AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Xbox Area (http://www.avsforum.com/forum/141-xbox-area/)
-   -   Rock Band 3 Freestyle Drum/Mic Lag (http://www.avsforum.com/forum/141-xbox-area/1334437-rock-band-3-freestyle-drum-mic-lag.html)
ShotgunZen 05-11-2011 06:10 PM
Greets All,
This question is for anyone playing Rock Band 3 through a high end 7.1 AVR.
First of all, and IMPORTANTLY, I'm not worried about standard lag - the kind the game can calibrate away. To see if you have lag from your digital audio processing, do the following: Load the drum trainer, and play a roll as fast as you can. If you hear a hit or two happen AFTER you finish, that's lag from your AV system. If you don't...well, you're alot less annoyed than me, probably.
If you can play RB3 with no lag time on the drum fills/freestyle/mic via HDMI, please post the receiver model you're using. I have a Yammy RX-A2000 which I really like, but I can't get rid of the lag and I'm about to ebay the damn thing and get something comprable if I can find an AVR with no drum lag. Thanks...
logicalnoise 05-11-2011 09:35 PM
Originally Posted by ShotgunZen View Post
Greets All,
Harmon Kordon's have never had this problem as far as I know. Mine only does optical but lag has never been a problem.
CoreyM 05-11-2011 10:47 PM
I've had good luck with HK, Rotel and Denon, but I disable all surround processing.
Cheaper Onkyo I had for a while added about 45ms to the average.
I find <20 ms to be acceptable.
Just one thing to add - my HK AVR (254) forces video processing on you if you run through HDMI, it can be calibrated away in RB but it adds about 40ms of lag which I don't want when playing FPS games.
garciab 05-12-2011 07:45 AM
I still think this is more a problem with the game. I can tolerate the lag on GH a lot better than that on RB. Speaking only of the games during only the 'freestyle' moments.
Eddie Horton 05-12-2011 07:59 AM
I had to disable the drum fills in RB3 because of the lag. Running HDMI from XBOX to Panasonic XR-57 to 55" Sony Bravia LCD. Even with the TV in Game Mode and all extra processing turned off in the receiver, it's still not tolerable. It's strange that it's only on the fills, though, but it sure makes you look like a goofball when you have been hitting every note on Expert Pro drums and then fall apart on a fill.
Lord Flatus 05-12-2011 08:30 AM
It only makes sense. The game deals with the lag by assuming you'll hit all the notes and playing them before you strike the pads/cymbals or strum a guitar note. That way when you hit the note the sound is coming out right then and it seems like you triggered it. But the first note you miss actually plays and then after that you get the miss sound. I start really noticing it when I'm "on" with the drums and I'm playing really fast sections. It actually takes me out of "suspension of disbelief" for a moment when I know I missed that frickin' note but I hear it play and then afterwards I hear the rim click.
The game can actually tune out quite a bit of lag this way, with the more lag accounted for the more noticeable it is.
In freestyle and fills, the game doesn't know what you are supposed to play so it can't play it first and then check to see if you actually hit it, so you hear the full on system delay that has been cal'd out. Same thing with vocals since it plays your actual voice over the speakers.
It's a pretty slick system that works great, but the fills and vocals show what's really going on.
ileff 05-12-2011 09:40 AM
I'm not sure about this. That means the first charted note would always play no matter what and I don't think thats the case. I'll give it a try.
Maybe you are meaning in crazy fast drumming parts. I play guitar and I've never noticed it playing something I missed. (not including all the slop that pro guitar allows)
Lord Flatus 05-12-2011 10:39 AM
It's usually fast rolls where I notice it most since that's where I'm the weakest. I'll miss one and three notes later my streak will break.
NoThru22 05-12-2011 10:59 AM
11 Attachment(s)
I have an Onkyo 701 and I don't get any lag added over what putting the game in 5.1 does. Apparently later Onkyos used a different processor that introduced a lot of lag, but I think that's corrected on the newer models.
garciab 05-12-2011 11:37 AM
Not even on fills? For me, it's better on RB3, but it's still there and annoying.
Scott Simonian 05-12-2011 05:12 PM
135 Attachment(s)
I used to have an older HK525 that I used optical digital connection with and no lag issues back then in RB2. I now have an Onkyo TXNR3007 and I use HDMI with it. I needed to recalibrate the game with the new receiver and I always use 7.1 upmix (Pro Logic2x/z). I have no lag issues after calibrating.
Since you have a nicer Yammy, make sure to disable any CinemaDSP effects while playing music games. That dsp may add even more lag to the sound, fwiw.
ShotgunZen 05-12-2011 06:04 PM
I've tried running optical audio, disabling Dolby in the game, going to digital stereo on the xbox, and shutting off just about every processing item on the reciever I can get to, including going to pure direct mode. Still getting freestyle drum/mic lag. Some of the above improved it, but pretty much any lag at all will drive you crazy as a couple of you already noted. Really pisses you off to drop 1k+ on an AVR (which otherwise sounds great and is awesome) only to f' up your rock band....My old denon s-101 didn't have this issue at all, and it was doing virtual surround processing for a 2.1 system. I'm gonna try analog audio, but I'm waiting on the adapter for the xbox.
And to clarify again (most seem to follow), this is NOT the standard video/audio lag the game can calibrate away. This is real time lag on drum fills/freestyle/mic only. If you don't play alot/don't sing/don't drum on high levels you likely wouldn't know if you're getting this lag or not. If you're not 100% sure what I'm talking about, try the drum roll test mentioned in the original post.
Any other lag-free AVR recommendations much appreciated....
Eddie Horton 05-12-2011 06:58 PM
The only remedy I've found for RB3 drum playing is........don't sing and turn drum fills off. It's very annoying, no doubt.
CoreyM 05-12-2011 11:10 PM
Not sure if its the later models or just the cheaper models. I think my bad one is a 506.
Scott Simonian 05-13-2011 11:12 AM
135 Attachment(s)
Its not your $1k receiver causing the lag during your fills. It's an inherent design of how the game works. Disable your drums fills. That's what I did.
NoThru22 05-13-2011 01:44 PM
11 Attachment(s)
Yes, it's the $1K receiver causing the lag during fills. People have hooked up cheap receivers from other brands and not had this effect happen.
CoreyM 05-13-2011 02:44 PM
There may be a few (<5) ms of lag inherent in the system and depending if you are wired or unwired but it only becomes an issue when your surround processor isn't fast enough to keep that few ms to an amount that your ear doesn't distinguish. I've tried playing with enough processors to know how broadly it can fluctuate (from 5ms with no surround to 60-70ms on a slow processor with 5.1 enabled). Only on the slow receiver does it sound like I am singing in an echo chamber.
garciab 05-14-2011 09:13 AM
I guess the true test will be with the analog setup. Can't wait to see what his results are then. I'm in the camp that believes the game is to blame.
ShotgunZen 05-14-2011 11:48 PM
It's definately not the game. My old denon s-101 had no lag via optical, and that was with dolby on even.
braves22 03-16-2012 08:01 AM
It could be your tv....
FWIW, I currently am at 196 ms of audio lag just connecting my xbox directly to my tv through HDMI....
Ok, so no problem with the guitar, it matches up ok...
Problem comes in when you play the keys, which are a different lag time, the drums, a MUCH different lag time, and then the worst, the mic which is so off that it sounds as if there's an echo when you sing because your voice feels like a 2 second delay
Lord Flatus 03-16-2012 08:12 AM
196 seems pretty excessive...
braves22 03-16-2012 08:37 AM
Um yeah....
I think so too....
Would be nice if that could get fixed somehow
NoThru22 03-16-2012 09:13 AM
11 Attachment(s)
Originally Posted by braves22 View Post
Um yeah....
I think so too....
What brand and model of TV?
Lord Flatus 03-16-2012 09:39 AM
Um yeah....
I think so too....
Check the other thread you started on this subject for my suggestion. And it would probably be best to move this to the main Rock Band thread for the best chance at useful answers.
braves22 03-16-2012 09:44 AM
Since i am using the app through my iPhone I didn't want to go on a thread like the regular RB one where it's 3 billion posts that I can't search through...
Also for your response in the "other" thread...which other thread and do you have a link?
That would help me....did i respond to your suggestion by chance....I may have already tried what you said?
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
