New HDMI Colour Space w/NXE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 209 Old 10-31-2008, 10:05 AM - Thread Starter
Ripeer's Avatar
Liked: 46
So on NXE HDMI ( at least on my setup elite 360, Benq w500 720p PJ)
You no longer change the screen format.
Theres still refrence levels.
but now theres an opition called
HDMI Colour Space, which has the follow opitions
  • Auto: Automatically use RGB or YCbCr based on HDMI recommendations for resolution and content type
  • Source- Automatically use RGB or YCbCr based on game or video source
  • RGB-Always display games and videos in GRB format. RGB is supported by all HDMI- compliant displays
  • YCbCr709- Always display.... YCbCr709 is typically used for HD movies
  • YCbCr601- Always display......YCbCr601 is typically used for SD movies
I'm guessing source is probaly the best one to use.
Ripeer is offline
post #2 of 209 Old 10-31-2008, 10:46 AM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 89
That is an awesome set of settings. Nice of them to take the ambiguity out of it!
Josh - GamerTag: ShapeGSX PSN: ShapeGSX
'97 Eclipse GSX - 11.825@117.55mph in the 1/4
Shape is offline
post #3 of 209 Old 10-31-2008, 12:07 PM
orogogus's Avatar
Yes, that's exactly what they should have done in the past, particularly for HDMI. VGA would be nice to know explicitly what is being output too. I'll have to check it out when I get home and download it.
orogogus is offline
post #4 of 209 Old 10-31-2008, 01:13 PM
2&2
2&2's Avatar
Hmm, I honestly wouldn't know which one to choose. All I know is my Samsung DLP has HDMI 1.3 which supports the broader color spectrum , xvYCC, I believe. which do I choose?
2&2 is offline
post #5 of 209 Old 10-31-2008, 01:43 PM - Thread Starter
Ripeer's Avatar
Liked: 46
I don't know I'm abit baffled by all of it.
I tried source and booted up the tomb raider demo to a black screen. I still had sound. But no picture. I'm going to try dig up the manual for my PJ tonight and play around with the settings.
Ripeer is offline
post #6 of 209 Old 10-31-2008, 02:11 PM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
What one uses will vary by display , some displays will auto sync with whatever is sent out while others will only accept a particular format 'properly' . These new settings should allow for better images but might require multiple memory calibrations , one for gaming (RGB) and one for movies (YCbCr) . Then you have the fact that some displays want different levels for different resolutions , fun stuff .
- Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #7 of 209 Old 10-31-2008, 02:45 PM
KoRn's Avatar
Quoted: 72 Post(s)
Liked: 38
Great. Now it will be even more confusing! I have a Samsung lcd hdtv. Using hdmi and have it set up in pc mode. What new setting would be best? I might as well ask before it gets here.
KoRn is offline
post #8 of 209 Old 10-31-2008, 03:39 PM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
KoRn ,
If you wish to leave the Samsung set for PC mode (0-255) for everything then you would use the third option listed above ...
RGB - Always display games and videos in RGB format .
However this will probably be expanding the 16-235 levels found in movies out to 0-255 and it might not look as it should , we'll have to wait and see just exactly what the new NXE is doing .
* It's sounding to me like the best option here is going to be that having multiple memories calibrated will yield the best results (one for games and one for movies) . But then even beyond that you could add in an additional one for YCbCr709 when watching HD-DVD's (for those that still do use the add-on) .
* For those that only game on their 360's the choice is easy ... RGB (as long as your display properly handles RGB via HDMI - most do) . Just be sure that you are calibrated to 0-255 , this is easy to do with a PC and the free colorfacts test patterns .
- Jason
post #9 of 209 Old 10-31-2008, 04:08 PM - Thread Starter
Ripeer's Avatar
Liked: 46
Originally Posted by DaGamePimp View Post
KoRn ,
- Jason
Well hopefully the Auto selection will automatacily pick the best opition for your display and content.
Ripeer is offline
post #10 of 209 Old 10-31-2008, 04:27 PM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Yes but there-in lies the rub , if your display is only calibrated for 0-255 or 16-235 then somewhere you are sacrificing the image of either games or movies . So even if the 360 is readjusting the levels for AUTO one would be either giving up the full RGB range for games or sacrificing BTB/WTW information for movies . I use 2 calibration memories for games and movies in order to get the best of both , it's just a simple button press on the remote once the calibration work is done .
Most people are calibrated for 16-235 because they used an sd calibration disc in the 360 to adjust the contrast/brightness but this is not what you want for native RGB games . I wonder how many people have never even seen the full 0-255 range with their 360 games . In other words I set the 360 for Expanded (0-255) , I have one memory that is 0-255 for games and another that is calibrated for 16-235 when watching video/movies (I currently use VGA) .
* Keep in mind all of this does not apply if you use Component video , this applies for HDMI (and VGA) , standard component is 16-235 .
- Jason
post #11 of 209 Old 10-31-2008, 05:07 PM
ogbuehi's Avatar
Wow! With all this new information I have no idea which one to choose.
ogbuehi is offline
post #12 of 209 Old 10-31-2008, 05:32 PM
Dahlsim's Avatar
The main point to avoid is forcing one type of signal when your TV or projector is expecting a different signal.
16-235 shouldn't be thought of as related to "SD" since it's really a standard video level signal. In fact as I understand it they adopted this partly because it left room for signals below black and above white w/o clipping.
Most people should be just fine with an auto setting if they are not sure their set supports because Color Decoding of the display will take a video signal and convert it to RGB anyway. Most peoples set should support the video signal.
RGB is nice to use if you know your set supports it although I doubt much real difference would be seen. Worth checking out though if your set supports it. Usually if a set supports RGB rather than Video level it makes it pretty clear in the menu and manual.
Family DVD Collection
Insider thread last question? R.I.P.
Nothing will ever be attempted if all possible objections must first be overcome.
Samuel Johnson 1709-1784, British Author
Dahlsim is offline
post #13 of 209 Old 10-31-2008, 07:03 PM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Certainly valid points Dahlsim but my comment was simply meaning that most people are probably calibrating using a standard def dvd using normal BTB & WTW patterns which are obviously 16-235 and therefore they are missing the full range when playing games . I would agree that most will probably be ok with Auto but again this is all display dependent and the best solution IMO is to have 2 different calibration memories ( at least if you are critical like me , I can see a difference ) .
- Jason
post #14 of 209 Old 10-31-2008, 07:31 PM
Valence01's Avatar
KoRn ,
I seriously doubt that after the VGA fiasco, that Microsoft would be stupid enough to put out RGB at 16-235 levels. Video (YUV) originally encoded at 16-235 is automatically converted to 0-255 levels during conversion to RGB.
P.J.
Valence01 is offline
post #15 of 209 Old 10-31-2008, 08:51 PM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
P.J.
We can only hope .
- Jason
post #16 of 209 Old 10-31-2008, 09:22 PM
sperron's Avatar
These options and the reference levels are seperate. So after you select the reference levels, you then get to pick amoung these options. So if you pick expanded, you will get any of these options with expanded PC levels. If you choose standard, then you get all these options with video levels. You cannot for instance pick YCrCb with video levels and also have RGB with PC levels. Basically nothing has changed except we now have the option of whether to send our TVs RGB, YCrCb or both. Previously the 360 made the decision automatically.
The color space options are kind of odd. Why you would want to send the 601 color space to a TV expecting 709 is beyond me (720/1080 are always 709). I guess it could compensate for your TV using the wrong color space, but you'd have to be savvy enough to know your TV had that problem in the first place. The best option in a situation like that is to just send RGB and remove the color space from the equation.
sperron is offline
post #17 of 209 Old 10-31-2008, 09:46 PM
Chris Rein's Avatar
The OP pretty much sums this up, or at least they covered off what the item description is for. I might give it a shot with Netflix. The only HD one I have found has been The Office Season 1 where I get the, "Presented in HD" logo. The rest are super soft SD streams which most are "Starz" flicks.
Chris Rein is offline
post #18 of 209 Old 10-31-2008, 09:55 PM
talbain's Avatar
what the hell is nxe?
---Mr. Met---
J-E-T-S-JETS JETS JETS!!!!!!! --- LETS GO DE-VILS!!!!!!! --- LETS GO METS!!!!!!! --- LETS GO NETS!!!!!!!
talbain is offline
post #19 of 209 Old 10-31-2008, 10:07 PM
Chris Rein's Avatar
The New Xbox Experience, aka new dashboard, aka new console. I've even heard Next Xbox Experience.
post #20 of 209 Old 10-31-2008, 10:34 PM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
AH , well then that changes things , thank you for the information !
- Jason
post #21 of 209 Old 11-02-2008, 03:39 PM
jpjibberjabber's Avatar
How do people have it already? I thought it came out 11/19.
jpjibberjabber is offline
post #22 of 209 Old 11-02-2008, 03:53 PM - Thread Starter
Ripeer's Avatar
Liked: 46
Major Nelson (Sort of the unofficial mascot of XBox) had sign up for preview, not to be confused with the beta version that is floating around torrents.
Ripeer is offline
post #23 of 209 Old 11-02-2008, 04:42 PM
257Tony's Avatar
If you install it early, you can't connect to XBL until the 19th. I installed it on on my second console that doesn't go online. Overall its pretty cool.
257Tony is offline
post #24 of 209 Old 11-02-2008, 06:41 PM - Thread Starter
Ripeer's Avatar
Liked: 46
Thats if you download the beta thats floating around.
There are people that have been given a preview of it by microsof. And they can connect to XBL
Ripeer is offline
post #25 of 209 Old 11-02-2008, 07:35 PM
Chris Rein's Avatar
Agreed. I can get on XBL no problem. Didn't get it from Major, but did get it from MS.
post #26 of 209 Old 11-03-2008, 08:03 PM - Thread Starter
Ripeer's Avatar
Liked: 46
back on track. Of course the settings will be different for everyone.
But I'm finding for playing fable 2. the Current settings are really nice on Bneq w500 3lcd projector.
720p
Auto
Expanded.
I jumped in and out of save files for awhile on expdanded and rgb vs auto.
dungion (castle Farefxe tomb) you chould see the shades of each indivudal green as if it was sort of paint by numbers (ie green 3 here greeen 4 green 5 here)
But on Auto and Expedaned I didn't have the problem.
I also tried a spot in Garths (well mine now ) tower. Basiacily walking up stone stairs looking at the wall which is covered in fire light. Much richer and bolder.
Slightly darker. which I comensated by turning up my PJ brightness.
My xbox default RGB and standard. I suspect its as the previous poster said we will have to make different settings on displays for different content. I've already made one for fable 2/360 games
Just though I'd share my findings.
Ripeer is offline
post #27 of 209 Old 11-04-2008, 12:19 AM
cybersoga's Avatar
If the reference levels setting is separate, does that mean you can set "expanded" (PC Levels) + YCbCr, which is totally incompatible screen known to man?
What we need is RGB at PC levels for computer games, and YCbCr at video levels for video, please, please, please, MS add an auto option to the reference levels that does just that!
cybersoga is offline
post #28 of 209 Old 11-04-2008, 08:44 AM
formulanerd's Avatar
whats the point of that? you arent playing any computer games or 360 games requiring pc video levels through your 360.
all you need is the auto setting, rgb for games, ycbcr for video... its there in the NXE
No trees were harmed forming this post, though many electrons were inconvenienced.
SERGEANT SERGEANT MASTER SERGEANT SHOOTER PERSON
Then:|A40|AX720|F1|K702|DT880|ES7|MS2i Now:|MS1|AD700|PC360|A30
formulanerd is offline
post #29 of 209 Old 11-04-2008, 08:58 AM
RafaelSmith's Avatar
Quoted: 597 Post(s)
Liked: 431
I never could figure out how to best set my current XBOX display settings.
I am using VGA @ 1920x1080 to my Vizio 47" LCD...the whole expanded, intermediate stuff never made sense to me. That and the fact I could never get a straight answer from Vizio tech on what exactly the VGA port on the Vizio is..0-255 or 16-235
I just picked what looked the best.
I only use my 360 for games so probably doesn't matter.
Hopefully the new selections will make more sense to me.
RafaelSmith is offline
post #30 of 209 Old 11-04-2008, 09:52 AM
cybersoga's Avatar
All xbox 360 games natively have 255 levels RGB, where 0 is black and 255 is white (same as PC). If the xbox 360 is outputting video levels then the 255 levels are compressed into 223 levels which reduces picture quality for games.
Reply Xbox Area
