Xbox live data consumption? 6 gig monthly max - AVS Forum | Home Theater Discussions And Reviews
Old 10-29-2008, 12:23 PM - Thread Starter
Koobs's Avatar
I know this depends on the game and what not. But i was just wondering if I would go over my 6 gig limit a month with xbox live?
Its hard to measure so lets just base it on an hourly play (ie: 1hr may = 400megs)
note I also use about 2 gigs a month for emails, mp3s sometimes, and web browsing so its more like 4 gigs.
NOTE: I currently use my internet through a tethered iphone. I get 2500kbps download, and about 200-400 upload. I know the upload is on the minimum but im really curious to see if it can be done. Speed seems to be there, now i wanna know about data consumption.
equipment lists are not allowed
because it wastes screen real estate....
so i removed it...
Koobs is offline
Old 10-29-2008, 12:29 PM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 88
I would think you would have an issue with your ping time. Ping is awfully slow with wireless.
Also, with 1 to 2GB demos being the norm these days, you would have to choose wisely when picking demos to download.
Josh - GamerTag: ShapeGSX PSN: ShapeGSX
'97 Eclipse GSX - 11.825@117.55mph in the 1/4
Shape is offline
Old 10-29-2008, 12:38 PM
kylebisme's Avatar
wireless doesn't have any notable effect on ping, it just limits bandwidth.
kylebisme is offline
Old 10-29-2008, 12:43 PM - Thread Starter
Koobs's Avatar
ping is fine, i did the research. I wouldnt download demos in that case, maybe 1 a month if i really wanted to.
so i removed it...
Koobs is offline
Old 10-29-2008, 12:44 PM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 88
He's using a tethered iphone for internet service. That means that his ISP is ATT Wireless or T-Mobile. I'm not so sure that those services are as concerned about latency as a conventional ISP, not to mention dropped packets.
Shape is offline
Old 10-29-2008, 12:59 PM
Nophix's Avatar
You aren't going to use 400meg in 1 hour of multiplayer. Your machine does the rendering, all the connection does is stat track, using something similar to grid coordinates. I've tracked my bandwidth usage across my network, and my 360 uses about 10GB a month. That is including demos, tv shows, and other DLC. I DL demos about every night. For the record, I game on COD4 a lot, especially that month.
Nophix is offline
Old 10-29-2008, 01:49 PM
CiPNET's Avatar
I just had to upgrade my cable modem to commercial. I was allowed 50GB per month on the residential account and I went over 150GB last month. Now I have 10MB Down / 1000GB Up speeds with unlimited bandwidth per month. Was paying $39.99 per month and now I am paying $180.00 per month. Note. I use this line for my business as well. IT consultant.
CiPNET is offline
Old 10-29-2008, 01:55 PM
CiPNET's Avatar
How is your Live connection on the tethered iPhone? I would assume it mustn't be all that good?
CiPNET is offline
Old 10-29-2008, 02:08 PM
Slordak's Avatar
If you want to stay under 4gb, you should refrain from downloading demos or movies. As Microsoft keeps "enhancing" the dashboard, more and more content gets pushed to it automatically each time you sign on, which eats up some amount of bandwidth even if you're not playing a multiplayer Xbox Live game.
Slordak is offline
Old 10-29-2008, 03:06 PM
Nophix's Avatar
We tried teathering our AT&T connection(not iphone, but still same speeds with a Palm smartphone), and bridging to the 360 from our laptop when the cable connection was down, and it worked Ok. There was some noticeable lag in COD4 at times, but not bad. It's still 2.2mbps. Ping went from 42ms on my normal server to 60ms, but not enough of a difference for me to notice. Still under 100ms.
Nophix is offline
Old 10-29-2008, 06:40 PM - Thread Starter
Koobs's Avatar
how do you bridge the connection to the 360? how do you get DNS and IPs?
im a newb so answer in newbian. thanks
so i removed it...
Koobs is offline
Old 10-29-2008, 08:09 PM
danieloneil01's Avatar
2.2mbps? BS. The fastest is 3G right? And 3G isn't that fast even when you're right next to the tower. 3G is at best 700k down.
I have a 3G iphone and with full bars, it's no where close to 2.2mbps. 3G is around 2x as fast as edge and edge is DIRT slow.
D.I.N.K
Double
Income
No
Kids
danieloneil01 is offline
Old 10-29-2008, 09:35 PM
darklordjames's Avatar
Liked: 94
"and with full bars"
You realize "bars" on a cellphone doesn't mean a damn thing, right? Bars tells you signal strength, but does not tell you noise floor. It is very possible, and quite common, to be in a "1 bar" situation and have far better performance than in a "five bar" situation.
darklordjames is offline
Old 10-29-2008, 09:58 PM - Thread Starter
Koobs's Avatar
... and bridging to the 360 from our laptop when the cable connection was down, and it worked Ok...
HOW?! over a computer-to-computer network?
so i removed it...
Koobs is offline
Old 10-29-2008, 10:44 PM
formulanerd's Avatar
its fairly easy, when the 360 launched i didnt have wireless on the xbox or a way to run a wire, i connected my laptop wireless bridged the ethernet to the 360, it doesnt matter what your connection source is (wireless, 3g, tether) it all works the same.
No trees were harmed forming this post, though many electrons were inconvenienced.
SERGEANT SERGEANT MASTER SERGEANT SHOOTER PERSON
Then:|A40|AX720|F1|K702|DT880|ES7|MS2i Now:|MS1|AD700|PC360|A30
formulanerd is offline
Old 10-29-2008, 11:39 PM
Chase117's Avatar
You will not be playing any online multiplayer games with that connection. Believe me.
Gamertag: TrounCeN
I'm a Halo 3 semi pro. seriously.
Chase117 is offline
Old 10-30-2008, 12:25 AM
ogbuehi's Avatar
Explain how you can hook up an iphone to a 360 and play online? My friend has an iphone and he can't do that with his.
ogbuehi is offline
Old 10-30-2008, 06:54 AM
Nophix's Avatar
Connect iPhone to computer, go into network settings, and bridge the iPhone connection to the hardwire connection from the PC to the Xbox. There is a setting when you right-click on the iPhone connection. It says Bridge.
Nophix is offline
Old 10-30-2008, 08:06 AM - Thread Starter
Koobs's Avatar
is bridging also referred to as internet sharing?
Because when i try sharing my connection from airport to ethernet it says my network settings will be affected and i get booted from the tethered connection.
I think what I need to figure out is how to share internet from a computer-to-computer network.
so i removed it...
Koobs is offline
Old 10-30-2008, 08:17 AM - Thread Starter
Koobs's Avatar
why not?
I did a speed test and the results are more than enough to run live
DL - 650kbps
UL - 320kbps
ping - 160 milliseconds
so i removed it...
Koobs is offline
Old 10-30-2008, 08:58 AM
Dark Helmet's Avatar
I have done this before. I call it "Macgyver internet" It works,and not all that badly. I had to do this when my cable went down for a few days.
Dark Helmet is offline
Old 10-30-2008, 09:13 AM
Nophix's Avatar
You will have to restart the connections. It has to change settings that result in the deviced being disabled and re-enabled.
Nophix is offline
Old 10-30-2008, 09:28 AM - Thread Starter
Koobs's Avatar
i dono how but it worked. I have to get back home to try and setup the xbox.
but do i just go to airport TCP IP settings and use that IP, Gateway and subnet mask?
will there be any confliction in IP addresses? fiddeling with it yesterday i got a message a few times
CONFLICTING IP
191.191.191.19 in use by DUoidkf0a94393 (some long wierd number)
so i removed it...
Koobs is offline
Old 10-30-2008, 02:07 PM
chrisherbert's Avatar
Quoted: 17 Post(s)
I don't think anyone has really answered the initial question, but I believe the actual amount of data transferred when playing games online (not downloading demos, movies, TV shows, etc) is pretty minimal. I don't think it would push you over 6 GB/per month, even with your other stuff.
chrisherbert is offline
Old 10-30-2008, 02:39 PM
cstmstyle's Avatar
Quoted: 14 Post(s)
I would imagine this is against your cell providers TOS in some way.
Xbox Live- DragonsLee
"I'm not in this world to live up to your expectations and you're not in this world to live up to mine." - Bruce Lee
cstmstyle is offline
Old 10-30-2008, 08:51 PM
Thanks for taking that part and not the real point of what I was saying. 3G is the fastest plan that is offered by AT&T for cell phone service and getting those numbers he said is somewhat hard to believe.
As for your "opinion" sorry that's also BS. When I have 1 bar compared to all bars I notice a difference very easily with speed.
And like the poster above me said. It's against TOS and will most certainly get your cell phone disconnected. Until AT&T offers it then your just waiting to get the hammer from them. It's not hard for them to see what you're doing.
D.I.N.K
Double
Income
No
Kids
Old 10-30-2008, 08:57 PM
why not?
DL - 650kbps
UL - 320kbps
160 m/s is garbage. You're right that the D/L and U/L is more than enough but latency is right up there as importance. But hey if it helps you in FPS games because people can't hit you because you're disappearing then more power to ya
D.I.N.K
Double
Income
No
Kids
Old 10-31-2008, 06:45 AM
Nophix's Avatar
I answered it a while ago when I gave him the data from my network monitoring logs.
Nophix is offline
Old 10-31-2008, 09:05 AM
ogbuehi's Avatar
Thanks for that. I'll let my friend give it a try.
ogbuehi is offline
Old 10-31-2008, 11:57 AM
lovebuzz#836's Avatar
I have seen more people trying this lately, and it always ends badly. Latency will be then end all in this situation, when you are sometimes running 500 milliseconds+ behind the next guy. It will also depend on the game and how it is programmed to handle latency battles, especially on FPS.
Most definitely. This is a good way to get your contract terminated early AND charged the Early Termination fee.
lovebuzz#836 is offline
