invalid format when switching hdmi cables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-16-2008, 08:08 AM - Thread Starter
blime84's Avatar
Guys,
I have an xbox elite with the hdmi outputs, I wanted to plug in my laptop which has hdmi to my plasma, so I uplugged the cable from the xbox and plugged in my laptop which displayed fine, but when I plugged my xbox in again to play it(just unplugged the hdmi cable from the laptop and put it in the xbox again) it said invalid format. I read earlier someone fixed this by resetting the settings of the xbox blindly. Can someone give me step by step directions on this please?
blime84 is offline
post #2 of 3 Old 12-16-2008, 11:52 AM
H0M3GR0WN's Avatar
if it works the same as it used to (pre-NXE), then power on console Use controller number 1 holding the Y button the whole time, then pull or hold the right trigger until console restarts itself.
I have not tried this post NXE, and can't test since my console is being repaired.
H0M3GR0WN is offline
post #3 of 3 Old 12-16-2008, 01:38 PM
daschrier's Avatar
You try turning the tv off and then on again?
daschrier is offline
Reply Xbox Area
