XBOX 1 Memory Upgrade ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-27-2008, 10:44 AM - Thread Starter
rfisher1968's Avatar
I have a old XBOX that I want to upgrade the memory to 128megs and want to know the best method to solder the chips. I already got the chips, just need to know the best method. I was thinking a hot air gun, but it might damage the chip.
rfisher1968 is offline
post #2 of 9 Old 08-27-2008, 10:51 AM
Sunkist's Avatar
go to xbox-scene.com they have lots of modding help in their forum.
Sunkist is offline
post #3 of 9 Old 08-27-2008, 10:52 AM
rdank's Avatar
http://www.youtube.com/user/stilts07
From what I've read, there isn't much point of doing this unless you are just looking for something to do. What are you hoping to gain from it?
rdank is offline
post #4 of 9 Old 08-27-2008, 10:58 AM - Thread Starter
Well i'm running a MAME emulator and with some of the games the XBOX runs out of memory. So if I increase the memory those game can be played.
post #5 of 9 Old 08-27-2008, 11:00 AM
markc72's Avatar
Quoted: 55 Post(s)
Liked: 42
I have MAME and they all work fine plus all my other console emulators. Why waste your time.
Come join our adult gaming community at www.syndicatedgaming.com
XBL, PSN, and Steam: diehardcubfn
markc72 is offline
post #6 of 9 Old 08-27-2008, 11:19 AM - Thread Starter
Well I'm using mameox128plus emulator and set the options to use virtual memory and I have slow response when playing. At first the emulator wasn't using any virtual memory and it wouldn't load the game.
I just thought the best solution would be to add the extra memory. It was only $5.25 per chip.
post #7 of 9 Old 08-27-2008, 11:25 AM
rdank's Avatar
Good luck. Hopefully it works out for you.
rdank is offline
post #8 of 9 Old 08-27-2008, 02:59 PM
RTRic's Avatar
Seriously...you will get more and better help there. This is not the forum for this kind of talk.
RTRic is offline
post #9 of 9 Old 01-07-2013, 08:27 AM
SONIC FIVE's Avatar
You dont need to do this anymore... (if you have a modded xbox) and i asume you do as you are playing Mame smile.gif
Here is a program called " RAM LIMMIT REMOVER " that allows you to access more of that xbox memory. - (Download Link Below)
LINK:
http://www.xbox-scene.com/tools/tools.php?page=xbexbx#newsitemEpFVplyEpujTqBIzpD
PS, other programs have this already impremented, like xbox1 CPS3 emulators.. and they work smoothly at 60fps.
SONIC FIVE is offline
Reply Xbox Area
