The Official Xbox One thread... - Page 469 - AVS Forum
 65Likes
post #14041 of 16214 Old 03-11-2014, 07:17 AM
OberstDanjeje's Avatar
it's what I tought, thanks
OberstDanjeje is offline
post #14042 of 16214 Old 03-11-2014, 09:24 AM
bodean's Avatar
Quoted: 47 Post(s)
Originally Posted by Cravit8 View Post
Man, my receiver "Auto"s all that. That all sounds like a hot mess.
I'd wager all the various receiver quirks people have with the xbone (popping, PCM, video loss, DSP switching, HDMI input needing to be switched from 3 to 1, etc) is because they spent $300 instead of $1200.
It'll likely last longer than both the PS4/Xbone generation.
I'm sorry, that came off as bragging. :-/ My intention is to say to drop the $$ on an AVR, not just buy an overpriced HDMI switcher.
My Denon, Auto's all that also. Never have to manually switch anything on the receiver. I use 5.1 btw, not 7.1
Sony KDL65W850A 65" LED HDTV
Denon AVR-2113CI
Polk Monitor 65T (Fronts)
Polk Monitor 50's (Rears)
Polk CS2 (Center)
Acoustech PL-200
bodean is online now
post #14043 of 16214 Old 03-11-2014, 09:29 AM
bodean's Avatar
Quoted: 47 Post(s)
Originally Posted by mrlittlejeans View Post
Did you try putting the AVS calibration patterns in your SkyDrive and playing them back on the One like I suggested a few months ago?
Can you link this post so I can do this also? Thanks I think I may have found it at http://www.avsforum.com/t/1463980/masciors-calibration-disc
From what I've been reading, seems RGB full (0-255) clips both black and white levels on the Xbox One, and appears broken? Should users be using RGB limited (16-235) instead for correct levels?
Denon AVR-2113CI
Polk CS2 (Center)
Acoustech PL-200
post #14044 of 16214 Old 03-11-2014, 11:47 AM
vertigo235's Avatar
That would be ridiculous if the 360 version looked as good as the xb1 version.
Xbox Live: IamVertigo
PSN: IamVertigo
vertigo235 is offline
post #14045 of 16214 Old 03-11-2014, 12:30 PM
bd2003's Avatar
Quoted: 90 Post(s)
Liked: 1330
Yes. Setting RGB 0-255 is supposed to clip black and white levels.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #14046 of 16214 Old 03-11-2014, 12:38 PM
metalsaber's Avatar
Liked: 77
not going to happen
metalsaber is offline
post #14047 of 16214 Old 03-11-2014, 01:07 PM
AVS Club Gold
mrlittlejeans's Avatar
Liked: 191
It is working perfect for me. This is how I checked it. I downloaded the AVS calibration files here which include a black clipping file in the basic settings. I checked it on my Oppo 105 to my Panasonic 65ZT60 and made sure I could see 17 flashing. I then copied the same file to my Skydrive and played it on my xbox. I could still see 17 flashing so the Xbox One is not clipping blacks. Turning up the brightness on my tv even showed the below black information so the Xbox One isn't clipping the below black information either. The link you posted is to a full RGB test file of some sort. I'm not sure what relevance it has here.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #14048 of 16214 Old 03-11-2014, 02:37 PM
DaGamePimp's Avatar
Quoted: 14 Post(s)
Liked: 153
It does clip black when set to RGB Full, I have tested it and anything below 8 is crushed, or at least it was on the previous firmware as I have not re-checked the new firmware. wink.gif
This is not really an issue for the majority playing on a tv or projector, if you are using a monitor that does not handle limited 16-235 properly then it can be.
Then there are also displays that when set to game/pc mode (for less processing & lag) expect a full range signal.
Jason
DaGamePimp is offline
post #14049 of 16214 Old 03-11-2014, 03:10 PM
bd2003's Avatar
Quoted: 90 Post(s)
Liked: 1330
Jason
That's weird....It should be crushing everything below 16.
bd2003 is offline
post #14050 of 16214 Old 03-11-2014, 03:12 PM
AVS Club Gold
aaronwt's Avatar
Quoted: 200 Post(s)
Liked: 578
So what happens when you watch 2.0 content with it set for 5.1 output? Does the audio come out of all five speakers or just the fl/fr? If it comes out of the fl/fr then auto isn't doing anything.
39TB unRAID1--53TB unRAID2--36TB unRAID3
LED DLP
XBL/PSN: WormholeXtreme
aaronwt is offline
post #14051 of 16214 Old 03-11-2014, 04:56 PM
brian6751's Avatar
Liked: 94
Full is usually for computer monitors. Limited is for TV's
Xbox One Gamertag = The Barbeerian
PS4 PSNID = The-Barbeerian
brian6751 is offline
post #14052 of 16214 Old 03-11-2014, 06:43 PM
Quoted: 20 Post(s)
Liked: 82
I just wasted the last 90 minutes or so of my life and missing out on Titanfall trying to connect my new second X1 to my home network.
The 2nd X1 sees my wireless connection just fine, In fact, I even downloaded and installed the latest console update right at the start, no issues, but I keep getting an error when trying to sign in with my normal XB Live ID. It says that there is a core account login issue. No idea what that means.
It's probably user error unless this is a new bug and unfortunately the second room is not hard wired for Ethernet.
Any ideas?
tampabuc is offline
post #14053 of 16214 Old 03-11-2014, 06:54 PM
onlysublime's Avatar
Liked: 493
Originally Posted by michaeltscott View Post
Pretty interesting: "A closer look at Titanfall's not-so-secret weapon: Microsoft's cloud".
The game is so dependent on Azure servers--not just as hosts, but running NPC AI--that they're not releasing in South Africa because there aren't any there are sufficiently close by.
it's all AI including when your Titan is in follow or guard mode. a lot of people wrongly think it's just grunts and spectres.
no servers have ever been close to South Africa but they're used to it and have connected to Asia, South America, etc. for their gaming in other games. in fact, a lot of those gamers said they wouldn't mind connecting to the Euro or China servers as they were doing so during the beta and said the game was good still even at 180 ms. they're complaining that EA/Respawn should not arbitrarily set who can and can't get the game. just sell it with buyer beware which they've been used to forever.
http://arstechnica.com/gaming/2014/03/ea-nixes-titanfall-for-south-africa-after-poor-network-performance/
Historically, South African gamers have often had to connect to servers as far away as Europe to get a laggy-but-better-than-nothing connection for many online games.
South African gamers are understandably upset by the last-minute cancellation of a highly anticipated game and are venting their anger on EA's Facebook page. "Did you ask the hundreds of local players who took part in the beta without problems, or simply make the decision on our behalf?" one player wrote. "Sorry, but that is inexcusable!" wrote another. "We have been playing online [multiplayer games] via international servers for years. Give us the option to decide for ourselves."
There is also, of course, a change.org petition asking EA to reverse the decision, with 415 signatures as of this writing. "We believe that this should be OUR decision to make," the petition reads in part. "We enjoyed the experience so much that we are willing to pay the admission price and put up with high latency in order to play this game... This announcement is not only a huge disappointment, but a kick in the teeth to all FPS gamers in South Africa."
onlysublime is offline
post #14054 of 16214 Old 03-11-2014, 07:02 PM
Liked: 493
just read The Witcher 3: Wild Hunt has been delayed until February 2015 for those interested in that game...
post #14055 of 16214 Old 03-11-2014, 07:10 PM
pennhunter's Avatar
Liked: 27
Any ideas?
Ditto, wired or wireless it says check my network. A connection test says xbox live core services are down. I thought the second console would be easier to set up than the first.
Anyone have any ideas?
tampabuc likes this.
Live Gamertags: PennHunter, world builder and aNUNandHERdog.
PSN: pennhunter
pennhunter is offline
post #14056 of 16214 Old 03-11-2014, 07:13 PM
chmorgan's Avatar
Liked: 33
Any ideas?
I read something about this on IGN tonight. It sounds like the same issues you are having. If so, the issue is on Microsofts end. Some people are logging on just fine and others are getting the message that you are seeing. I think it it has something to do with all the people trying to get on with Titanfall.
tampabuc and pennhunter like this.
chmorgan is online now
post #14057 of 16214 Old 03-11-2014, 07:23 PM
Quoted: 20 Post(s)
Liked: 82
You guys kick a$$. Thank you. I'll stop trying for now.
pennhunter likes this.
tampabuc is offline
post #14058 of 16214 Old 03-11-2014, 07:46 PM
bd2003's Avatar
Quoted: 90 Post(s)
Liked: 1330
The azure servers are up and running on PC, so it's def XBL itself.
bd2003 is offline
post #14059 of 16214 Old 03-11-2014, 07:49 PM
Quoted: 20 Post(s)
Liked: 82
Sorry, I didn't realize it was a first attempt, not just a second console.
I just tried again and it is accepting my login info....
tampabuc is offline
post #14060 of 16214 Old 03-11-2014, 07:56 PM
Quoted: 20 Post(s)
Liked: 82
Ok, good news, I was able to login to XBL on the new/second console just now....
No errors. It even recognized my Titanfall purchase immediately. Downloading now.
Try it again now guys.
tampabuc is offline
post #14061 of 16214 Old 03-11-2014, 08:06 PM
bori's Avatar
Liked: 70
Xbox Live problems keep many Xbox One owners from calling in their Titan (update: fixed!) http://www.engadget.com/2014/03/11/xbox-live-problems-keep-many-xbox-one-owners-from-calling-in-the via Engadget Android
bori is online now
post #14062 of 16214 Old 03-12-2014, 09:17 AM
Cravit8's Avatar
Quoted: 18 Post(s)
Liked: 191
Does the Xbox UI lag by ~80ms or is it my tv?
I'm still waiting for TF to install so I can discern if its the UI or this crap 4k TCL LCD.
Cravit8 is offline
post #14063 of 16214 Old 03-12-2014, 09:40 AM
NJPapi1977's Avatar
Liked: 37
I thought PC version ran on Origin Servers and XB1 on Azure
NJPapi1977 is offline
post #14064 of 16214 Old 03-12-2014, 09:49 AM
cubdenno's Avatar
Liked: 54
Prolly the TV
http://www.displaylag.com/
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #14065 of 16214 Old 03-12-2014, 09:51 AM
americangunner's Avatar
Liked: 285
I am not having any issues on my LED tv, it's real quick and snappy.
XBL: xGunner26x
PSN: AMER1CAN_GUNNER
Steam: xGunner26x
americangunner is offline
post #14066 of 16214 Old 03-12-2014, 10:17 AM
Cravit8's Avatar
Quoted: 18 Post(s)
Liked: 191
Originally Posted by cubdenno View Post
Prolly the TV
Oh it's the TV, I just confirmed. And it is basically unplayable. Ugh. What a horrible purchase.
Cravit8 is offline
post #14067 of 16214 Old 03-12-2014, 10:21 AM
Myrtledog's Avatar
Liked: 98
Go to the Microsoft Store, Add the Titanfall bundle and use promo code 1. You're welcome! biggrin.gif
Myrtledog is offline
post #14068 of 16214 Old 03-12-2014, 10:23 AM
AVS Club Gold
aaronwt's Avatar
Quoted: 200 Post(s)
Liked: 578
Does it have a game mode?
LED DLP
aaronwt is offline
post #14069 of 16214 Old 03-12-2014, 10:25 AM
emartins's Avatar
Quoted: 98 Post(s)
Liked: 308
Woah, thank you.
Hapi -"Lazy......cuz he's a boss like that"
mphfrom77 - "I'm an idiot."
benjamin-benjami - http://www.avsforum.com/t/1476721/battlefield-4/7200_100#post_24609271
emartins is online now
post #14070 of 16214 Old 03-12-2014, 10:29 AM
NJPapi1977's Avatar
Liked: 37
It is not a valid code as it was quickly taken down.
Reply Xbox Area
Monoprice , Xbox One Console Day One Edition
User Tag List
