Xbox display resolution question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 12-13-2011, 04:57 PM - Thread Starter
Oliver Dubin's Avatar
Quoted: 14 Post(s)
If I have a 50 inch 9UK Panasonic plasma should I connect my 360 to it via VGA or HDMI? Is there a way to achieve 1:1 pixel mapping? I've tried researching it myself but everything is getting me confused a little bit. Anything would help, Thanks
Oliver Dubin is offline
post #2 of 19 Old 12-13-2011, 07:27 PM
ogbuehi's Avatar
HDMI. Panasonic's are notorious for not accepting 1080p via VGA.
ogbuehi is offline
post #3 of 19 Old 12-13-2011, 08:06 PM - Thread Starter
Quoted: 14 Post(s)
But my TV doesn't do 1080p. Only 720p
post #4 of 19 Old 12-13-2011, 08:07 PM - Thread Starter
Quoted: 14 Post(s)
Forgot to mention that if using VGA then I would be setting it at 1360x768. HDMI would be 720p
post #5 of 19 Old 12-13-2011, 10:53 PM
Ph8te's Avatar
Quoted: 4544 Post(s)
Liked: 3976
My vote is for HDMI as well. That way when and if you get a new TV you wont need to buy a new cable. Usually the only time you would use VGA is.when HDMI is unavailable.
Ph8te is offline
post #6 of 19 Old 12-14-2011, 02:16 AM
darklordjames's Avatar
Liked: 94
"Usually the only time you would use VGA is.when HDMI is unavailable."
Gah! Oh god no!
On a lot of displays VGA does two things. One, it is sometimes the only way to get 1:1 pixel mapping, especially at weird resolutions like the not-720p "720p" of 768p displays. Second, it tends to turn off a hell of a lot of processing, resulting is quicker response times and an image that is truer to what the original rendered image represented.
Both of these cases are not effected in the slightest by the presence of HDMI. Please stop spreading this disinformation around.
"If I have a 50 inch 9UK Panasonic plasma should I connect my 360 to it via VGA or HDMI?"
Head over to the plasma section and find the thread regarding your panel. Ask about 1:1 mapping based on input options.
To point you in the right direction though: Does HDMI on your display support 1080p? 1080p downscaled to 768p is preferable to 720p scaled up to 768p in almost every case. If your HDMI port supports 1080p, then set the 360 to 1080p and forget about it. If you can though, try out VGA. If you can get the Panasonic to accept 1360x768 over VGA, it is probably your best possible option in terms of image quality. A 360 VGA cable is like $7 on Monoprice.
darklordjames is offline
post #7 of 19 Old 12-14-2011, 05:05 AM
Ph8te's Avatar
Liked: 3976
Gah! Oh god no!
Gahhh ohhh no if you even bothered to read a few posts it would be obvious that the OP can't do 1080p (per their response)......Thanks for the "education" that I already had. Not sure why usually turns into always for some people. Ehhh go figure....
Ph8te is offline
post #8 of 19 Old 12-14-2011, 07:46 AM
Slordak's Avatar
On a lot of displays VGA does two things. One, it is sometimes the only way to get 1:1 pixel mapping, especially at weird resolutions like the not-720p "720p" of 768p displays. [...]
Is it really even possible to get 1:1 pixel mapping on these pseudo-720p displays when showing 1280x720 (16x9) content? Since they don't actually have this number of pixels, it seems like this would be impossible, but I confess I don't know that much about such displays.
Slordak is offline
post #9 of 19 Old 12-14-2011, 07:51 AM
257Tony's Avatar
Well, there are quite a few games that don't run at 720p native, (CoD, halo 3, etc) so you can avoid double scaling by going with VGA.
My opinion is that especially if you have a 768p display, nothing beats VGA. I would find an official MS VGA cable though, the monoprice ones are hit and miss quality wise.
257Tony is offline
post #10 of 19 Old 12-14-2011, 08:01 AM
sigteacher's Avatar
There is a way to achieve 1:1 pixel mapping with your PC and the right video card. Check out this link:
http://www.avsforum.com/avs-vb/showthread.php?t=733641
It's a little outdated, but this guy really pushed the limits of the 9uk panel with some amazing results!
sigteacher is offline
post #11 of 19 Old 12-14-2011, 10:56 AM
ogbuehi's Avatar
That works great for PC's (I've done this many times for different displays with my laptop), but doesn't really do the OP much good if the intent is to utilize a 360 as the video source. Otherwise DVDo iScan would be the next option albeit not necessarily a cheap one.
ogbuehi is offline
post #12 of 19 Old 12-14-2011, 03:01 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Pixel mapping can also be done with the 360 using proper patterns but this would require using VGA and a display that has timing adjustments.
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #13 of 19 Old 12-14-2011, 03:36 PM
Liked: 94
"Is it really even possible to get 1:1 pixel mapping on these pseudo-720p displays when showing 1280x720 (16x9) content?"
Not really. But it also isn't really possible on a 1080p panel either. The 360 does a really good, quick job of scaling though, so if at all possible it is best to have the 360 scale to an exact resolution that your display supports, to avoid any double-scaling, or dog slow display-side scaling. Hence, 768p VGA is the preferred option for 768p displays. In example, my first plasma was 1024x768 42". 360 VGA spit out at 1024x768 16:9 was bloody fantastic and allowed for 1:1 mapping. 720p over component or HDMI was visually inferior in a fairly obvious way, and had forced overscan.
post #14 of 19 Old 12-14-2011, 04:04 PM
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
Question - does piping my hdmi through my receiver introduce tangible lag with regards to screen response? I'm wondering because come Christmas I'll have my Mixamp 5.8 installed so I really don't need my Xbox going through my receiver.
Gaming hard from October thru April.
Samsung 60KS8000
Xbox One S
PS4 Pro
Astro A50s (2nd Gen)
s1njin is offline
post #15 of 19 Old 12-15-2011, 02:15 AM - Thread Starter
Quoted: 14 Post(s)
So I can set my xbox on my TV via VGA for 1360x768 and my displays native resolution is 1366x768. Is this better then using HDMI and setting it at 720P?
post #16 of 19 Old 12-15-2011, 03:22 AM
Liked: 94
Quite probably, yes.
post #17 of 19 Old 12-15-2011, 03:50 AM
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
Yes to which one of us?
Samsung 60KS8000
Xbox One S
PS4 Pro
s1njin is offline
post #18 of 19 Old 12-15-2011, 03:54 AM
Liked: 94
"Is this better then using HDMI and setting it at 720P?"
"does piping my hdmi through my receiver introduce tangible lag with regards to screen response?"
Depends on the receiver, but there should be no additional lag unless your receiver adds on some sort of on-screen display overlay, or is set to do some scaling.
post #19 of 19 Old 12-15-2011, 05:57 AM
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
Thanks much DLJ.
Samsung 60KS8000
Xbox One S
PS4 Pro
s1njin is offline
Reply Xbox Area
