Single Xbox Wireless Controller for both Xbox AND HTPC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-18-2013, 04:32 AM - Thread Starter
sandeepkor's Avatar
I have a single Xbox wireless receiver and I am planning on getting a Xbox Wireless receiver for the HTPC. I wanted to know if I can switch between the Xbox and HTPC receiver with minimum effort.
Would it involve only synchronizing the controller and the intended receiver every single time or is there some trick to avoid that as well?
Or would I need to get another controller?
sandeepkor is offline
post #2 of 4 Old 02-18-2013, 12:54 PM
darklordjames's Avatar
Liked: 94
You have to sync every time. Get a second controller of a different color.
darklordjames is offline
post #3 of 4 Old 02-19-2013, 04:42 AM - Thread Starter
sandeepkor's Avatar
Thanks darklord.. will do that!
post #4 of 4 Old 02-19-2013, 09:13 AM
number1laing's Avatar
Liked: 32
MS sells a package with a separate controller and a wireless receiver for PC. Just get that. It's much easier than re-synching every time.
number1laing is offline
Reply Xbox Area
