The Official Xbox 360 Dashboard/Update Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
Old 12-19-2011, 05:12 PM
Quoted: 303 Post(s)
Liked: 43
Originally Posted by Thebarnman View Post
I've never noticed that.
so what are you trying to say? how come i see that?
lamonsasa is offline
Old 12-19-2011, 06:22 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Don't worry about it.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
Old 12-19-2011, 06:33 PM
betterdan's Avatar
I don't see any jerkiness or tearing in the dashboard either. Only problem for me is the messed up black levels.
betterdan is offline
Old 12-19-2011, 07:20 PM
Quoted: 303 Post(s)
Liked: 43
its not in the general dashboard, its when you press the Guide button and the windows comes up, try to move the tabs side to side and look at the edges, they tear slightly, sometimes it doesnt happen, i cant figure it out.. i guess its buggy or something..
Old 12-20-2011, 05:38 AM
betterdan's Avatar
I'll try it tonight.
Old 12-20-2011, 07:26 AM
mboojigga's Avatar
Quoted: 590 Post(s)
Liked: 822
I haven't had this issue. Don't have the black issue either.
The 5.0 is here
mboojigga is offline
Old 12-20-2011, 08:32 AM
Slordak's Avatar
... Everyone has the black issue. Well, that is, everyone using high definition video output via component, VGA or HDMI. I suppose if you were using standard definition (480i) output, you might not have the problem.
I'll admit it can be nuanced in some cases, i.e. if you just look at a random screen, you may not notice it. However, there are certain places where it's more obvious than others. What started out as a vague "Hmmm, does it look a bit off compared to the NXE?" feeling has now been confirmed through independent testing.
Slordak is offline
Old 12-20-2011, 09:28 AM
mboojigga's Avatar
Quoted: 590 Post(s)
Liked: 822
So when exactly did this problem start? I have been in the beta and haven't seen a difference on my two LEDs and Sony LCOS. All 3 systems are 250gb Slims with HDMI. Is it the dashboard or Netflix where the problem shows up?
The 5.0 is here
Old 12-20-2011, 11:24 AM
Slordak's Avatar
I don't know whether this started early in the beta for the new dashboard or at a later point in time, since I wasn't part of that. Others can probably comment further.
The amount of perceived difference will be directly related to how you had your displays setup. For example, if you were using RGB and already had the color levels set to "Intermediate" or "Expanded", you may not see much of a difference during video playback. Basically, although the breakage is across the board, it will have a different level of impact depending on your precise setup. So yeah, I'd certainly believe that you may have a setup and set of calibrations where you don't really notice it much.
See the Digital Foundry / Eurogamer article linked from the previous page for details.
Slordak is offline
Old 12-21-2011, 11:21 AM
michaeltscott's Avatar
Quoted: 2708 Post(s)
Liked: 1429
VUDU's up in the app marketplace for everyone. As promised, no HDX.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
Old 12-21-2011, 02:10 PM
the red worm's Avatar
already an indie game making fun of the new dashboard
http://www.mommysbest.blogspot.com/2...ndie-game.html
the red worm is offline
Old 12-21-2011, 03:34 PM
darklordjames's Avatar
Liked: 94
"So when exactly did this problem start? I have been in the beta and haven't seen a difference"
It started at the launch of the new video apps. The beta dashboard worked great, but then the new video layer seems to have been activated at the launch of the new Netflix and Hulu apps, hours before the dashboard came out of beta. Now with the new video layer active, it effects every source of video that I have seen on the 360. Dropping HDMI reference level from Standard to Intermediate fixes video black levels, but then breaks game black levels. For example, hopping in to Battlefield 3 last night to check out the new Karkand expansion, I had to bump Brightness up from it's 50% level to about 75% to avoid all shadows from just being a deep dark pit of detail-less despair.
You have the black level problem. If you don't see it, then awesome! Doesn't change the fact that it is there, on your systems.
darklordjames is offline
Old 12-21-2011, 03:35 PM
Liked: 94
"already an indie game making fun of the new dashboard"
Not really making fun of it. He's more goddamn pissed off that making XBLIG titles is pretty pointless as it's now impossible to find, and therefore sell, them.
Old 12-21-2011, 05:48 PM
Jeremy Anderson's Avatar
Quoted: 345 Post(s)
Liked: 658
Actually, it started as soon as the first preview update was pushed out. I thought it looked washed out, so I threw the AVS 709 black level test at it... Sure enough, black levels were all wrong. Same for white levels, and resolution was now downscaled to what looks like 720p or lower even with the system set to 1080p (whereas the previous dashboard mostly passed a 1080p resolution test). Setting Reference Levels to Intermediate or Extended does NOT fix black levels, as those two settings actually clip black ABOVE digital 16 (Intermediate clips black around 19-20 and Extended clips it above the range of the AVS 709 black level test, so who knows who off that is). I hooked up my NXE system that hasn't been connected to the internet in some time, and with the same settings as my update system, it was correct (black at 16, white at the correct levels for my calibration compared to my Oppo BDP-83). With the new dashboard, you can see the dashboard itself is at the right level by using a black level test JPG as your dashboard background... but as soon as you play a video, black turns gray. Then more bizarrely, if you stop that video and then resume it, black level changes to be slightly darker, but is still displaying content below 16 that it shouldn't.
But you are correct... Every system with the new dashboard has this problem, but if your set is not calibrated or is using any kind of dynamic contrast, it minimizes your chances of seeing the problem. And it has been confirmed on HDMI, component and VGA connections, in all possible settings of color space/reference level.
"Never believe any quote you read on the internet." - Abraham Lincoln
Jeremy Anderson is online now
Old 12-21-2011, 06:46 PM
John Megadeth's Avatar
Really, no HDX? That's weird...why, I wonder?
John Megadeth is offline
Old 12-21-2011, 06:48 PM
FYI, new Vudu users will get a $4.99 credit after downloading the app and creating an account! I did this with a couple of PS3s.
Old 12-21-2011, 07:13 PM
Liked: 1429
I got two of these one for registering my PS3 and one for registering my BD player. I see that they did give me $4.99 credit for registering the Xbox (expiring on 1/21), though they didn't announce it. I'm sure I can use it on my BD player, which can play HDX and bitstream DD+. I seem to remember that the credit used to be $5.99, the price of a recent release in HDX, so you can sample their highest quality product. That's what I got when I registered my PS3 and my BD player. Of course, you can't rent HDX on the Xbox which might explain it.
Old 12-21-2011, 07:16 PM
Why isn't HDX available? I'll admit, the only times I've used VUDU were with said free credits, but I'm just curious as to why it is excluded.
Old 12-21-2011, 09:41 PM
UHD Addict
aaronwt's Avatar
Quoted: 5219 Post(s)
Liked: 3123
IN another thread someone mentioned that it is only 720P on the 360 right now.
VUDU has SD which is 480P24, HD which is 720P24 and HDX which is 1080P24. So if the 360 only shows 720P then maybe that is why HDX is omitted right now.
Which is probably the best way to do it. Otherwise people would be pissed if they paid for an HDX title and found out that the 360 could only use the 720P version.
Hopefully MS remedies this sooner rather than later and enables 1080P encodes for VUDU as well as Netflix.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
Old 12-21-2011, 10:10 PM
UHD Addict
aaronwt's Avatar
Liked: 3123
I like how this is setup. I logged into VUDU on one 360 and then it associated my Gamertag with my VUDU account. Then when I signed in on my other consoles and opened the VUDU app it automatically gave me the $4.99 credit for those boxes. So I got $14.97 in VUDU credits that are good for one month. I guess I'll be watching some movies on VUDU over the Holidays. I definitely don't want to lose those credits.
Old 12-21-2011, 11:13 PM
Liked: 1429
Except that HD Zune video is 1080p--the "quality meter" has 5 parts, 1 to 3 bars for SD, 3 bars plus the letters "HD" for 720p, 3 bars, "HD" and "1080p" for 1080p. (Unlike VUDU, you cannot buy limited-to-720p video; if you buy the HD version you'll get up to 1080p if you have the necessary bandwidth on your connection. Of course they charge what VUDU HDX costs).
Old 12-22-2011, 02:33 AM
totalownership's Avatar
Quoted: 188 Post(s)
Liked: 271
Originally Posted by ahartig View Post
Quality for me is excellent. Very impressed all around.
I think it defaults to the highest resolution possible. I don't have a problem with that.
I'm also under the impression, if your internet speed cannot handle higher resolutions, the quality is automatically adjusted down.
Oh and besides the above comment, I have to say the Youtube HD videos look really good. And, I know they can look a LOT better when they fix the black issue!
Can you guys tell me how this looks to you through the 360's youtube:
It looks pretty bad when I do it through the 360. Like it's SD or something. Could you point me to some sources that you watch that you know for a fact should be HD and look good?
AT HAMMOND ROBOTICS WE'RE BRINGING THE FUTURE ... HOME
PROTOCOL 3: PROTECT THE PILOT
totalownership is offline
Old 12-22-2011, 06:42 AM
UHD Addict
aaronwt's Avatar
Liked: 3123
But the Zune video is actually1080P isn't it? It's just the VUDU VOD that's limited to 720P right now(and Netflix)?
Old 12-22-2011, 02:39 PM
Liked: 1429
Yes, the Zune video is 1080p and bandwidth testing that I've run showed a 10 Mbps average for 10 minutes of Zune 1080p. My post was to point out that the lack of 1080p VUDU is not due to an inability of the Xbox to handle it (there are even a small handful of 360 game titles which do 1080p, though for games it's a waste of graphics processing power). My theory is that Microsoft is artificially limiting other video sources in order to make Zune video the only source of 1080p.
Old 12-22-2011, 04:16 PM
Quoted: 345 Post(s)
Liked: 658
Except that now ALL video sources passed through the renderer seem to be going through a 720p framebuffer... so even if you're playing a 1080p file, odds are that it's being downscaled, even for Zune. You can't even play a 1080p file locally (in any format) without it downscaling now. That's part of the bug with the video rendering on the new dashboard, so hopefully they'll fix the black level problem and that at the same time.
Old 12-22-2011, 06:32 PM
UHD Addict
aaronwt's Avatar
Liked: 3123
Really!! Even 1080P content from Zune is being downscaled to 720P? And then upscaled again to 1080P for output? How the heck did they let a bug like that through?
Old 12-22-2011, 06:36 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Thats bananas.
bd2003 is offline
Old 12-22-2011, 07:06 PM
betterdan's Avatar
What kind of evidence do you have of it downscaling 1080P video to 720P? If it doesn't look as good to you ok but that doesn't mean that it is doing what is implied.
I definately notice the black level bug but I don't see any resolution problem myself.
Old 12-22-2011, 07:29 PM
mikepaul's Avatar
Quoted: 179 Post(s)
I wonder why they got rid of Native display mode. I wouldn't have thought it was a lot of code to not modify the video...
LIVE: mikepaul
Evil intentionally does harm to innocent beings. Good will occasionally do harm to innocent beings, but it's not intentional. Try not to be Evil. Strive to be Good...
mikepaul is offline
Old 12-23-2011, 01:50 PM
Thebarnman's Avatar
Quoted: 14 Post(s)
I don't have the source, however it is listed somwhere withing these Xbox threads...an article about the black level problem recently published...they also talk about the problems the Xbox 360 has with 1080 output (not being true 1080 resolution.)
Movies must be OAR, sports and movies must also have 5.1 audio, No EE or NO SALE!
Thebarnman is offline
Xbox 360 250gb Console With Kinect
