Xbox 360 not filling screen with Epson 5010 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-26-2012, 09:38 AM - Thread Starter
crakerhead's Avatar
Quoted: 13 Post(s)
Just finished setting up theater with 5010 and 110" screen. PS3 fills up the whole screen but the Xbox 360 is only 4:3. I changed the resolution on the Xbox to 1080p but nothing changed. Thoughts? Thanks.
crakerhead is offline
post #2 of 6 Old 06-26-2012, 10:07 AM
wlcohen's Avatar
can't remember if there is another setting in the xbox for widescreen or 4:3, spend some more time in the menu.
Plug the Xbox into the PS3 input on the projector or receiver, to find the culprit.
wlcohen is offline
post #3 of 6 Old 06-26-2012, 11:44 AM
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
XBOX is dependent upon source material. If you go into the menu (with the controller) while the movie/tv show is playing, and select the advanced options, you can cycle through native/ "fullscreen"/16:9, etc...
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
post #4 of 6 Old 06-26-2012, 12:20 PM - Thread Starter
crakerhead's Avatar
Quoted: 13 Post(s)
thanks, i'll try messing it with some more after work
post #5 of 6 Old 06-27-2012, 02:28 PM - Thread Starter
crakerhead's Avatar
Quoted: 13 Post(s)
started working, didn't change any settings
post #6 of 6 Old 06-27-2012, 05:23 PM
Hockeytown Fan's Avatar
That's weird lol... At least its working though. I'm using an Epson 3010 with the xbox in my living room. All I did was set it to output 1080p and starting gaming, it was smooth as butter. Maybe it was just some strange anomaly...
Help a Family in need, Show Them We Care! Like it on Facebook and tweet it!
http://igg.me/p/171832?a=874546
Hockeytown Fan is offline
Reply Xbox Area
