Connecting An xbox360 to a non-hdmi receiver and Dell U2412M monitor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-04-2012, 10:19 PM - Thread Starter
Avngl's Avatar
Hello guys.
I am planning to purchase a Xbox360 but first there is something that I require assistance with.
Monitor : Dell U2412M (DisplayPort, DVI-D, VGA)
HT Receiver: Niro Nakamichi two 6.1 (NO HDMI [Only S/PDIF / Optical])
As of the moment, My desktop is connected to my monitor via a DVI-D-to-HDMI adapter. This leaves the VGA slot and DisplayPort slot open. My Desktop has only 1 HDMI output (NO VGA / DVI-D) so I cannot substitute it.
Now I know I would have to get a HDMI Switch. However, there is another issue.
How do I connect the XBOX360 to my monitor via HDMI (Through the switch of course) and then the sound would be output via optical out to my receiver?
I found a device that might do it:
However, The HDMI is at the output and DVI is at the input. The description says it works for xbox360, PS3 etc.
Is this the one that I need or would i need a HDMI Input and DVI Output?
Asus Maximus IV Gene-Z/Gen3 | i5 2500K | Intel® HD Graphics 3000 | Asus Xonar DX 7.1
Avngl is offline
post #2 of 3 Old 08-05-2012, 02:06 AM
darklordjames's Avatar
Liked: 94
The normal 360 S that you'll find new in stores has optical out on the back of it. Optical to the receiver. HDMI from the 360 and PC to a cheap $20 auto-sensing HDMI switchbox. HDMI-to-DVI cable from switch to monitor.
No converter needed.
darklordjames is offline
post #3 of 3 Old 08-05-2012, 02:43 AM - Thread Starter
Avngl's Avatar
Got it.
Thank you very much. Will verify it when i get the xbox360 this thursday.
Avngl is offline
Reply Xbox Area
