RGB or yCB? - AVS Forum | Home Theater Discussions And Reviews
Old 11-06-2012, 01:43 PM - Thread Starter
Quoted: 303 Post(s)
Liked: 43
what do you guys use, which setting gives better PQ? i heared games are made in RGB so i have mine set to RGB and reference level to STANDARD,
lamonsasa is offline
Old 11-08-2012, 05:56 AM
PiratesCove's Avatar
Quoted: 82 Post(s)
Liked: 176
HDTV (Samsung): HDMI : Low and Xbox360: Standard / Source. (OK)
OR
HDTV (Samsung): HDMI : Normal and Xbox360: Standard, Intermediate or Expanded (-won't matter) / YCbCr709 . (Better)
OR
HDTV (Samsung): HDM I: Normal- Xbox360 with Reference Level: Expanded / HDMI Color Space: RGB . (Best)
PiratesCove is offline
Old 11-19-2012, 06:57 PM - Thread Starter
Quoted: 303 Post(s)
Liked: 43
Old 11-20-2012, 09:05 PM
OARevolution's Avatar
The optimal settings should be HDMI normal and reference level Expanded. That would give you a full RGB signal and levels. HDMI low and reference level standard will give you limited RGB signal and levels. Either will look fine as long as you have them set up properly. If you set it for a YcbCr color space you shouldn't be able to change your TV from normal to low because that is a video signal and RGB levels need not apply. (at least on my TV you can't)
OARevolution is offline
Old 11-21-2012, 04:50 PM
FattiesGoneWild's Avatar
Quoted: 42 Post(s)
Liked: 29
When you connect your console to a TV or monitor, the console uses default settings based on your TV and cable type. In some cases, you can change these settings to improve video quality. If you use an HDMI cable, the console automatically selects the best settings.
http://support.xbox.com/en-US/xbox-360/audio-video-setup-and-use/improve-video-quality#53c934f4bf074e8e8b3e65fe179ffaf3
Basically let the Xbox and tv do its thing. It matches best settings automatically. Mine defaulted to rgb. I am using hdmi on my LG 55" led tv.
FattiesGoneWild is offline
Old 12-10-2012, 07:48 AM
techfreak191's Avatar
Yes, RGB is generally suited best for games. YCbCr for movies.
So keep it on Auto. Ref. levels to expanded if your TV can handle it. If the greys and blacks look too dark (often referred to as a Black Crush), you can set it to Intermediate. If you still can't see detail in low contrast scenes, or there's excessive color bleeding in dark scenes, you'll need to set it to Normal.
techfreak191 is offline
Old 12-15-2012, 03:43 PM - Thread Starter
Quoted: 303 Post(s)
Liked: 43
why should i set the reference leve lto expanded or intermediate? i thought that standard is the correct setting to get the colors to look the way they should be..
Old 12-20-2012, 07:42 AM
^^ Expanded.. ONLY if your TV makes the greys and blacks look accurate. Most TVs don't. And you would be right when you say Standard is most likely the best setting.
I got mine set to Standard as well.
Cheers.
Old 12-22-2012, 10:18 AM - Thread Starter
Quoted: 303 Post(s)
Liked: 43
Cheers.
you have yours at rgb and standard as well?
Old 12-23-2012, 07:47 PM
Standard and Expanded should only apply in RGB color space.
Old 12-26-2012, 08:07 AM
suntu ieu's Avatar
YCbCr 709 and Expanded.
suntu ieu is offline
Old 12-27-2012, 09:05 PM
Old 12-27-2012, 09:52 PM
Dimethios's Avatar
This is how I have mine as well, is it incorrect?
Dimethios is offline
Old 12-28-2012, 06:04 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
It's a non-standard way of getting there, but probably looks fine if your display is flexible enough.
Games are native RGB/expanded. Video is native 709/standard.
HDTVs are built for 709/standard, monitors are built for RGB/expanded. Nowadays there is precious little difference between a TV and a monitor, and most HDTVs are flexible enough to support monitor specs.
So 709/expanded is a weird combination that isn't true to any source. But the video chip in the 360 can convert to whatever with little degradation, so it barely matters.
You could make a solid argument either way that RGB/expanded or 709/standard is "correct" for games on the 360.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
Old 12-28-2012, 07:11 AM
Yep, Standard works great. Games generally respond better to RGB, as that's the source. I've selected the Auto option. So it simply changes to YCbCr 709 for movies. Intermediate and Expanded are just too dark on my TV.
Old 12-28-2012, 11:14 AM
If you set your Xbox to YCbCr 709 I don't think the reference levels apply any more. All three settings (standard, intermediate, expanded) should look exacty the same in that scenario. Idk if the the Xbox is doing some kind of conversion or if it just defaults to the correct black level for YCbCr 709.
Old 12-29-2012, 12:02 AM
^^ it just uses the default values on this color setting. Reference levels only apply to RGB.
Old 12-29-2012, 10:30 PM
Precisely
Old 12-30-2012, 09:06 PM - Thread Starter
Quoted: 303 Post(s)
Liked: 43
so all in all u guys think that setting to ycbcr 709 is best for gaming even though games are produced in rgb?
Old 12-30-2012, 11:34 PM
No. Set it to auto or source.
