The Official Xbox One thread... - Page 478 - AVS Forum | Home Theater Discussions And Reviews
 1929Likes
post #14311 of 22110 Old 03-21-2014, 09:37 PM
onlysublime's Avatar
Quoted: 899 Post(s)
Liked: 1472
Originally Posted by ajohn505 View Post
The chat volume is nice and loud, the DSS2 puts out some great sounding audio (and has quite a few EQ and virtual speaker placement options).
I love my DSS2! Great way to get surround sound on a budget...
onlysublime is offline
post #14312 of 22110 Old 03-21-2014, 09:57 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
Originally Posted by onlysublime View Post
less work than porting The Crew from DX to PS4...
Not sure what you're trying to say?
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #14313 of 22110 Old 03-21-2014, 11:05 PM
c.kingsley's Avatar
Quoted: 197 Post(s)
Liked: 372
Originally Posted by bd2003 View Post
It's not fragmented if everyone can still play the same games. That's where DX12 comes in.
They already had DX11.x which could accomplish that same objective. The Windows 8 kernel is built for x86/64 and ARM already. These are the dominant architectures today. DX12 isn't going to change much of anything. It may improve the performance of the Xbox somewhat but that is speculative. If anything it is more of a boon to the PC market.
c.kingsley is offline
post #14314 of 22110 Old 03-22-2014, 12:35 AM
mboojigga's Avatar
Quoted: 642 Post(s)
Liked: 878
http://www.dualshockers.com/2014/03/22/xbox-one-april-firmware-update-gets-new-build-brings-silent-system-update-installation/
Today the 1404 build of the April Xbox One firmware update is being made available to those that are in the update preview program. The most relevant addition a silent system update installation feature, allowing the download and installation of a new firmware overnight without the need to turn on the console manually.
The full patch notes have been published on the private preview forum, and you can read them below, courtesy of Reddit user SilasDG.
1404 build (xb_rel_1404.140319-2200)
Deployment starts at 6:00PM PDT on 3/21 and is over 1GB)
Prompt Update will begin on 1:00AM PDT 3/23 for non-standy units
Issues Fixed
◦Several fixes and tweaks to the user interface.
◦Initial fixes to address audio crackling sound encountered when Dolby Digital is enabled (additional fixes are pending and will be deployed with a later build).
◦A fix to address issues where game resume could fail when a console comes out of standby, causing the game to restart rather than resume from its previous state.
◦Initial fixes for Blu-ray issues where the drive may not be responsive, requiring full system power down to resolve (pressing and holding the power button on the console for 5 seconds).
New Additions:
◦Underlying OS changes required to enable planned 1404 features.
◦NEW FEATURE Silent system update installation: Initial OS changes are present that enable consoles to take a system update overnight when in standby, and the console will now complete the installation, then boot back into standby. This feature will bypass the green installation progress bar currently seen when starting a console that needs to finish installing an update started in standby. This feature will already work with some consoles in this update!
Known Issues:
◦An issue has been identified in the current 1404 build (xb_rel_1404.140313-2200) where consoles with wired connections aren’t taking system, app, or game updates when in standby. Consoles connected via wireless are not affected. To test the silent update with a wired connection, you can work around this issue by connecting wirelessly when putting your console in standby overnight.
◦When performing the new silent system update, the following issues may be encountered:
1.The Blu-ray drive may spin up during silent startup.
2.The Kinect sensor may light up during silent boot.
3.During shutdown from standby to install the update, the power light will flash showing that it is shutting down.
◦Work is still being done to fix all Blu-ray drive issues that were introduced in 1404. There are still some instances where the Blu-ray drive may not wake up from an idle state, resulting in errors that a disc is not present. These issues should be resolved by ejecting and re-inserting the disc to wake up the drive.
◦When turning off your console with the “Xbox, turn off” command, Kinect does not respond to a command of “yes” or “no”, requiring the controller or remote be used to select “yes” to turn the console off
JudgeSmails and onlysublime like this.
The 5.0 is here
mboojigga is offline
post #14315 of 22110 Old 03-22-2014, 05:50 AM
c.kingsley's Avatar
Quoted: 197 Post(s)
Liked: 372
This is a very good change. I don't know how it ever released without this ability!
post #14316 of 22110 Old 03-22-2014, 05:52 AM
metalsaber's Avatar
Quoted: 1029 Post(s)
Liked: 844
Finally some silent updates.
metalsaber is offline
post #14317 of 22110 Old 03-22-2014, 06:41 AM
brian6751's Avatar
Quoted: 1146 Post(s)
Liked: 1125
Originally Posted by slyderulz View Post
Totally understand that option, and I appreciate you bringing it up, twice wink.gif...but the way the One guide works with my current Uverse cable box is glitchy at best. Forget voice commands, I'll select a channel manually in the guide and the One will bring up a different channel!
I've got patience to work through that stuff but they don't...and I'm not going to spend the little free time I have being tech support for the One so they can watch their TV programs. That's why I have everything hooked up to a Harmony remote in the first place, they just press the activity and everything works.
I'd rather keep them off the One for TV entirely, so I guess if no one else has tried the splitter I'll be the guinea pig biggrin.gif
I'm in the same situation as you. I tried this splitter. It did its job just fine. I was having audio sync issues and took it out of the loop. I no longer have the issue but I'm not sure if the splitter was the cause. I have not hooked it back up yet. I'm waiting for an update to make the Xbone default to the TV ap on start up.
http://www.amazon.com/gp/aw/d/B008D66RAU
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is offline
post #14318 of 22110 Old 03-22-2014, 07:10 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
The significance isn't that DX11 couldn't do the same. It's that going forward, the xbox API isn't a fork of the PC (like it was with the 360).
Just to add a little fuel to the fire:
http://www.polygon.com/2014/3/21/5534188/microsoft-renewed-focus-on-windows-pc-gaming-phil-spencer
Think about what windows has done in the past few years. They've systematically ripped out a ton of branding, and replaced it with xbox. The music app in windows 8 is "xbox music". Same with video....even the games app is technically "xbox games". Xbox is slowly becoming more like windows, and windows is becoming more like xbox. And since the xbox one is basically an x86 PC....it seems pretty obvious where this is all headed.
bd2003 is offline
post #14319 of 22110 Old 03-22-2014, 08:59 AM
JaremyP's Avatar
Quoted: 483 Post(s)
Liked: 274
I would love love love shorter consoles cycles. Give me 3 year cycles. Perfect. The only caveat is maintaining perpetual backwards compatibility which should be the case now that consoles are (and should stay) pc core architectures.
Gear: Vizio P75, Marantz AV7702mkII, Emotiva XPA, Triad Silver 7.2.4
Xbox Live: TrackZ
PSN: TrackZ
Steam/PC: TrackZ06
JaremyP is offline
post #14320 of 22110 Old 03-22-2014, 09:25 AM
jhoff80's Avatar
Quoted: 395 Post(s)
Liked: 361
I was thinking this morning as I had to get up to do a full system reboot after already setting myself up on the couch... there really needs to be a way to do a full shutdown with the controller. Bury it in settings>power if necessary, there's already a turn off feature there.
XBL/Steam: JHoff80
jhoff80 is offline
post #14321 of 22110 Old 03-22-2014, 09:39 AM
michaeltscott's Avatar
Quoted: 2844 Post(s)
Liked: 1516
You can already do this. Just go to settings and turn off "Instant On" then turn the machine off. When you turn it on again it will boot from scratch.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #14322 of 22110 Old 03-22-2014, 09:49 AM
jhoff80's Avatar
Quoted: 395 Post(s)
Liked: 361
Hadn't really thought of that as a possibility, but yeah that would work. A little overly complicated compared to just having a button for it, but still.
XBL/Steam: JHoff80
jhoff80 is offline
post #14323 of 22110 Old 03-22-2014, 10:02 AM
Liked: 1516
Perhaps, but if you use Instant On how often are you going to need to boot from scratch?
post #14324 of 22110 Old 03-22-2014, 10:03 AM
jhoff80's Avatar
Quoted: 395 Post(s)
Liked: 361
Unfortunately, more often than I'd like to. It's been about once a week or so that I've had to do it. Today it was because the system wouldn't connect to Live until I did that.
XBL/Steam: JHoff80
jhoff80 is offline
post #14325 of 22110 Old 03-22-2014, 10:37 AM
chmorgan's Avatar
Quoted: 205 Post(s)
Liked: 149
S
Same thing here. Been having to reboot in order to connect to Live. What up with that?
XBL: octavarium1/PSN:octavarium1970
chmorgan is offline
post #14326 of 22110 Old 03-22-2014, 11:31 AM
slyderulz's Avatar
Quoted: 211 Post(s)
Liked: 136
Thanks, I got this one...works like a charm so far except for the incredibly bright blue LED lights. Gotta find that electrical tape I used on the DS4 wink.gif
http://www.amazon.com/gp/product/B0088HP93A/ref=oh_details_o00_s01_i00?ie=UTF8&psc=1
XBOX LIVE ID: JeepR kReapR
PSN ID: JeepR_kReapR
Originally Posted by emartins
Instead of the usual 2 minutes, give her 5 minutes of nothing but that Jeep ecstasy. She will be exhausted and fall right to sleep. You are now free to play.
Thats what I do.
slyderulz is offline
post #14327 of 22110 Old 03-22-2014, 12:00 PM
OberstDanjeje's Avatar
I have the same splitter and it work quite well, yes the led are too bright 😖
OberstDanjeje is offline
post #14328 of 22110 Old 03-22-2014, 03:49 PM
UHD Addict
aaronwt's Avatar
Quoted: 6228 Post(s)
Liked: 3859
LightDims
http://www.lightdims.com/
They work great on Bright LEDs.
I need to put them on my second HDMI splitter. For some reason the LEDs are alot brighter than the first one I bought from Amazon.
OberstDanjeje likes this.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #14329 of 22110 Old 03-22-2014, 08:49 PM
c.kingsley's Avatar
Quoted: 197 Post(s)
Liked: 372
Don't get me wrong, it'd probably be a good thing if it went there but the first Xbox was also x86 and then the 360 was released on PowerPC architecture. You can count me in the camp that was totally surprised by that decision. I think it is way to early to be assuming what happens next is obvious. We're only ~4 months into this cycle of consoles. My crystal ball is cloudy...
post #14330 of 22110 Old 03-22-2014, 09:52 PM
pcweber111's Avatar
Quoted: 30 Post(s)
Liked: 267
This is why Steam had to be proactive because the collision course Xbox and Windows are headed to involves the Windows Store, something Steam will be locked out of. To me if MS says they're dedicated to PC gaming but that dedication locks you into apps from their store that doesn't do the PC crowd any favors. In fact it's pretty hostile to be honest. I like Windows 8 but I think they need to keep PC gaming separate from what they're doing with their Metro store. I don't see that happening though.
TeflonSoul likes this.
pcweber111 is offline
post #14331 of 22110 Old 03-22-2014, 10:30 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
I don't see how they can lock you in short of locking steam entirely out of windows. If the windows store (ahem, xbox games store) finally becomes a viable PC games marketplace, then I welcome a new competitor. I'm looking forward to them bringing a proper controller-based interface to windows, and as long as I'm free to arrange shortcuts as I please then I'm all for it. If it really is an attempt at lock in, where the only apps that can launch from that interface are windows store apps, then I agree...it's going to fall as flat on it's face as GFW. It'll be interesting...it could end up being something fantastic, or another half assed attempt.
How all this extends to the xbox consoles themselves is hard to say...I suspect it'll stay locked down in far more ways than windows, more of a controlled experience. But I would bet anything you buy on xbox, you'll automatically get for windows. And looking at the start screen, the interfaces will probably be indistinguishable from one another.
bd2003 is offline
post #14332 of 22110 Old 03-22-2014, 10:36 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
I dunno...it just seems obvious to me. Any one thing isn't evidence of much by itself, but taken all together I think it's pretty clear what the general direction of their plans are.
bd2003 is offline
post #14333 of 22110 Old 03-23-2014, 03:05 AM
Originally Posted by aaronwt View Post
LightDims
Thank.
It's an interesting thing
post #14334 of 22110 Old 03-23-2014, 07:08 AM
Bailey151's Avatar
Quoted: 12 Post(s)
Liked: 73
That's pretty easy.......the "media content device" aka the Xbox will be the only "PC" in the average home. PC's are a dodo bird & MS is very aware of that fact.
It's just my opinion & it's worth exactly what you paid for it.
Bailey151 is offline
post #14335 of 22110 Old 03-23-2014, 09:17 AM
jhoff80's Avatar
Quoted: 395 Post(s)
Liked: 361
In case anyone was interested, there's apparently a new app so people can watch the Call of Duty Championships. (I only noticed it myself because I was looking to see if MLB.tv was there yet).
XBL/Steam: JHoff80
jhoff80 is offline
post #14336 of 22110 Old 03-23-2014, 12:04 PM
Quoted: 899 Post(s)
Liked: 1472
did you guys read the article on the million point guy at Polygon? pretty cool article...
can't imagine unlocking an average of 333 gamerscore a day... didn't know also that he wanted to sit at 1,000,000 and not get any more points by playing in such a way that he knew he couldn't get any achievements...
http://www.polygon.com/2014/3/22/5533384/meet-the-million-point-man-of-xbox-live
Microsoft approached him with another request: The Titanfall event at South by Southwest, the interactive festival in Austin, Texas, was a second chance to do it during a big moment for Xbox.
Cox accepted the challenge and went to Texas with a library of gamesaves already set up to cash in achievements and Gamerscore. "It's actually kind of what I'd been doing since October," he said, "getting to points in a game where I was close to unlocking an achievement and saving them. That's kind of how I was playing for many months."
He arrived in Austin on a Saturday standing about 17,000 Gamerscore short of a million. Think about this for a second. A five-figure Gamerscore is an entire career for thousands, if not millions, on Xbox Live. Cox was trying to cover that span in a weekend. Again, it just proved infeasible.
"They had everything set up, and they had everything out there to help me try to get the million," Cox said. "As soon as I got to the hotel, I played all night, then I slept for an hour and got up and played all day. It was pretty nuts. Everybody else was drinking and having fun, and I was sitting there busting my ass."
post #14337 of 22110 Old 03-23-2014, 12:26 PM
Quoted: 899 Post(s)
Liked: 1472
just got the 1404 update preview (1.7 GB!). preview forum says not all 1404 update features are live yet but will roll out...
post #14338 of 22110 Old 03-23-2014, 01:07 PM
Sorax's Avatar
Liked: 61
Exciting. And I may just be a tiny bit envious of everyone in the preview biggrin.gif
Gamer Tag: Todd Stevens
Sorax is offline
post #14339 of 22110 Old 03-23-2014, 02:20 PM
UHD Addict
aaronwt's Avatar
Liked: 3859
I thought the last update was supposed to elimiate having the scrub bar show up. It's showing an update for me now. But the scrub bar does look different and there is also a picture of the XBOne on screen which didn't used to be the case. At least it downloaded quick. It took less than two minutes to download the 1.6 or 1.7GB.
EDIT: well that was different. It just rebooted and now I have the screen with only the scrub bar. This must be the update that my other XBOne got the other day. Which I guess is the one that changes how it updates. Where in the future it is supposed to update and go back into standby mode,
aaronwt is offline
post #14340 of 22110 Old 03-23-2014, 02:25 PM
chmorgan's Avatar
Quoted: 205 Post(s)
Liked: 149
I'm not in on any of the preview updates, so I don't know if that makes a difference, but I've never seen a scrub bar of any kind. I'm guessing it's the way I have my system set up, but I don't recall setting anything for this.
chmorgan is offline
Reply Xbox Area
Monoprice , Xbox One Console Day One Edition
