Rechargeable AA Brand? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-06-2013, 09:48 PM - Thread Starter
darklordjames's Avatar
Liked: 94
It'd gotten about five years out of my rechargeable AA low self discharge cells and its time to replace them. What are people using these days? Eneloops are out of the question as they are so well known that they are also massively counterfeited. Tenergy? Amazon? Good old Rayovacs? I'm looking for bang for dollar here.
Also, what smart charger are we using these days? I'd like something that sits on the outlet, holds four cells, and doesn't just dumbly trickle-charge for a set 8 hours.
darklordjames is offline
post #2 of 6 Old 03-06-2013, 11:48 PM
onlysublime's Avatar
Quoted: 771 Post(s)
Liked: 1206
still love Eneloops. just bought some recently again. fantastic.
the la crosse chargers are just as good as ever too.
onlysublime is online now
post #3 of 6 Old 03-07-2013, 08:51 AM
CrowSS's Avatar
I use Sony Cycle 2000 mAh AA's. Only $8 for 4 on Amazon.
Lacrosse BC-700 charger. Don't spend more than $30 on it.
I have 5 controllers, keyboard and mouse for PC's, etc. They work great, no sign of decaying in over 3 years.
Xbox GT: CROWSSLT1
CrowSS is offline
post #4 of 6 Old 03-07-2013, 10:00 AM
signmastr's Avatar
Quoted: 12 Post(s)
I've had good luck with this Nyco setup. Going on 3 years.
http://www.nyko.com/products/product-detail/?name=Charge+Base+S
signmastr is offline
post #5 of 6 Old 03-07-2013, 10:02 AM
bbexperience's Avatar
Liked: 53
I use both Eneloops and Powerex Imedion batteries and I've found both to be great. If you're looking for best value, the Amazon batteries are reviewed very well. For the charger, go with one of the La Crosse models or Powerex makes some good ones as well.
Read. Think. Post. In that order, preferably
"If the Playstation and Xbox are like the Bloods and the Crips, then the Wii is whatever gang Sha Na Na was in" - Christian Finnegan
bbexperience is offline
post #6 of 6 Old 03-24-2013, 07:17 AM
Nickff's Avatar
Quoted: 279 Post(s)
Liked: 170
I use these and haven't looked back. They last way longer than the crappy play-and-charge kit.
http://www.amazon.com/eneloop-Capacity-Pre-Charged-Rechargeable-Batteries/dp/B0058GZWXQ/ref=sr_1_1?ie=UTF8&qid=1364130966&sr=8-1&keywords=eneloop+xx
Mathematics is the reason for the season.
Nickff is offline
Reply Xbox Area
