Fallout 3 question - AVS Forum | Home Theater Discussions And Reviews
Old 07-30-2012, 05:26 PM - Thread Starter
mproper's Avatar
I know this is an old game, but I just got the game of the year edition through a Goozex trade.
The first disc installed fine, but when I try to install the second disc, I can't....when I press the X for 'more details' where it typically gives you the option to install, I get an error about the marketplace being unavailable...even though I know it's not.
Was wondering if someone else that might still have it around could check their copy? Not sure if I got a bum disc or if something else is up.
mproper is offline
Old 07-30-2012, 05:56 PM
darklordjames's Avatar
Liked: 94
What happens if you log off Live before installing?
darklordjames is offline
Old 07-30-2012, 06:02 PM
jsacevedo's Avatar
Quoted: 504 Post(s)
Liked: 203
Don't press X to go into the details, just press A to play the disc, but instead of going into the game a menu should pop up asking which DLCs you want to install. That's how it has worked for me on my other Game of the Year type releases. I hope this helps.
Xbox Live Gamertag: JShmoopy
PSN ID: JShmoopy
jsacevedo is offline
Old 07-30-2012, 06:37 PM
Liked: 94
Ah, missed that part. smile.gif Yup, Play the disc like normal. Then it should install your DLC packs as five separate packages, not a single disc image.
Old 07-30-2012, 06:59 PM - Thread Starter
mproper's Avatar
Ha...that was it. I feel stupid. All is well...
mproper is offline
