Question about 1360x768 resolution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-16-2012, 11:00 AM - Thread Starter
jtmatchett's Avatar
Is 1360x768 progressive scan or interlaced? I know its a PC resolution, but I'm not sure if progressive scan and interlace exist in the PC resolution realm. I was messing with settings on my 360 this morning and it suggested this as the optimal resolution. I had it set at 720p. Definitely a sharped picture as 1366x768 is my (720p) TV's native resolution, but experienced the color issues others had mentioned. I quickly fixed the color issue with a re-calibrating of that specific HDMI input.
Here are my settings:
Resolution: 1360x768
Color space: Source (supposed to switch between RGB and 790 based on the source)
Reference levels: Standard
This sound right for a calibrated 720p HDTV? I'm hoping 1360x768 is progressive scan or the equivalent.
Sorry if this a repeated subject, I'm new here. Any help would be greatly appreciated!
Jeff
jtmatchett is offline
post #2 of 3 Old 12-16-2012, 02:00 PM
darklordjames's Avatar
Liked: 94
It's progressive.
darklordjames is offline
post #3 of 3 Old 12-20-2012, 06:25 AM
techfreak191's Avatar
Yes, it IS progressive.
How have you calibrated your TV BTW?
techfreak191 is offline
Reply Xbox Area
