XBOX360 Connects to the Wrong Network - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-01-2013, 11:13 PM - Thread Starter
grigorianvlad's Avatar
Quoted: 165 Post(s)
Liked: 623
Hi. Please accept my apologies if this question has been answered elsewhere. I have 2 routers chain connected. Here is how it looks:
Comcast cable internet box -> Belkin wireless router (192.168.2.1) -> Linksys wireless router (192.168.1.1) . None of the hardware I am using is using wireless, just laptops and Ipads.
Here is the problem. Xbox360 and PC are both connected to Linksys (192.168.1.1). The PC shows the correct connection (192.168.1.107), but XBOX360 for some reason shows IP of the Belkin (192.168.2.5), which is Linksys is connected to, but not the XBOX itself, not directly. So, XBOX doesnt talk to the PC, but it is connected to the Internet (I can download stuff).
How do I make them talk to each other? I need to use Windows Media Player from XBOX using media on the PC.
How is it possible that both devices connected to the same router Linksys but use different IPs.
Thanks a lot.
DAC: Wyred4Sound DAC1LE || Processor: Marantz AV8801 11.2 Ch || Power Amps: Audio Research VS110 (100W tube) || Emotiva XPR-2 (600W), Emotiva XPA-5 Gen 2 & UPA-500 (200W/80W) || L/R Speakers: Eminent LFT-8b , Magnepan 2.7, Center : Polk LSiM-704C, Sur: Polk LSiM-703 || Sub 1: Rythmik F25 (800W). Sub 2: Sunfire True Signature TS-EQ12 (2,700W) || Cables: MIT terminator 2 Biwire, 4, Exp; Cardas Crosslink || Power: PS Audio Premier || HP: HifiMan HE560
grigorianvlad is offline
post #2 of 8 Old 05-02-2013, 06:51 AM
garciab's Avatar
Quoted: 151 Post(s)
Liked: 69
Not a good idea to have two routers. Turn off DHCP on the Linksys, and simply use it as a switch. That should simplify your life a bunch. smile.gif
grigorianvlad likes this.
bg
garciab is online now
post #3 of 8 Old 05-02-2013, 08:00 AM
bucwylde23's Avatar
Liked: 68
I have no idea why you would need to set up 2 routers like that, but have you tried just setting a static IP in the xbox?
Xbox Live/PSN: bucwylde23
Daekwan: What makes a grown man want to be a troll like this?
coyote_5: You know who's cool and doesn't know it? Bucwylde. Jus' sayin.
bucwylde23 is offline
post #4 of 8 Old 05-02-2013, 08:01 AM
Daekwan's Avatar
Liked: 335
THIS.
x100.
You only need one router. Any router added to a home network to extend it.. should be bridged and not assigning IPs. Turn off DHCP and 2nd router will essentially become a switch (think of it as an extension cord for your network). This will solve your problem.
Xbox Live & PSN gamertag- Daekwan
www.facebook.com/Daekwan
Daekwan is offline
post #5 of 8 Old 05-02-2013, 08:32 AM - Thread Starter
Quoted: 165 Post(s)
Liked: 623
Originally Posted by Daekwan View Post
THIS.
x100.
Thanks, guys. Idea this simple never crossed my mind. I will check docs I find out how to turn off DHCP.
BTW setting a static IP on XBOX360 made it inaccessible (cant go on the network), so I had to switch it back to DHCP.
post #6 of 8 Old 05-02-2013, 08:42 AM - Thread Starter
Quoted: 165 Post(s)
Liked: 623
Still, the main question is unanswered (even though I am grateful I got a resolution, thanks!). How in the world Xbox which is connected by wire to Linksys retains Belkin's IP it is not connected to?
post #7 of 8 Old 05-02-2013, 04:33 PM
c.kingsley's Avatar
Quoted: 197 Post(s)
Liked: 372
In that configuration the WAN port of the Linksys router would have grabbed a 192.168.2.0 address. If the 360 is plugged into a DMZ port that wouldn't be all that strange.
In either case, as others have said, just connect one of the Linksys router's switch ports to a switch port on the Belkin's. Disable DHCP on the Linksys through the web interface from your PC.
http://192.168.1.1
c.kingsley is offline
post #8 of 8 Old 05-02-2013, 05:29 PM - Thread Starter
Quoted: 165 Post(s)
Liked: 623
Reply Xbox Area
