Black screen when starting amazon prime and hulu plus... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-02-2012, 11:10 AM - Thread Starter
jasonstiller's Avatar
None else having this issue? Installed apps and they don't work. Uninstalled and I get the same issue.
jasonstiller is offline
post #2 of 7 Old 06-02-2012, 12:13 PM
onlysublime's Avatar
Quoted: 768 Post(s)
Liked: 1203
maybe you have corrupted files in your system cache. time to do some housecleaning.
onlysublime is offline
post #3 of 7 Old 06-02-2012, 02:22 PM
darklordjames's Avatar
Liked: 94
That would also be a sign of HDCP failure. Hook directly up to the TV with a different HDMI cable and see what happens.
darklordjames is offline
post #4 of 7 Old 06-03-2012, 09:10 PM
JuiceRocket's Avatar
Quoted: 50 Post(s)
Liked: 41
I get a black screen when I select Netflix. It lasts roughly 60 seconds, and then Netflix comes up. For the longest time I thought the app was broken, turns out it just takes forever to load on my xbox. If you haven't tried to wait a full minute for one of the apps to load, give it a shot. Good luck!
JuiceRocket is offline
post #5 of 7 Old 06-03-2012, 09:14 PM
Quoted: 768 Post(s)
Liked: 1203
that's true. the amazon app takes a long time to load and it sits at a black screen for awhile.
i just assumed the guy tried waiting for awhile.
post #6 of 7 Old 06-09-2012, 10:36 AM - Thread Starter
Thanks juice, that was it ha ha. I can't believe it takes that long to start the app!
post #7 of 7 Old 06-12-2012, 03:40 PM
Quoted: 50 Post(s)
Liked: 41
No problem, happy to help. I don't get why it takes so long, they should really put a loading icon or something there.
-JR
Reply Xbox Area
