How to copy purchased game disc to xbox hard drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 09-10-2010, 03:12 PM - Thread Starter
bcab17's Avatar
Quoted: 40 Post(s)
Now that the new xbox 360 I got for my son has a 250gb hard drive, I would like him to start copying the purchased game discs to the xbox 360's hard drive. I've read that this saves wear and tear on the disc drive, loads games faster, and most importantly reduces the risk of damaging the $60 game discs. I assume this is legal since I've purchased the discs, but I have absolutely no idea how to do it.
bcab17 is offline
post #2 of 15 Old 09-10-2010, 03:54 PM
mguy5's Avatar
Quoted: 39 Post(s)
Liked: 55
Insert the disc. When you see the game on the dashboard menu, instead of hitting 'A' to play game, press 'Y' to see game details. One of them will be 'Install to Hard Drive'.
Note: Disc must still be in the tray to play it off your hard drive.
"We've tried nothing and we're all out of ideas." - Agnes Mona Flanders
mguy5 is offline
post #3 of 15 Old 09-10-2010, 05:28 PM - Thread Starter
bcab17's Avatar
Quoted: 40 Post(s)
If you don't mind another dumb question...after a game is installed on the hard drive, when you want to play it in the future, after inserting the disc into the console, does it automatically default to playing the game from the hard drive instead of from the disc or do you have to select that option?
bcab17 is offline
post #4 of 15 Old 09-10-2010, 06:36 PM
gpthree's Avatar
It should automatically play from the harddrive.
Consider the unparalleled advantage, of a natural disaster that's impossible to manage.
gpthree is offline
post #5 of 15 Old 09-10-2010, 07:01 PM
joebloggs13's Avatar
Are there any differences in gameplay when comparing Hard drive saved game vs disc played game? Glitches etc...?
joebloggs13 is offline
post #6 of 15 Old 09-10-2010, 07:33 PM
JohnnyPraze's Avatar
Quoted: 28 Post(s)
Faster load times. Game performance/experience may improve depending on the game as well if played from the HD.
XBOX Live: Hanxious
JohnnyPraze is offline
post #7 of 15 Old 09-10-2010, 08:37 PM
Taubs's Avatar
main reason i do it isto stop the noise of the disc spinning
Taubs is offline
post #8 of 15 Old 09-11-2010, 06:34 AM
Another question...I currently play the disc, and save my progress. If I copy the game to the HDD, and say at some later date, for lack of space, delete certain games, will my progress in these games be deleted as well?
post #9 of 15 Old 09-11-2010, 06:39 AM
cfmustang's Avatar
Nope. Game saves are separate files from the install.
cfmustang is offline
post #10 of 15 Old 09-11-2010, 06:46 AM
Shin CZ's Avatar
Yeah, installing games is worry free. If for some reason you need to delete the installed game, nothing else will be affected.
Note: A few games actually play WORSE when you install it on the hard drive, though nowadays it shouldn't be an issue.
Shin CZ is offline
post #11 of 15 Old 09-11-2010, 06:50 AM
Thanks guys. Will try it when I get mine back. Hopefully it's fixed, and won't cause me any more grief.
post #12 of 15 Old 09-11-2010, 09:20 AM
the red worm's Avatar
the only game I've heard not to install is Halo 3
of course here is the big list cag has posted that is pretty handy
http://www.cheapassgamer.com/forums/...d.php?t=202456
the red worm is offline
post #13 of 15 Old 09-11-2010, 09:51 AM
kjr39's Avatar
Quoted: 73 Post(s)
Liked: 80
Same games (Bad Company 2) you get quite the advantage for having installed the game.
Salminella is wandering the Wasteland: PSN
kjr39 is offline
post #14 of 15 Old 09-11-2010, 05:44 PM
Ripeer's Avatar
Liked: 46
Through some games such as Halo and crackdown run worse when installed.
Ripeer is offline
post #15 of 15 Old 09-11-2010, 08:13 PM
Halo 3 is the biggest known one, if you follow the link I posted it shows a list of most game and if it improves or hurts load times.
Reply Xbox Area
