Call of Duty: Black Ops 2 - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 4672 Old 09-12-2012, 06:31 PM
rightintel's Avatar
Quoted: 657 Post(s)
Liked: 232
Originally Posted by JukeBox360 View Post
Nothing in the COD series is anything close to a "legitimate tactic." It all preferences. Nothing more. And why wouldn't they try to change things up? If people wanted to play the same guy. Why bother making a new one to begin with?
Well, by that logic you should be able to snipe w/ the SMG's then, right? Is it a PREFERENCE not to snipe w/ short range weapons? More like a factual reality within the scheme of the game. Why would they limit a short range weapon's ability to kill at long range w/ one shot(unless you get a one in a million shot)? Because it's NOT a sniper rifle, that's why. Same should go for quick-scoping in CQ w/ a sniper rifle. Otherwise, the give and take of a weapon's pros/cons/advantage/disadvantage system breaks down. Sure, it's a game, so it's ultimately not realistic anyhow. However, for shooters to "work", there should be some baseline expectations in regards to realism. The expectation that someone shouldn't be in CQ w/ a sniper rifle(or 1 shot killing at extended range w/ SMG's, etc.) is a completely reasonable one. It's not a condemnation of the game in it's entirety by any means, but a valid critique/improvement they could make.
Xbox Live: General PATT0N
rightintel is offline
post #632 of 4672 Old 09-12-2012, 06:40 PM
JukeBox360's Avatar
Liked: 53
lol, Agree with me or not. COD is far from the same game that it was before. I for one wish for a balance of COD 4. With the implementation of black ops. Points for unlocking things was just awesome. NON stacked killstreaks. COD 4 game play as just almost perfect. Sniping ironically was better in 4 then any other cod I've played.
JukeBox360 is offline
post #633 of 4672 Old 09-12-2012, 10:03 PM
sage11x's Avatar
Quoted: 1070 Post(s)
Liked: 1041
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #634 of 4672 Old 09-13-2012, 09:54 AM
Myrtledog's Avatar
Quoted: 20 Post(s)
Liked: 115
EuroGamer is at the end of this month so between that and the TGS, we should get alot more info in the next couple of weeks.
Myrtledog is offline
post #635 of 4672 Old 09-13-2012, 09:56 AM
Myrtledog's Avatar
Quoted: 20 Post(s)
Liked: 115
Will Zombies have ranking or challenge icons?
post #636 of 4672 Old 09-13-2012, 11:30 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
Zombie....prestige?
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #637 of 4672 Old 09-13-2012, 06:53 PM
rightintel's Avatar
Quoted: 657 Post(s)
Liked: 232
post #638 of 4672 Old 09-13-2012, 07:47 PM
JukeBox360's Avatar
Liked: 53
^^^^ It's sadly true. Love the pic.
post #639 of 4672 Old 09-13-2012, 08:20 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
If they really are making it so you need to use an attachment to get iron sights in order to quickscope, then I'm cool with that. If you have to give up your long range capabilities to shoot people in the face point blank, it's a fair trade. Quickscoping was cheap cause you could have the best of both worlds.
bd2003 is offline
post #640 of 4672 Old 09-14-2012, 07:09 AM
coyote_5's Avatar
Liked: 144
Not really.
XBOX Live: Ell Dudereno
coyote_5 is offline
post #641 of 4672 Old 09-14-2012, 07:20 AM
Rage Guy's Avatar
Every time I try to play, I seem to have connection issues.
Modern warfare games seem to be the worst.
Comcast says there is nothing wrong with my connection.
No, I am not connected wirelessly either.
All of my speedtest.net results seem ok.
Next time I run a test I will post the results.
Check out my ping times -
23ms - is that bad?
Perhaps I need a new router, I guess I could pick one up from newegg.com wink.gif
Rage Guy is offline
post #642 of 4672 Old 09-14-2012, 07:57 AM
bbexperience's Avatar
Liked: 53
It's even more retarded that you can put an ACOG, much less iron sights, on a sniper rifle. So, no, using iron sights isn't going to make it better. Worse, if anything.
Read. Think. Post. In that order, preferably
"If the Playstation and Xbox are like the Bloods and the Crips, then the Wii is whatever gang Sha Na Na was in" - Christian Finnegan
bbexperience is offline
post #643 of 4672 Old 09-14-2012, 08:00 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
What's the big deal though? It'll still be way harder to use in CQB than a shotgun.
bd2003 is offline
post #644 of 4672 Old 09-14-2012, 08:04 AM
Liked: 53
We'll see I suppose but I doubt it. People use the MK14, M16, Type 95, and sniper rifles with ACOG in CQ in MW3. It seems like exchanging an ACOG for an iron sight will only make it worse. Talk about best of both worlds...it's not like you need a scope to see across a CoD map as it is. You can have an iron sight on a sniper rifle and still snipe at least as effectively. Hopefully they're smart enough to at least gimp the long range accuracy if you use an iron sight.
post #645 of 4672 Old 09-14-2012, 08:33 AM
JukeBox360's Avatar
Liked: 53
Sounds like they are using some of the lame BF3 ideas. Iron sights on a sniper is just flat out dumb. But I guess it's better then nothing.
post #646 of 4672 Old 09-14-2012, 08:51 AM
coyote_5's Avatar
Liked: 144
You shut your whore mouth!!
coyote_5 is offline
post #647 of 4672 Old 09-14-2012, 08:54 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
Well with any gun when you're using iron sights vs an acog or sniper scope, your aim assist range is reduced, so it's much harder to get on target at range, especially if you use high sensitivity. Plus the iron sights are more obstructive. ACOG is still an option but it sights in slower. As long as they don't let you use the quickdraw attachment, it seems balanced.
I don't think it'll be that popular though. They're basically the bolt actions from world at war, which almost no one used.
bd2003 is offline
post #648 of 4672 Old 09-14-2012, 10:06 AM
Rage Guy's Avatar
LOL! Reminds me of a quote from Blazing Saddles.... hmmm
Rage Guy is offline
post #649 of 4672 Old 09-14-2012, 11:06 AM
JukeBox360's Avatar
Liked: 53
Clearly you like the idea of Iron Sights on a sniper rifle.... It isn't a smart idea.
post #650 of 4672 Old 09-14-2012, 11:55 AM
bucwylde23's Avatar
Liked: 68
Clearly he likes bf3... clearly he just isn't smart.. at all.
Xbox Live/PSN: bucwylde23
Daekwan: What makes a grown man want to be a troll like this?
coyote_5: You know who's cool and doesn't know it? Bucwylde. Jus' sayin.
bucwylde23 is offline
post #651 of 4672 Old 09-14-2012, 12:30 PM
coyote_5's Avatar
Liked: 144
Clearly you didn't understand the content of my post. It was a smart post; witty, concise, 10 out of 10 - would read again :thumbsup:
coyote_5 is offline
post #652 of 4672 Old 09-14-2012, 01:12 PM
Rage Guy's Avatar
Clearly, this has nothing to do with Jessica Christmas!
Rage Guy is offline
post #653 of 4672 Old 09-14-2012, 02:12 PM
JukeBox360's Avatar
Liked: 53
Who is Jessica Christmas?
post #654 of 4672 Old 09-14-2012, 02:29 PM
bucwylde23's Avatar
Liked: 68
Not sure if serious?? You trying to troll us or something?
post #655 of 4672 Old 09-14-2012, 03:08 PM
JukeBox360's Avatar
Liked: 53
No. I was dead serious. That someone everyone should know?
post #656 of 4672 Old 09-14-2012, 05:32 PM
Myrtledog's Avatar
Quoted: 20 Post(s)
Liked: 115
post #657 of 4672 Old 09-15-2012, 08:41 AM
coyote_5's Avatar
Liked: 144
Jessica Christmas dude.
coyote_5 is offline
post #658 of 4672 Old 09-15-2012, 10:21 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
If you Prestige and unlock a gun, you'll pick up at the weapon level where you left off.
Nice!
bd2003 is offline
post #659 of 4672 Old 09-16-2012, 04:53 AM
Myrtledog's Avatar
Quoted: 20 Post(s)
Liked: 115
Yep. Definitely eases the pain of prestiging a little bit.
David Vonderhaar ‏@DavidVonderhaar
Just got this bug from QA. "Weapon levels are given after unlocking a gun that was leveled up on a past level progression." +
That's what we call NAB. Not a bug. If you Prestige and unlock the gun, you'll pick up right where you left off. :P
post #660 of 4672 Old 09-17-2012, 07:46 AM
cubdenno's Avatar
Quoted: 72 Post(s)
Liked: 93
Looks like they are giving a reason to prestige. Keep gun levels, limit unlocking all items during a single prestige. Requiring prolly all prestiges to unlock everything?
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
Reply Xbox Area
Call Of Duty Black Ops 2 , Call Of Duty Black Ops Ii
