The NEW Gaming Headset/Headphone Topic! (REQUEST STICKY PLZ) - Page 190 - AVS Forum
 19Likes
post #5671 of 5686 Old 01-04-2015, 09:35 AM
jbn008's Avatar
Quoted: 29 Post(s)
Stealth 500x
For anyone who's on the fence about purchasing the 500x, I can say that I am a very happy that I picked one up.
I had the Astro A50s with a PS4 and when I switched over to the Xbone I sold them (hated having to use the chat cable). That being said, I am very happy with the performance from the 500x. The Astros are arguably better in terms of sound quality, but the TBs aren't far behind and the 500x's chat quality is MUCH better, not to mention wireless.
Just my 2 cents
Headless Petie
jbn008 is online now
post #5672 of 5686 Old 01-05-2015, 09:41 AM
anthonycm's Avatar
Steel Series Question:
I received the Steel Series H for Crimmus. The problem is the Xbox cable that came with it is a 2.5mm on both ends, so it won't fit into the Xbox headset adapter (too loose). Has this happened to anyone else? Not a big deal, but I'm annoyed that I have to go out to purchase a 2.5mm to 3.5mm wire or adapter.
-anthony
www.twitter.com/anthonycmoreno
PSN - anthonycm
XB1 - anthonycmo
anthonycm is offline
post #5673 of 5686 Old 01-05-2015, 01:24 PM
KLUNKDM's Avatar
-anthony
I think mine didn't have one and I used the one that came with the headset adapter. Been too long to remember, but I know I didn't buy any other cables.
KLUNKDM is offline
post #5674 of 5686 Old 01-05-2015, 01:40 PM
emartins's Avatar
Quoted: 603 Post(s)
Liked: 583
-anthony
The Xbox cable is listed on the bag as a xbox 360 cable but that changed with the XB1. I already had a 2.5 - 3.5 cable that I purchased earlier in the year so I never noticed till I checked the box. But Klunk is right, the Xbox headset adapter came with a 2.5 - 3.5 adapter, at least it used to.
One of the greatest posts I have read
benjamin-benjami - http://www.avsforum.com/forum/142-pl...l#post24609271
emartins is offline
post #5675 of 5686 Old 01-05-2015, 05:00 PM
anthonycm's Avatar
Yup, there's one in the box with the adapter. Didn't even think about that (honestly surprised they supplied one).
PSN - anthonycm
XB1 - anthonycmo
post #5676 of 5686 Old 01-06-2015, 04:17 PM
smokozuna's Avatar
Quoted: 28 Post(s)
-anthony
http://www.ebay.com/itm/301399281988...%3AMEBIDX%3AIT
smokozuna is online now
post #5677 of 5686 Old 01-08-2015, 03:42 AM
henhowc's Avatar
Quoted: 28 Post(s)
looks like xbone is going to get its own branded version of the elite 800
henhowc is offline
post #5678 of 5686 Old 01-08-2015, 05:10 PM
rightintel's Avatar
Quoted: 142 Post(s)
Liked: 62
Link?
Xbox Live: General PATT0N
rightintel is offline
post #5679 of 5686 Old 01-08-2015, 07:41 PM
dandiego's Avatar
Quoted: 24 Post(s)
Originally Posted by rightintel View Post
Link?
Turtle Beach Elite 800X - http://www.neowin.net/news/turtle-be...t-for-xbox-one
dandiego is online now
post #5680 of 5686 Old 01-08-2015, 09:34 PM
henhowc's Avatar
Quoted: 28 Post(s)
hoped they fixed the design flaw where the buttons were too easy to trigger
henhowc is offline
post #5681 of 5686 Old 01-09-2015, 04:30 PM
rightintel's Avatar
Quoted: 142 Post(s)
Liked: 62
Originally Posted by dandiego View Post
Thanks. So built in mic, and a charging stand...meh. If the mic works well, it's a decent upgrade. I personally see that as a downgrade, becuz I like adjusting the mic volume by moving it away/closer depending what others are hearing from me. As far as the charger, mine are plugged into USB outlet right next to my lazyboy already.
post #5682 of 5686 Old Yesterday, 01:22 PM
oktoberrust11's Avatar
Quoted: 20 Post(s)
Liked: 24
So I've finally gotten around to gathering the required pieces to make my TB X12's work with the XB1. I have the XB1 Stereo headset adapter, and just picked up a TB Ear Force DSS for $12 on eBay. I connected everything yesterday in this manner:
XB1 optical out --> Ear Force DSS optical in
XB1 USB --> Ear Force DSS USB
Ear Force DSS USB --> TB X12 USB
Ear Force DSS 3.5mm out --> TB X12 Green 3.5mm
With this connection setup, I'm getting good volume on game audio & receiving chat audio, and I can also chat.
Here's my issue/question; I have (3) different interfaces where I can control volume, bass boost, etc. (Ear Force DSS, TB X12, XB1 headset adapter), and I don't know what the optimum levels are for each. Actually I guess (4) interfaces, including the chat/gameplay audio levels in the XB1. Also, I'm assuming the settings on the XB1 should be set to Bitstream Out, then Dolby Digital?
I guess just a little guidance/clarification would be assuring.
Matt
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #5683 of 5686 Old Today, 01:19 PM
MilkManX's Avatar
Quoted: 39 Post(s)
Liked: 30
Matt
I have mine set like this...
DSS2- Volume about 7 on the dial- EQ-Bass Boost on Normal and the Surround on setting 3.
Headset Adapter I set it to chat at FULL-no game volume mixing(will cause an echo with the x12)
X12 dials to a level where I can hear the game and my team mates well but its also the easiest to adjust. Barely any roll on the bass boost though(due to the DSS2).
With that it sounds great. IF you have the chat adapter pass any game sound you will get a faint echo in the headset.
MilkManX is offline
post #5684 of 5686 Old Today, 01:36 PM
Quoted: 20 Post(s)
Liked: 24
Thanks MilkMan! I will try out your settings the next time I'm able to play!
post #5685 of 5686 Old Today, 09:32 PM
smokozuna's Avatar
Quoted: 28 Post(s)
Matt
max out the chat and volume on the headset adapter and max out the tb dss, use the controls on the x12 amp for everything after that. also leave the bass boost turned all the way down if you can.
also i just bought one of these cables and they are brilliant!
post #5686 of 5686 Old Today, 09:42 PM
smokozuna's Avatar
Quoted: 28 Post(s)
we run our dss maxed, default settings on the dss, max out the chat and volume buttons on the headset adapter. we use only the dials on the x12 amp to adjust everything and we never use the headset adapter for anything.
Reply Xbox Area
