rearanging apps - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-23-2011, 07:35 PM - Thread Starter
cincy51's Avatar
In the my apps section is there any way to move or rearange the apps so the ones you use the most can moved toward the front of the list. Thanks Karl
cincy51 is offline
post #2 of 3 Old 12-23-2011, 08:31 PM
mboojigga's Avatar
Quoted: 606 Post(s)
Liked: 835
No you cannot move apps. Under Home on the dashboard you have a quickplay under the disc tray that gets you to all your previous used apps. This was the case in the previous dashboard but much better overall on this one.
The 5.0 is here
mboojigga is online now
post #3 of 3 Old 12-24-2011, 02:07 AM
darklordjames's Avatar
Liked: 94
That's what Quick Launch automatically does for you already.
darklordjames is offline
Reply Xbox Area
