Doom 3 is coming to 360 in a remastered form with it's expansion and some cut levels. It also looks to be integrating an on-armor flashlight, which I'm not so sure about. I very much hope that the original "flashlight or gun" gameplay remains an option. Most PC players of the original game whined that you didn't always have a flashlight, then they used the duct-tape mod, then they complained that the game wasn't very good.
Yeah, that tends to happen when you take away the primary source of tension in the game, which was the primary point of Doom 3. That's like modding out the free-roaming exploration from Fallout 3, then complaining that it's not a very good linear experience.
In its original, afraid of the dark form, Doom 3 was brilliantly executed and quite the technical marvel. We owe a lot of today's rendering technique to what Doom 3 pioneered. Read a copy of Making Doom 3 if you want a pretty good inside view of how that engine was designed.
Finished it on the PC as well as the Xbox1. I guess it's good for people that have good memories of it.
I don't have good memories of it. The graphics were great but the maps were so cramped, the pacing was so slow, and it was such a dark (lighting, not mood) game. And just when you think the game will finally get good, it just kind of ends. Even playing it in co-op didn't help it, we ended up bumping into each other in the tight quarters.
Oh! I forgot about the 3D! Hopefully it stays up at 60fps. Being Carmack, there is a very good chance it will meet that target. I like 3D, and is a feature I made sure to get on my 64" plasma, but it sucks at 30fps. 60fps 2D feels better than 30fps 3D, but 60 fps 3D is great in practice. Too bad HDMI doesn't support 1080p/60 for 3D and caps out at 1080p/30.
actually, the PC version was illegal and the Xbox1 version was bought used via Ebay when people had moved onto the 360. I played the PC version single player. Played the Xbox1 version co-op. My friend and I were dying to play co-op system link games over the Internet and Doom3 was one of the few available.
you don't understand. I really really wanted to like Doom3. I loved Doom 1 and 2. Loved Castle Wolfenstein. Loved Quake 1&2.
Originally Posted by darklordjames /forum/post/0
"It's so terrible I bought and played it twice!"
"Seems a given it'll be 60fps, but I'll be super impressed if they can maintain that in 3D, even at 720p."
Shouldn't be too difficult, though it would likely be 600p/640p. Halo and COD both render 60fps, and the primary reason they use the lower resolution is so they can fit two frames in to the 10mb edram for merging to render. Essentially they already run 120fps.
"Even though 1080p/60/3D is technically impossible on current HDMI, I seriously doubt any game will pull that off, even next gen."
It's not that hard. Really though, if they can do 1920x1080/60, dropping to 960x1080/60 to gain 3D is a fair tradeoff. Humans are far more sensitive to vertical resolution than horizontal, so the largest noticeable difference will be slightly more aliasing on the small percentage of high contrast lines at almost-vertical lines. FXAA can handle those quite well with minimal performance impact.
Hoping for 1080p/60 out of the next consoles is a fantasy though. 1080p/30 is going to be the standard, and the Wii U is quite likely to only do 720p/30 as the norm.
Other than perhaps being 3D compatible, I doubt they'll be getting anything except a straight port.
They were already part of Doom 3 for many people. The Collector's Edition of Doom 3 included them and it was a standard part of the package for Resurrection of Evil. And they also had some issues that aren't present on the XBLA releases. I recall some significant problems with background graphics (I want to say every level used the same background, but it's been a while).
So hopefully they'll be including the XBLA versions instead of simply porting over the flawed versions included in the original package (Which also lacked online play).
They were already part of Doom 3 for many people. The Collector's Edition of Doom 3 included them and it was a standard part of the package for Resurrection of Evil. And they also had some issues that aren't present on the XBLA releases. I recall some significant problems with background graphics (I want to say every level used the same background, but it's been a while)..
Yeah, all I'm really wondering is if they're going to attempt adding 3D to the first two. I seriously doubt it, I just can't imagine what that would look like...which is why I'm so curious about it.
We weren't talking about COD in 3D. We were talking about 720p/120 rendering. You seem to have missed the point and gotten sidetracked on "COD! COD! COD!".
The point was that there are 60fps games that already render two actual frames for merging to a single output. 60fps x 2 passes = 120fps. 60fps x 2 eyes = 120fps. That is the important comparison. How, which, or even if COD renders to 3D is absolutely irrelevant to the subject.
One item making the interwebs rounds this week was the scandalous revelation that Halo 3 runs at “640p” which isn’t even technically a resolution. However, the interweb detectives did notice that Halo 3’s vertical resolution, when captured from a frame buffer, is indeed 640 pixels. So what gives? Did we short change you 80 pixels?
Naturally it’s more complicated than that. In fact, you could argue we gave you 1280 pixels of vertical resolution, since Halo 3 uses not one, but two frame buffers – both of which render at 1152x640 pixels. The reason we chose this slightly unorthodox resolution and this very complex use of two buffers is simple enough to see – lighting. We wanted to preserve as much dynamic range as possible – so we use one for the high dynamic range and one for the low dynamic range values. Both are combined to create the finished on screen image.
This ability to display a full range of HDR, combined with our advanced lighting, material and postprocessing engine, gives our scenes, large and small, a compelling, convincing and ultimately “real” feeling, and at a steady and smooth frame rate, which in the end was far more important to us than the ability to display a few extra pixels. Making this decision simpler still is the fact that the 360 scales the
“almost-720p” image effortlessly all the way up to 1080p if you so desire.
In fact, if you do a comparison shot between the native 1152x640 image and the scaled 1280x720, it’s practically impossible to discern the difference. We would ignore it entirely were it not for the internet’s propensity for drama where none exists. In fact the reason we haven’t mentioned this before in weekly updates, is the simple fact that it would have distracted conversation away from more important aspects of the game, and given tinfoil hats some new gristle to chew on as they catalogued their toenail clippings."
But now that I've dug it up, it looks like I'm misremembering Halo 3 as a 60fps game. It held a steady 30fps.
The best I can put up instead is that Geometry Wars 2 is 1080p/60. Similar math though. A 1080p frame is roughly twice the size of a 720p frame, or the same size as a 1280x1440 frame for 3D. 1080p x 60 = 720p x 2 x 60. At 60fps, GW2 has already proven that we can spit 720p/60 3D out of the 360 in terms of bandwidth. Sure, it's a simpler game to an extent, but we are talking about Doom 3, which is old.
All of this is merely academic though. By no means do I expect them to pull off 720p/60 3D. I'm just saying that it physically can be done on the hardware and we have an example that says it can be.
That's hardly the same thing as running at a full 120fps.
Sure the 360 technically has the bandwidth, but there's way more to it than that. Proper stereoscopy requires two separate views, geometry has to be recalculated for each eye. So it's not just a matter of needing twice the fillrate/bandwidth...it's more complex compared to a resolution shift.
That's another reason why I brought up blops - dropping to 3D brought with it a frame rate AND resolution drop - and most other games have been the same way, to varying extents. Even the ICO/SOTC remake had poorer performance in 3D, not even being able to maintain 30fps/720p. And it's a PS2 remake too!
I could imagine it being a locked 60fps in 2D, but performance fluctuating quite a bit in 3D. Doom 3 is an old game for sure...but it seems like its getting quite a bit of retouching as well.
"Proper stereoscopy requires two separate views, geometry has to be recalculated for each eye. So it's not just a matter of needing twice the fillrate/bandwidth...it's more complex compared to a resolution shift. "
Geometry and shaders have to be calculated for each pixel on the screen. Whether I'm running 640x480 for 8 eyes, or 1920x1080 for one eye, workload is very much the same. Graphics subsystems don't care about how many viewpoints there are. They care about how many dots we are trying to make. This holds true on both the hardware and software half of the equation.
Doom 3 got a lot of people dumping on it, being a simple, monster-closet 1-to-3-enemies-at-a-time shooter. But it was an excellent example of the old-school simple shooter in a modern (at the time) engine - great atmosphere, tension, weapons, and enemies.
And I loved the gun-or-flashlight mechanic, which really adds to the panic and blind-firing in the dark.
I know the haters will come back to dump on this game, but whatever - top 10 of all-time game for me.
That's funny, I don't remember a single strong opinion on this game one way or the other! I remember when it came out (I was still a PC guy at the time) and reading a few reviews and a few of my friends played it. No one hated it-- but then no one loved it. I remember asking a buddy of mine if it was worthy of some time as I was trying to clear a backlog of games, his response: "meh".
This writer talks about the game as if it was a long lost gem or a misunderstood classic... But then rockstar developers tend to have that affect on games even if the final product is just 'ok'. See also: Rage, L4D 2, LA Noire.
The only anger over L4D2 was that it was coming out only a year after the first. The first was still extremely popular, so the effect was going to be to split the player base.
As a product though? L4D2 is fantastic. It also shipped with 4 or 5 campaigns, then they added another 3 campaigns for free. It sees bi-weekly mutations to its multiplayer giving people a reason to come back to it repeatedly. Then of course they ported the entire first game over to the second game. For free.
Doom 3 though? People whined endlessly about the flashlight mechanic. They completely missed the point of the game in doing so. Doom 3 was executed extremely well. The public was just a little too dumb to see that.
See also: Mass Effect 3. Brilliant conclusion to the series. BioWare just overestimated their audience's intelligence by a long shot.
The lesson in both cases is: If you give your audience the chance at proving themselves grown up enough to think, and they will disappoint you and hate you for it. Follow the COD model, keep things as dumb as can be, and you'll do just fine.
I had actually dropped Doom 3: Resurrection of Evil into my 360 a few days ago; the old Xbox game still held up pretty well and I was wondering what a full on remastered version would look like. The gameplay felt a little restrictive compared to newer games and the flashlight or weapon model did quickly get a little tiresome after repeated playthrus but I'll still probably end up buying this game just because I've always been a big Doom fan. The fact that it will support 3D is a nice little bonus as well and I wouldn't be surprised if the reason we'll be getting a constant flashlight option is because of the 3D support.
I'm still not clear on a couple of things though:
- I seem to recall that the Xbox version of Doom 3 had some simplified versions of some levels (the outdoor ones on Mar for example), mainly because of memory restrictions. I wonder if we'll be getting a port of the Xbox version or the slightly more expansive PC version.
- Will Doom and Doom 2 be remastered in any way or will they still be the old pixelated wonders from the bygone 486 days? Even giving them a GLQuake coating would be a nice addition.
One of the big innovations of Doom 3 was to use extremely high polygon source models, use a much lower polygon model in game, then use a normal map to give the impression of the higher count model on the lower count asset. I hope that in this version they go back to the original models and source higher quality in game models and higher resolution normal maps than what we see in the PC version. They may not though, as I'd guess the limited ram on a 360 and especially the PS3 would restrict model resolution.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
