Help w/ connecting to XBL. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-27-2009, 02:38 PM - Thread Starter
Degenerazn's Avatar
Quoted: 18 Post(s)
For all the tech heads out there, I'm hoping you can give me some help.
All of a sudden, my Xbox can't connect to Live any more. I ran the tests and it can get internet, but the bar stops about 1/3 the way to LIVE. And everytime I did the test connection on the Xbox, my router would reset, disconnecting everything for a brief second or two. For the record, my PS3 connects to PSN just fine and my laptop works fine when wired. Any ideas?
I've been connecting to Xbox Live thru a bridge connection thru my laptop, but I often can't get into the same games as my friends. It feels limited I suppose.
Degenerazn is offline
post #2 of 3 Old 05-27-2009, 05:40 PM
Mike LS's Avatar
Which step of the test does it fail on?
Gamertag: crud monkey
Mike LS is offline
post #3 of 3 Old 05-27-2009, 06:08 PM - Thread Starter
Degenerazn's Avatar
Quoted: 18 Post(s)
At connecting to LIVE. But I fixed. Had to do some manual NAT opening with my router and xbox.
Close.
Reply Xbox Area
