Xbox 360 4 GB HDD? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-08-2012, 06:19 AM - Thread Starter
jake51's Avatar
Quoted: 106 Post(s)
Hi
Is the 4 GB HDD large enough for savegames?
If I buy this I have no intentions of downloading stuff
Jakob
jake51 is offline
post #2 of 4 Old 08-08-2012, 06:34 AM
wlcohen's Avatar
always go with the largest HD possible!
4 is fine for game saves but you will want to download all the free demos and they fill up the HD fast
+ if you buy any games on line you need the space
wlcohen is offline
post #3 of 4 Old 08-08-2012, 09:09 AM
rewdpost's Avatar
Quoted: 28 Post(s)
If you're not going to download anything else the simple answer is yes.
With the ability to use an inexpensive USB drive to extend your storage space too you can get a lot more mileage out of a 4GB system now than you used to for basic usage.
rewdpost is offline
post #4 of 4 Old 08-08-2012, 09:37 AM
onlysublime's Avatar
Quoted: 910 Post(s)
Liked: 1482
Heck, of my cloud saves, I've only used 350 MB and I have a ton of games! My old 360 only came with 512 MB of flash memory which I haven't even used (I use my 250GB HDD).
and just for clarity's sake, that 4 GB is flash memory. Not hard drive space. That's a distinction that many software will note.
onlysublime is online now
Reply Xbox Area
