audio question.. - AVS Forum
post #1 of 11 Old 01-31-2009, 01:08 PM - Thread Starter
freshane's Avatar
I recently got a 1080p LCD tv. I am currently using components with optical audio. When I transfer over to HDMI does it bring audio as well?? I don't have HDMI into my receiver so the only way I can bring audio is thru digital coax or optical. Is there anyway I can run HDMI with optical audio??
freshane is offline
post #2 of 11 Old 01-31-2009, 01:21 PM
forcedfedgtp's Avatar
The HDMI from the Xbox will carry both audio and video to the TV. You can buy a dongle box for the X360 to allow you to use the optical output to your receiver and run your HDMI for the video.
forcedfedgtp is offline
post #3 of 11 Old 01-31-2009, 01:59 PM - Thread Starter
freshane's Avatar
great, thanks!
I can use my current dongle with components the only thing is I need to take the bottom half of it off to get at the hdmi port! I tried using a knife to pry it apart but no luck.. seems like its snapped together
nm got it working, its a tight fit but works
freshane is offline
post #4 of 11 Old 01-31-2009, 03:09 PM - Thread Starter
freshane's Avatar
When playing games does any sound come thru the center channel???
freshane is offline
post #5 of 11 Old 01-31-2009, 04:06 PM
Ripeer's Avatar
Liked: 46
It should, quite a few people find that when using HDMI to the reciver they have problems with sound. Try andf check on your reciver if there any lights/menus/displays that let you know your still getting a DD 5.1 signal and not PCM 2.0 signal.
I've resorted to HDMI for picture and Optical found sound as it always works.
Ripeer is offline
post #6 of 11 Old 01-31-2009, 04:54 PM
confidenceman's Avatar
Liked: 37
If you're having audio issues with HDMI, go to your sound options on the dash, set to 2-channel, then set back to 5.1. That usually will fix any of the common handshake issues with the 360.
PSN & XBL ID: drop me a private message
confidenceman is offline
post #7 of 11 Old 02-01-2009, 11:02 AM
BMaugans's Avatar
It varies from game to game - many games don't utilize the center channel.
BMaugans is offline
post #8 of 11 Old 02-01-2009, 12:59 PM
formulanerd's Avatar
i thought a developer requirement for the 360 was DD5.1?
No trees were harmed forming this post, though many electrons were inconvenienced.
SERGEANT SERGEANT MASTER SERGEANT SHOOTER PERSON
Then:|A40|AX720|F1|K702|DT880|ES7|MS2i Now:|MS1|AD700|PC360|A30
formulanerd is offline
post #9 of 11 Old 02-01-2009, 01:38 PM
metal83's Avatar
Every game i've played on the 360 so far has DD5.1, i've yet to see a game without it.
metal83 is offline
post #10 of 11 Old 02-01-2009, 02:07 PM
LexInVA's Avatar
Liked: 40
The 360 encodes core game audio into a Dolby Digital 5.1 stream by design. A developer can optimize their game audio code for 5.1 streaming in the Xaudio API during development of a title but there is no actual Dolby Digital work in a game except for the occasional cutscene or video clip that has a pre-encoded track. The only requirement is that the game be compatible with the DICE (Dolby Interactive Content Encoding) technology built into the console.
LexInVA is offline
post #11 of 11 Old 02-01-2009, 10:02 PM - Thread Starter
freshane's Avatar
Thanks for all the info.. I actually had a rca/optical dongle that came with my elite that I forgot about. I got the center channel working, I had to go thru a setup on my receiver and select how many speakers I had and that did the trick.
freshane is offline
Reply Xbox Area
User Tag List
