
post #3 of 11 Old 07-28-2008, 09:50 PM
vertigo235's Avatar
Quoted: 110 Post(s)
Liked: 94
Make an offer, I have 2.
Xbox Live: IamVertigo
PSN: IamVertigo
vertigo235 is online now
post #4 of 11 Old 07-28-2008, 10:56 PM
Anthony1's Avatar
Quoted: 587 Post(s)
Liked: 352
probably the cheapest option is just to get another Xbox. That's what I did. Mine had the same issue with the drive not opening. I just recycled that Xbox and got another one for 25 bucks.
Anthony1 is offline
post #5 of 11 Old 07-29-2008, 08:36 AM
Slordak's Avatar
I replaced a Thompson drive that was acting up with another Thompson drive and... It almost immediately started acting up too. You'd be much better served getting one of the other drives that were put in the later Xbox models, if you have a choice.
Slordak is offline
post #6 of 11 Old 07-29-2008, 08:36 PM
ChrisFB's Avatar
Liked: 34
A PC drive won't read Xbox game discs. A PC drive also requires some alterations on the interier to get the fit right. It's not that it can't be done, but in most situations both of these are very undesirable consequenses.
Samsung and Phillips drives, with Samsung being the better choice for most people, are the names you'd want to go with if you buy an ebay drive. I just got a whole new Xbox for $35 so I don't know it's worth it as those drives cost about that.
Panasonic 65" VT60 (calibrated by Jeff Meier), Marantz 6005, Kef Q towers/rears Kef Reference center, Win 7 Pro with XBMC, Harmony Ultimate One
Xbox Live: Arbitrage XXL
ChrisFB is offline
post #7 of 11 Old 07-30-2008, 09:16 AM - Thread Starter
getme's Avatar
you have a PM
Modded the unit last night actually has a Samsung drive in it my friend said the tray is probably slightly misaligned so I may try to manually relign it sometime this week.
getme is offline
post #8 of 11 Old 07-30-2008, 10:17 AM
Mindwarper's Avatar
I replaced a bad one for a Thompson , It still works. It was 20$ on ebay.
Mindwarper is offline
post #9 of 11 Old 07-30-2008, 10:40 AM
kronickidd's Avatar
how much
kronickidd is offline
post #10 of 11 Old 07-30-2008, 10:41 AM
Drew_veloce's Avatar
Originally Posted by kronickidd View Post
how much
42
Drew_veloce is offline
post #11 of 11 Old 07-30-2008, 11:54 PM
darklordjames's Avatar
Liked: 94
Softmod it with a bigger harddrive, drop all your games to the HDD and never deal with the DVD drive again.
darklordjames is offline
Reply Xbox Area
