Xbo 360 won't boot up. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-13-2013, 06:27 AM - Thread Starter
nckjason's Avatar
Hi,
Need help on my Xbox 360.It does not power up. Is there any way to repair it myself. Any suggestions or advise are needed.
nckjason is offline
post #2 of 11 Old 06-13-2013, 07:33 AM
garciab's Avatar
Quoted: 144 Post(s)
Liked: 56
Which model? Slim?
bg
garciab is offline
post #3 of 11 Old 06-13-2013, 08:10 AM - Thread Starter
nckjason's Avatar
No it is not slim. Any help?
nckjason is offline
post #4 of 11 Old 06-13-2013, 09:30 AM
AutoWobble's Avatar
Tell us more. What color is the power brick light? Does that color change? Have you tried a different outlet?
Xbox Gamertag: Autowobble
AutoWobble is offline
post #5 of 11 Old 06-13-2013, 10:05 AM - Thread Starter
nckjason's Avatar
The colour of the power brick is orange. I suspected that it could be the power brick that is giving the problem. However, I tried on my friend's xbox 360 and it is working with green light when powered on. So this confirmed that the power brick is working and my xbox is dead.
nckjason is offline
post #6 of 11 Old 06-13-2013, 10:11 AM
garciab's Avatar
Quoted: 144 Post(s)
Liked: 56
sorry, no help. i have a slim that went dead overnight for no apparent reason. just completely unresponsive to power button or controller. research indicates certain components going bad in the console, but I haven't cracked the case to take a look. not sure the same thing happens with the original though.
bg
garciab is offline
post #7 of 11 Old 06-13-2013, 01:42 PM
Rotoman's Avatar
Liked: 40
This is going to sound crazy, but unplug your HDMI cable and plug it back in and try it. I had the same problem about 3 weeks ago. The system would 'beep' when I hit the power button but would not power up...the power brick light was orange and tested good on another unit...searched the Googles and found this solution and amazingly it worked.
Xbox handle: TheRotoman
Rotoman is offline
post #8 of 11 Old 06-13-2013, 02:52 PM
garciab's Avatar
Quoted: 144 Post(s)
Liked: 56
Rotoman, slim or original?
bg
garciab is offline
post #9 of 11 Old 06-13-2013, 07:55 PM - Thread Starter
nckjason's Avatar
Thanks Rotoman.I've tried it but it is still not working.I was just wondering if it is the problem on the motherboard. Just curious if there is any fuse somewhere? Could it be the fuse has blown? Will try to Google for the schematics of my Xbox or the service manual to find out.
nckjason is offline
post #10 of 11 Old 06-14-2013, 04:08 AM - Thread Starter
nckjason's Avatar
Been trying to search for other forums regarding the power brick problem and googling it for solutions but with no luck and despair. Advice and help are desperately needed. Thanks in advance.
nckjason is offline
post #11 of 11 Old 06-14-2013, 06:15 AM - Thread Starter
nckjason's Avatar
Does anybody got the schematics or service manual for the Xbox 360? Appreciate it if there are suggestions or links which I could download the service manual or the schematics or diagrams or whatsoever guides for repair my Xbox 360. Thanks in advance.
nckjason is offline
Reply Xbox Area
