Xbox 360 slim hard drive problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-06-2012, 07:27 AM - Thread Starter
Stereoxbox's Avatar
Hi I want to determine the cause of the following problem, what happens is this, turn on the console, I can play normally but sometimes being in the game or interface partially frozen and hear the noise when the hard disk read and this noise does not stop at any moment, so I do a forced shutdown,
may be the disc because you hear the noise?
the cause may be bad sectors?
or may be the problem of internal connection of the console?
Stereoxbox is offline
post #2 of 3 Old 07-06-2012, 08:40 AM
Hksvr4's Avatar
Quoted: 29 Post(s)
Liked: 37
Try another game or turn on the xbox without a disc in it. Does it still make the noise?
Hksvr4 is offline
post #3 of 3 Old 07-06-2012, 10:15 AM - Thread Starter
Stereoxbox's Avatar
remove the hard drive, no sound is heard, the problem is hard drive or may be the problem of internal connection of the console? thanks
Reply Xbox Area
