Replacing xbox game controller cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-29-2010, 06:45 AM - Thread Starter
husher69's Avatar
I need to repair an xbox wireless controller. It uses 5 wires. I've seen people use a USB cable but given that's only 4 wires I'm assuming that won't work for a replacement.
I understand Category 3E (phone Wire) has 5 wires, but is the gauge enough? It's also kinda flimsy feeling. I'm thinking of using network cable (Ethernet) and only using 5 of the 8 wires in the cable. Is the gauge enough to work?
Or is there a better type of wire I can use?
husher69 is offline
post #2 of 8 Old 03-29-2010, 09:05 AM
Slordak's Avatar
I don't understand the question. You're talking about a wireless controller, but you're asking about the wiring. Are you talking about some sort of internal repair, i.e. a wire break inside the controller? How do you know that this is what's broken?
Slordak is offline
post #3 of 8 Old 03-29-2010, 09:38 AM - Thread Starter
husher69's Avatar
It's a wireless controller that has about 18 inches of cable from the xbox controller port plug to a wireless transmitter (with game ports). The connection to the actual controller is wireless but there is 18 inches of actual cable that needs to be replaced.
husher69 is offline
post #4 of 8 Old 03-29-2010, 09:56 AM - Thread Starter
husher69's Avatar
It's pretty obviously the cable since it work's intermittently when you wiggle the cable, and the previous owner's CAT must have left hundreds of teeth marks resulting in exposed copper wiring. Don't ask. I'm fixing this for a friend.
I had a similar issue with the xbox's access point's network cable which was a simple replacement.
husher69 is offline
post #5 of 8 Old 03-29-2010, 11:08 AM
rdethloff's Avatar
Liked: 33
I'm assuming this is for the original xbox, right? If the wireless transmitter is similar to the logitech one I used for my xbox, I would think using the CAT5 cable would be fine...
rdethloff is offline
post #6 of 8 Old 03-29-2010, 11:14 AM
dbc
dbc's Avatar
I'm guessing the wire gauge will be OK with the Ethernet cable.
More importantly, see if you can find some wire management product that will serve like some "armor". Like that nylon spiral that allows you to branch out sections of wire. It's not much protection, but the covering might distract the cat away from the actual cable.
dbc is offline
post #7 of 8 Old 03-29-2010, 11:24 AM - Thread Starter
husher69's Avatar
Thanks for the idea. There's no more cat to worry about.
I was thinking of picking up some tubular shrink wrap. Basically I just slide over the cable after I've soldered and sealed the connections with electrical tape, then use a hairdryer to shrink the black tube from an inch wide to a quarter inch wide. It's intended for outdoor protection, but for a buck per meter, it'll make it look like it wasn't repaired (hopefully).
husher69 is offline
post #8 of 8 Old 03-29-2010, 02:54 PM
darklordjames's Avatar
Liked: 94
You could also just buy a cheap Xbox controller and harvest the wiring from that. If you can find one at a local Gamestop, I'm sure it'd be cheap as they've been trying to unload Xbox for a while now.
darklordjames is offline
Reply Xbox Area
