How do I upgrade XBOX 360 Hard drive? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 06-29-2013, 10:02 PM - Thread Starter
gonzo90017's Avatar
Quoted: 42 Post(s)
I'm about to purchase the new redesigned XBOX 360 4gb version. I would like to install my own drive so I don't have to pay the inflated amount microsoft wants. So my question is can someone give me a step by step? Can I use any drive? What's the max size? etc. etc...
gonzo90017 is online now
post #2 of 14 Old 06-29-2013, 10:05 PM
yaomizzle's Avatar
Liked: 26
Life doesn't work that way
Sent from my iPad using Tapatalk HD
freemeat likes this.
yaomizzle is offline
post #3 of 14 Old 06-29-2013, 10:15 PM
freemeat's Avatar
Quoted: 388 Post(s)
Liked: 744
You only have that flexibility with a PS3 and PC.
freemeat is offline
post #4 of 14 Old 06-29-2013, 10:39 PM
onlysublime's Avatar
Quoted: 768 Post(s)
Liked: 1203
you have to get a western digital scorpio drive. only that brand can work for 360 drives. lots of easy guides out there. just google.
really, the cheapest way to go about it is get a Xbox 360 HDD Chinese knockoff from Amazon or Ebay. of course, it won't be authentic but you'll most likely be able to get away with it.
or you can wait for one of Gamestop's regular 50% hardware sales. I got a 250GB refurbished drive for $30 that way. Got a 120GB refub for $20 that way too.
you can use any 360 drive on any 360 console which means you can use an old drive on the latest 360 E system or the 360 E HDD on the original 360 drive. it's just a matter of swapping the external case.
onlysublime is online now
post #5 of 14 Old 06-29-2013, 11:04 PM - Thread Starter
gonzo90017's Avatar
Quoted: 42 Post(s)
Thanks for the helpful reply. The reason I didn't want to go with the chinese knock off drives was that I heard they used refurbished drives. Might as well go with a new drive because of the warranty.
I assume the biggest drive I can use is 250gb?
post #6 of 14 Old 06-29-2013, 11:07 PM
yaomizzle's Avatar
Liked: 26
It's $100 difference between the 4gb and the 250gb models. Between the time invested into researched and then ordering a hdd and then the time to install it and hope it works. Isn't it cheaper to just spend the extra 100 bucks?
Ripeer likes this.
post #7 of 14 Old 06-29-2013, 11:30 PM
Quoted: 768 Post(s)
Liked: 1203
you could get a 320GB drive.
price shop and see if you can get a new WD scorpio drive cheap. check the xbox hacker sites. they'd be able to give more info. we're straying into a gray area here...
i've been more than happy with my refurbs from gamestop. working for years now without a problem.
post #8 of 14 Old 06-30-2013, 08:20 AM
rmalbers's Avatar
Quoted: 16 Post(s)
Thanks for that about being able do use the hard drive from my old white dead 360, I've been thinking about getting a 4 gb 360 E. I figured I would have to just sell the old a get a new drive. BTW: That old 360 drive is a Gamestop refurb and it worked fine until the old 360 quit! I've seen new hard drive cases for cheap somewhere.
rmalbers is offline
post #9 of 14 Old 06-30-2013, 11:05 AM
Ripeer's Avatar
Liked: 46
I would have to second that. Really wouldn't it be easier to put in some overtime at work and buy a 250/320gb xbox 360?
Isn't there also the risk of getting your 360 banned?
Ripeer is offline
post #10 of 14 Old 06-30-2013, 05:43 PM
UHD Addict
aaronwt's Avatar
Quoted: 5192 Post(s)
Liked: 3099
I got an OEM 320 GB drive close to a year ago for only $40. I see they are only around $50 right now from Amazon. Much cheaper than paying an extra $100 to have it included with the system. I have not had any problems with this OEM drive. It works just as well as the drives that came with my other 360 systems
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #11 of 14 Old 07-01-2013, 10:56 AM
americangunner's Avatar
Liked: 288
I also use this kind. The only thing you can't do is play original Xbox games, but it works for everything else.
XBL: xGunner26x
PSN: AMER1CAN_GUNNER
Steam: xGunner26x
americangunner is offline
post #12 of 14 Old 07-01-2013, 11:43 AM
Quoted: 768 Post(s)
Liked: 1203
you can play original Xbox games if you install the missing partition (that contains the profiles for the emulator) that the Chinese fakers didn't put on. the guide is at same places that tell you how to make your own drive.
post #13 of 14 Old 07-02-2013, 09:46 AM
splatee's Avatar
Quoted: 30 Post(s)
I used my 250 gig drive from the original 360 on my slim 4g. It is easy to do there are some guides out there on how to do it. All you do is take the the hard drive out of the case and you can slide it into the slim. You don't need slim type case for it. You can pick up the hard drive at game stop for cheap when they run one of there sales, or get one off eBay. Also by doing it this way the Xbox slim recognizes it with no problem because it is a microsoft drive.
splatee is offline
post #14 of 14 Old 04-25-2014, 02:55 PM
Stewie67's Avatar
I have a 360 live 4 gb with a 250 black scorpion hd installed. I put that in my self. I have another xbox 360 and I want to install another hd. Can't remember if I hdcracked my first one, but I don't think I did. I thought i just installed it and then formatted it from my xbox.
My question is, I bought a 750 gb blue scorpion hd and installed that one, but the xbox didn't read it. Does anyone know if only blacks work or can i use a blue, but has to be small? I am sure I just installed it and then formatted it though xbox. No connecting it to computer and doing a crack. Hoping someone can help me out. Thanks.
Stewie67 is offline
Reply Xbox Area
