Headset Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-28-2012, 06:36 AM - Thread Starter
Skipdalou's Avatar
I know lots of you have headsets beyond what I would ever need or understand, so I thought I would make you all feel a bit dumber by asking you a question.
I bought my nephew the Turtle Beach X31 set a couple years back for $99.
http://www.newegg.com/Product/Product.aspx?Item=N82E16874502004
Needless to say, he has broken them and he needs a new set, but it seems to me they may be discontinued. So in looking in the similar price range, I found the DXL1 set:
http://www.newegg.com/Product/Product.aspx?Item=N82E16874502023
Would this be a sufficient equivalent to the X31's?
XBox Live: Mystaphyer / ConmansMom
Skipdalou is offline
post #2 of 2 Old 11-28-2012, 08:20 AM
bbexperience's Avatar
Liked: 53
The X31 was wireless so I'd say the newer equivalent would be the X32.
http://www.amazon.com/Turtle-Beach-Digital-Headset-Xbox-360/dp/B006W41X1S
Read. Think. Post. In that order, preferably
"If the Playstation and Xbox are like the Bloods and the Crips, then the Wii is whatever gang Sha Na Na was in" - Christian Finnegan
bbexperience is offline
Reply Xbox Area
