Can I use Skullcandy SLYR with Xbox 360? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-21-2012, 12:44 AM - Thread Starter
atlantic44's Avatar
I just got the SLYR gaming headset which is supposedly "universal"
It comes with a bunch of cables and vague instructions on how to setup with the Xbox, and there are a few things I don't understand.
The only setup instructions for the Xbox involves red/white component cables for sound(and of course I use HDMI) mad.gif
I should be able just to plug it right into the Xbox controller to get everything to work right?
Can someone help me do this?
atlantic44 is offline
post #2 of 6 Old 12-21-2012, 01:09 AM
onlysublime's Avatar
Quoted: 909 Post(s)
Liked: 1482
you need the audio adapter. like this one:
http://www.amazon.com/Audio-Cable-Adapter-XBOX-360-Slim/dp/B002P35JMO/ref=sr_1_1?ie=UTF8&qid=1356080789&sr=8-1&keywords=xbox+audio+adapter
to use this headset. use the HDMI for the video. use the audio adapter for the headset.
plug the mic into the controller for chat.
onlysublime is offline
post #3 of 6 Old 12-21-2012, 01:51 AM - Thread Starter
atlantic44's Avatar
The thing is I got the same headset for my brother also, and I had hoped to use them for co-op and such. If we do that, then the audio will be displayed for each person separately right?cool.gif
Would there be any reason why not to get the audio right from the controller?rolleyes.gif
post #4 of 6 Old 12-21-2012, 07:57 AM
Raven Crimson's Avatar
Quoted: 380 Post(s)
Liked: 426
I didn't even know you could get game audio from the controller.
In any case, the RCA method is gonna have a cleaner signal.
I'm fairly certain the console comes with the adapter... if not the composite cable adapter, the component one...
Mad Lust Envy
Raven Crimson is offline
post #5 of 6 Old 12-21-2012, 02:42 PM - Thread Starter
atlantic44's Avatar
I see allot of prople reporting a problem using the hdmi for video and component for audio method, where if you shut off your tv screen or switch inputs it shuts off the Xbox, apparently it has somthing to do with the wiring......
So your saying the Xbox should already come with the type of adapter that I need?
post #6 of 6 Old 12-22-2012, 11:50 AM
Dash525's Avatar
Quoted: 137 Post(s)
Liked: 97
I've never had a problem with my adapter I got from Monoprice. I have heard of people having issues with the adapters from Amazon. here is the link for the monoprice adapter. http://www.monoprice.com/products/product.asp?c_id=114&cp_id=11403&cs_id=1140302&p_id=7526&seq=1&format=2
I use this with my Skullcandy SLYR and it works great.
PSN ID : AVS Dash
Dash525 is offline
Reply Xbox Area
