The Official Xbox One thread... - Page 352 - AVS Forum | Home Theater Discussions And Reviews
 1806Likes
post #10531 of 21906 Old 11-22-2013, 04:15 PM
BaronVH's Avatar
So here are my impressions of setup. First of all all of the cables and cords are very high quality. The system initially did not recognize my wireless network (my 360 did not like it at all). The system update would not download and locked up. After turning everything off and on, it downloaded in 30 minutes. Voice command works very well, and the only problems with it were attributed to operator error. The setup of my cable box (comcast) worked fine. It was then sent to my pioneer elite receiver then to tv, also a pioneer elite. Everything controls perfectly, and there were no problems with 7.1 sound. It did not have my specific receiver on the menu, but I picked one close to it, and it works great. The games take forever to download the required updates. It took Forza about 15 minutes to be able to play. Ryse is taking very long. As to Forza...oh my. I heard somebody comment that it looked to much like Forza 4 on the 360. Have to disagree. It looks and plays amazing. I also think the controllers are a big improvement, and the feedback in the triggers helped while driving. As i was typing this, it notified my that Ryse is ready to play. So far, everything works as advertized, but the reliance on the internet makesa few things take longer than I would like, but it seems like it is due to volume. I was impressed that it recognized and functions well with a niche tv and reciever. My cable box is a pain in the butt to use, but with the one it is easier. So far, very high marks but plan on setup taking a while.
pennhunter likes this.
BaronVH is offline
post #10532 of 21906 Old 11-22-2013, 04:25 PM
NJPapi1977's Avatar
Quoted: 210 Post(s)
Liked: 92
Can anyone help with the HDMI/DVI RGB RANGE
It seems at RGB Limited the tv 65VT60 shows the blacks washed out.
I have the HDMI/DVI RGB Range on Auto...Is that correct
NJPapi1977 is offline
post #10533 of 21906 Old 11-22-2013, 04:27 PM
The Murderousone's Avatar
Quoted: 197 Post(s)
Liked: 51
Guys how long is it taking you to download the games? KI and crismon dragon is taking forever for me........
The Murderousone is offline
post #10534 of 21906 Old 11-22-2013, 04:28 PM
jmalto's Avatar
I was just to post to see what others are doing. Utilizing the built-in patterns and a W1070 with the HDMI setting o "Auto" I cannot see the closed eye at the top but the bottom shows open and the blacks look black. If I flip it to a PC sigal which will display 0-255 I can see the top closed eye but everythig looks exremely washed out. Setting my RGB levels to Limited or Expanded makes no difference as to whether or not I can see the top eye, only changing the signal at the projetor itself.
Right now I have mine set to RGB Limited utilizing a "VIdeo" signal along with 30-bit depth. This should be correct for my projector but the built-in pattern does not display correctly for black levels.
jmalto is offline
post #10535 of 21906 Old 11-22-2013, 04:34 PM
NJPapi1977's Avatar
Quoted: 210 Post(s)
Liked: 92
I believe the PS4 has this issue as well
My Panny 65VT60 has the HDMI/DVI/RGB Range at Auto other choices are Nonstandard and Standard 16-235
If I leave it at Auto on my tv and RGB Limited on the xbox then the direct tv feed going into the xbox 1 looks washed out
The games look fine...But when I put the panny to 16-235 the direct tv feed looks perfect but gaming has crushed blacks.
This sucks
post #10536 of 21906 Old 11-22-2013, 04:46 PM
jmalto's Avatar
This sucks
Sorry for all the spelling errors a min ago, was in a hurry. My PS4 has issues as well with the W1070 but I decided to stop worrying about it and let it on RGB Limited with an "Auto" signal on the projector. I tried to calibrate using the AVS disc last weekend to touch up my colors and no matter what I did I was getting color blowout to where increasing Saturation or Hue made no difference in the numbers I was seeing with my meter. I've read previously that this has something to do with the signal between the console and the projector and most recommended setting it to RGB Limited with a "PC Signal" but everything looks horrible this way.
jmalto is offline
post #10537 of 21906 Old 11-22-2013, 04:49 PM
mboojigga's Avatar
Quoted: 589 Post(s)
Liked: 822
Originally Posted by lmychajluk View Post
Hmmm... might have to try VPN'ing back in so I can play as 'Commander' in BF4 from my tablet at work. wink.gif
It should be working from outside the home and your Wifi but for some reason it is telling me to connect on the same Wifi
The 5.0 is here
mboojigga is offline
post #10538 of 21906 Old 11-22-2013, 04:56 PM
beach scrub's Avatar
Liked: 37
Just had to do a hard reset... I was in the game menu and the screen reloaded then rebooted from standby. After the reboot kinect voice recognition didn't work and drilling down into a home screen selection would freeze the machine. I would have to put the one in standby and back on. After BF4 finished downloading I long pressed the power button until it rebooted from off. voice recognition works and menu selections are working as well. Just makes me curious is all.
PSN/XBL scrub175
beach scrub is offline
post #10539 of 21906 Old 11-22-2013, 04:58 PM
lmychajluk's Avatar
Finally! UPS guy was here 20 min ago. No text. No doorbell. The only way I found out was that I was refreshing the tracking page every 10 min. Took a couple of tries to connect to my wireless network, but downloading updates now....
-Lee
XBL GT: S4Lee
(Former) MS MVP - Xbox
lmychajluk is offline
post #10540 of 21906 Old 11-22-2013, 04:59 PM
Arutha_conDoin's Avatar
Quoted: 547 Post(s)
Liked: 495
My only disappointment so far is how long it takes to install the games off of the discs. Ryse took awhile, and so far COD Ghosts is at 6% and no option to play yet. I am a bit bummed that there is no option (hopefully down the road) that we can choose to have have discs out after it is installed (I'm willing to have some form of DRM for this since I do not trade in games or sell).
Xbox Live: DaBeavers
PSN- Arutha_conDoin
Steam- An0mander
"Too much knowledge never makes for simple decisions."
-Ghanima Atreides
Arutha_conDoin is offline
post #10541 of 21906 Old 11-22-2013, 05:04 PM
Daekwan's Avatar
Liked: 335
This right here. Is worth every penny
Xbox Live & PSN gamertag- Daekwan
www.facebook.com/Daekwan
Daekwan is offline
post #10542 of 21906 Old 11-22-2013, 05:06 PM
gpthree's Avatar
For kicks I hooked my 360 into the One and use the 360s Media Center Extender function. I can get TV to show but the One's IR commands do work to well in controlling media center for me. Will have to play around more with this.
Consider the unparalleled advantage, of a natural disaster that's impossible to manage.
gpthree is offline
post #10543 of 21906 Old 11-22-2013, 05:09 PM
tgable's Avatar
Quoted: 17 Post(s)
Liked: 78
Watching TV on a $500 console in party chat alone?
Now playing: Bloodborne
Recently Finished: The Order: 1886, Dying Light
PSN & XBL: Scuzzlebutt33
tgable is offline
post #10544 of 21906 Old 11-22-2013, 05:14 PM
chmorgan's Avatar
Quoted: 187 Post(s)
Liked: 136
Got the One at 2:10 today and ran some errands while letting it get to room temp and finally have it set up. It's been a great experience so far. Voice commands work great and the system is quick to respond.
I know this has been covered but I can't find it now. Is there a way to set the One up to have audio pass through? I've got a 9.2 setup and am missing my front presence speakers now. Anyone have any ideas?
Now to try some games. Thanks!
Never mind. I took care of business on my receiver. Kind of a DUH moment!
XBL: octavarium1/PSN:octavarium1970
chmorgan is offline
post #10545 of 21906 Old 11-22-2013, 05:16 PM
sirjonsnow's Avatar
Quoted: 121 Post(s)
Liked: 139
No option to exit out of a game straight to dashboard - for instance to exit a COD game and lobbies without hitting B half a dozen times.
No option to eject a disc without getting up and hitting the sensor.
sirjonsnow is offline
post #10546 of 21906 Old 11-22-2013, 05:22 PM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
Couple of questions:
1) Are the three red lights on the Kinect always on?
2) Any reason to keep my stand-alone blu-ray player?
Mathematics is the reason for the season.
Nickff is online now
post #10547 of 21906 Old 11-22-2013, 05:24 PM
housequestion's Avatar
Does the Xbone do HDMI passthrough? I'm reading mixed signals on this on the web. Also, for the HTPC features, can it call up things like Comcast On Demand?
housequestion is offline
post #10548 of 21906 Old 11-22-2013, 05:25 PM
c.kingsley's Avatar
Quoted: 187 Post(s)
Liked: 361
After being stuck in Shipping Now limbo at Amazon for more than 24 hours, my status updated to shipped with a delivery of 11/23. I checked FedEx and its actually a Priority Overnight. eek.gif
Looks like I may get it tonight and if so Amazon really pulled a hat trick on this one!
c.kingsley is offline
post #10549 of 21906 Old 11-22-2013, 05:35 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
At the rate this day one download is progressing I won't be able to set this thing up until next week.
The most frustrating part is that I need to baby sit it because after every 1-2mb it times out and tells me that there was a problem with the update. Sometimes it resumes on its own, sometimes it doesn't. It's so aggravating.
c.kingsley likes this.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #10550 of 21906 Old 11-22-2013, 05:38 PM
c.kingsley's Avatar
Quoted: 187 Post(s)
Liked: 361
Yeah, they have to be getting absolutely hammered right now. Even if my box shows up tonight, its 20 something degrees outside. I won't be able to turn it on for several hours so I may not get to play until tomorrow sometime. mad.gif
post #10551 of 21906 Old 11-22-2013, 05:41 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Also am I missing a piece or something, or is there no clamp or anythjng to attach kinect to the top of my panel?
bd2003 is offline
post #10552 of 21906 Old 11-22-2013, 05:44 PM
c.kingsley's Avatar
Quoted: 187 Post(s)
Liked: 361
post #10553 of 21906 Old 11-22-2013, 05:45 PM
spid's Avatar
Quoted: 248 Post(s)
Liked: 748
At the moment the One does not support 3D playback for blu-rays.
spid is offline
post #10554 of 21906 Old 11-22-2013, 05:51 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Even though I haven't been able to try it with a game yet, I can't say I'm digging the controller. The analog sticks seem much improved but that's about it. The bumpers are awful, there's no space between them and the triggers, and they just don't align well with my long fingers. My fingertips reach past where they curve down and they basically swoop down away from me, and they're difficult to press from that angle. The triggers have almost no resistance and it feels like a shorter throw than before. Something about the face buttons feels cheaper, the options button is way too close to the right analog stick. The dpad is shallow and clicky.
It's not that it's a bad controller per se, it just feels like everything but the sticks is a downgrade from the 360 controller.
emartins likes this.
bd2003 is offline
post #10555 of 21906 Old 11-22-2013, 05:54 PM
spid's Avatar
Quoted: 248 Post(s)
Liked: 748
Are there any demos other than kinect sports and KI in the store? I haven't bought any games, just looking for something to test it out with.
I am away from my console, but did you check out Zoo Tycoon or Just Dance?
spid is offline
post #10556 of 21906 Old 11-22-2013, 06:02 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
I haven't checked out anything but an update screen, but I'm going download every demo there is. Yes, even just dance. Are there demos for those?
bd2003 is offline
post #10557 of 21906 Old 11-22-2013, 06:07 PM
liltalkm's Avatar
Quoted: 191 Post(s)
Liked: 261
Let me preface this first.
I love my PS4. We are going to have a nice long relationship.
Having said that, with all this talk about how the PS4 has superior hardware (and there is no denying that), I can't help but think to myself "why doesn't the PS4 do this?"
Shouldn't it be the other way around?
Both consoles have their perk's, but if I had to purchase one console right now, it would be the One now and get a PS4 later when Naughty Dog releases their title.
My PC can do what the PS4 currently does. My PC cannot do what the X1 does quite the same way.
Just my .02.
(Theater)Speakers: Martin Logan Montis, Stage X, Dual Depth I Subs, Vanquish in ceiling (surrounds) | Processor: Marantz AV8802(A) | Amp: Three Moon Simaudio 400m monoblocks,One Moon Simaudio 330a, PS Audio Directstream | Sources: DirecTV HR54, HTPC, Mac Mini, Oppo UDP-203, PS4 Pro, Xbox One S | Television: LG 77G6P | Remote: Logitech Harmony Elite
(Bedroom)ORB Audio Mod 2 5.1, Yamaha RX-A2050, LG 55E6P, Samsung K8500, Harmony Elite.
liltalkm is offline
post #10558 of 21906 Old 11-22-2013, 06:09 PM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
My Xbox One is reporting a latency of 114ms for my network...way higher than speedtest reports. Normal?
post #10559 of 21906 Old 11-22-2013, 06:12 PM
rightintel's Avatar
Quoted: 547 Post(s)
Liked: 185
I blew off going to Gamestop and picking up the pre-order(it's cold/wet outside). I was wondering if anyone could comment on how easy/difficult the network settings are to configure if you're setting up a manual IP.
Xbox Live: General PATT0N
rightintel is offline
post #10560 of 21906 Old 11-22-2013, 06:19 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2980
Finally got mine up and running SW update took forever. Id like to see em add YCBCR colorspace instead of just RGB. Also find it odd they dont offer a "bitstream" setting for audio. I have to blu-ray for either 5.1 or 7.1 lossless PCM, unless I am missing something.
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
Reply Xbox Area
Monoprice , Xbox One Console Day One Edition
