The Official Xbox One thread... - Page 514 - AVS Forum | Home Theater Discussions And Reviews
 1806Likes
post #15391 of 21906 Old 05-20-2014, 12:46 PM
scubasteve2365's Avatar
Quoted: 262 Post(s)
Liked: 346
Originally Posted by bd2003 View Post
There's been a recent surge in ram requirements due to the next gen consoles. Prior to that was a long stretch where you could go the length of a console cycle without upgrading.
The particular example with watch dogs referencing what it'll take to run the game at 1080p/60 at ultra settings, something neither console will be able to touch.
For poops-n-giggles. What do you think the price would be on a BOM (with HTPC console sized case) that would run watch dogs at 1080/60 versus a BOM with the same case that would run watch dogs at the same specs as PS4 (IIRC, 900p/60) Could you build a PC that would run the game as well as the PS4 does for $399 or less? What about the XBO? 5 years from now would you be able to do the same at $199-$249 (where the PS4/XBO will be priced then)?
I've always had the understanding that even though consoles are usually low-spec for the bulk of the console life cycle compared to PC, that due to the lower overhead (i.e., not running windows) or other developer methods of efficiency result in getting more out of that 1gig of ram than you would in a PC.
"The Scuba Tank" thread here
PSN/XBL : ScubaSteve2365
VR Roundtable
scubasteve2365 is offline
post #15392 of 21906 Old 05-20-2014, 12:51 PM
Quoted: 262 Post(s)
Liked: 346
Originally Posted by Osirus23 View Post
This is a bunch of nonsense that just proves you know little about PC gaming outside of what you were told 15 years ago. "Constant upgrading" is complete nonsense.
I also have a 5 year old PC that will play Watch Dogs just fine btw.
Interesting, my 3 year old PC, with 16g of Ram and an early gen core i5 wouldn't run Titanfall. Granted I didn't buy a gaming level video card 3 years ago, but in order to get the game to run well today (at least as good as the XBO) I'd have to spend a minimum of $100-$150 bucks. A card 3 years ago that would run Titanfall well would've cost how much then? How much was that PC build 5 years ago that will play Watch Dogs just fine and will it play it as well as the PS4/XBO?
VR Roundtable
post #15393 of 21906 Old 05-20-2014, 01:01 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
It's hard to say until the game is out. A PC will certainly cost you a little more, but it's more than made up by the lack of a yearly fee and cheaper games and accessories. There's still a case to be made that consoles are simpler, but its way more difficult the justify them from a value perspective than it used to. I think you even can get watch dogs for free with a $150 video card right now (which probably means I'll be able to buy a code from someone for $10.)
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #15394 of 21906 Old 05-20-2014, 01:01 PM
metalsaber's Avatar
Quoted: 962 Post(s)
Liked: 774
Originally Posted by americangunner View Post
What are the chances that after E3, we stop talking about all this stupid crap that has been recycled through this thread for the last several pages and start focusing on games?
pennhunter likes this.
metalsaber is offline
post #15395 of 21906 Old 05-20-2014, 01:51 PM
michaeltscott's Avatar
Quoted: 2708 Post(s)
Liked: 1429
From http://www.forbes.com/sites/erikkain/2014/05/13/ubisoft-reveals-actual-resolution-for-watch-dogs-on-ps4-and-xbox-one/
“The game also looks great on both generations of consoles,” the post reads. “On new-gen systems the game will run at 900p on PS4 and 792p on Xbox One, at 30 frames-per-second on both consoles.”
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #15396 of 21906 Old 05-20-2014, 01:58 PM
totalownership's Avatar
Quoted: 188 Post(s)
Liked: 271
AT HAMMOND ROBOTICS WE'RE BRINGING THE FUTURE ... HOME
PROTOCOL 3: PROTECT THE PILOT
totalownership is offline
post #15397 of 21906 Old 05-20-2014, 02:20 PM
freemeat's Avatar
Quoted: 388 Post(s)
Liked: 747
792p, isn't that Titanfall as well? Is there technical reason why they go with 792p, maybe scaling smoothly or something?
freemeat is offline
post #15398 of 21906 Old 05-20-2014, 02:43 PM
Liked: 1429
Google "Titanfall resolution". Respawn said that were continuing to work on it and intended to issue a patch with a resolution bump.
post #15399 of 21906 Old 05-20-2014, 02:45 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
The simple answer is esram limitations. The full explanation requires so much tech jargon it'll make your head explode. ;p
bd2003 is offline
post #15400 of 21906 Old 05-20-2014, 02:47 PM
freemeat's Avatar
Quoted: 388 Post(s)
Liked: 747
So they are upping it?
ok, well other game are 1080p.. Just was curious if 792p was some weird preferred scaling resolution.
freemeat is offline
post #15401 of 21906 Old 05-20-2014, 03:14 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
It depends on how they use the esram.
I think it's actually a pretty bad resolution to scale to 1080, but having more source pixels outweighs it.
bd2003 is offline
post #15402 of 21906 Old 05-20-2014, 05:37 PM
tgable's Avatar
Quoted: 17 Post(s)
Liked: 78
The frame rate is bad enough, they should get a batter frame rate, not increase the res. Odds are they will do neither.
Now playing: Bloodborne
Recently Finished: The Order: 1886, Dying Light
PSN & XBL: Scuzzlebutt33
tgable is offline
post #15403 of 21906 Old 05-20-2014, 05:48 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Yeah I get the feeling that if they were going to raise the resolution, they'd have done it by now. All the extra stuff they promised for PC is still MIA as well. Their programmers have prob moved on to TF2 already.
bd2003 is offline
post #15404 of 21906 Old 05-21-2014, 04:54 AM
Jonny5nz's Avatar
Quoted: 31 Post(s)
Liked: 93
Who has time to look at the resolution? A solid 60fps would be nice though.
Jonny5nz is offline
post #15405 of 21906 Old 05-21-2014, 07:22 AM
Bailey151's Avatar
Quoted: 12 Post(s)
Liked: 73
.........I've always had the understanding that even though consoles are usually low-spec for the bulk of the console life cycle compared to PC, that due to the lower overhead (i.e., not running windows) or other developer methods of efficiency result in getting more out of that 1gig of ram than you would in a PC.
That's always been the claim, can be optimized for the hardware. Squeeze every last drop out of it since there is no generalized coding.
It's just my opinion & it's worth exactly what you paid for it.
Bailey151 is offline
post #15406 of 21906 Old 05-21-2014, 07:22 AM
spid's Avatar
Quoted: 248 Post(s)
Liked: 750
The new OS features coming in June have been detailed. The biggest feature for me is external drive support. The beta features for Smartglass will roll into full product.
http://majornelson.com/2014/05/21/external-storage-real-names-and-more-coming-with-xbox-one-system-update-in-june/
spid is offline
post #15407 of 21906 Old 05-21-2014, 07:52 AM
metalsaber's Avatar
Quoted: 962 Post(s)
Liked: 774
External Hard drive support = huge win
Auto sign in will be nice simple addition as well.
pennhunter and Bailey151 like this.
post #15408 of 21906 Old 05-21-2014, 08:29 AM
mboojigga's Avatar
Quoted: 590 Post(s)
Liked: 822
So no ceiling limit for external hardrive size along with being able to hook up two at a time. My 2 3TBs have been ready.
The 5.0 is here
mboojigga is offline
post #15409 of 21906 Old 05-21-2014, 08:33 AM
americangunner's Avatar
Liked: 288
A lot of good features coming in that update. I want to see how the real name thing works too.
XBL: xGunner26x
PSN: AMER1CAN_GUNNER
Steam: xGunner26x
americangunner is offline
post #15410 of 21906 Old 05-21-2014, 08:49 AM
Bailey151's Avatar
Quoted: 12 Post(s)
Liked: 73
post #15411 of 21906 Old 05-21-2014, 08:53 AM
metalsaber's Avatar
Quoted: 962 Post(s)
Liked: 774
I'm assuming the HDD can be of any variety as long as it connects via USB3? 5400 or 7200rpms or higher? SSD or any form factor?
post #15412 of 21906 Old 05-21-2014, 09:15 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
DX12 may change all that though.
bd2003 is offline
post #15413 of 21906 Old 05-21-2014, 09:15 AM
Quoted: 1173 Post(s)
Liked: 968
All it mentions is USB3 and 256gb or higher. So I would think anything would work
One of the greatest posts I have read
benjamin-benjami - http://www.avsforum.com/forum/142-pl...l#post24609271
emartins is offline
post #15414 of 21906 Old 05-21-2014, 09:20 AM
metalsaber's Avatar
Quoted: 962 Post(s)
Liked: 774
Thats my reaction as well, but I'd hate to go dropping a couple hundred bucks on a drive/enclosure that wasn't supported for some reason.
post #15415 of 21906 Old 05-21-2014, 09:21 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Maybe they'll run a speed test or something, but I doubt there are any retail USB 3.0 drives slower than the stock HDD anyway, so USB 3.0 support alone should make for a good cutoff. It says at least 256GB though, so that rules out a lot of SSDs.
bd2003 is offline
post #15416 of 21906 Old 05-21-2014, 09:22 AM
Liked: 968
I plan on waiting till they tell us exactly what requirements it has
emartins is offline
post #15417 of 21906 Old 05-21-2014, 09:26 AM
Liked: 968
Do you think somehow USB3 will slow down any gains from the SSD. I see MS somehow slowing down the USB3 to the point of the SSD speeds being worthless.
emartins is offline
post #15418 of 21906 Old 05-21-2014, 09:34 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Depends on their implementation. On paper USB 3.0 is faster than the internal SATA2 ports, but they might be reserving some bandwidth for other purposes. Even so, most of the gains from an SSD are going to come from the vastly reduced access time, so I'd wager you'll still see a solid boost from one. It won't be huge though, cause the bottleneck is still the decompression stage.
bd2003 is offline
post #15419 of 21906 Old 05-21-2014, 09:46 AM
UHD Addict
aaronwt's Avatar
Quoted: 5201 Post(s)
Liked: 3106
Auto sign in will be nice simple addition as well...
Yes. Newegg is having a sale on 2.5" external enclosures with USB 3.0. I have a bunch of old 128GB SSDs lying around. So I think I will buy a several enclosures and use them for my XBOnes.
As far as auto sign in. It already does this for me with kinect.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #15420 of 21906 Old 05-21-2014, 09:48 AM
UHD Addict
aaronwt's Avatar
Liked: 3106
Crap!! Really?!?! 256GB and higher? There goes my plan to repurpose my old 128GB SSDs.
aaronwt is offline
Reply Xbox Area
Monoprice , Xbox One Console Day One Edition
