XBox 360 storage Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 07-22-2013, 06:33 AM - Thread Starter
Ripeer's Avatar
Liked: 46
I just dipped below 70gb free on my 360, I was wondering what options I have? I have a new xbox 360 slim. Am going to have to pick and choose my installed games or can I use an external HDD like (I believe, been awhile since I had one) a PS3?
Ripeer is offline
post #2 of 15 Old 07-22-2013, 06:57 AM
pcweber111's Avatar
Quoted: 30 Post(s)
Liked: 267
What size HDD do you have? If you have the largest size, 320GB, you're either in pick and choose mode or if you have other media on the drive move it to an external drive and save the internal drive for just games/dlc. Unfortunately the 360 doesn't allow external drives for games. Neither does the PS3 though. The PS3 allows you to use your own drive which I wish MS would implement. The One will allow an external drive to function as a game drive though which will be nice.
Ripeer likes this.
pcweber111 is offline
post #3 of 15 Old 07-22-2013, 05:48 PM
Quoted: 1176 Post(s)
Liked: 970
You can use external drives for games on demand and arcade games, if you have any of those you can always move them over.
One of the greatest posts I have read
benjamin-benjami - http://www.avsforum.com/forum/142-pl...l#post24609271
emartins is offline
post #4 of 15 Old 07-22-2013, 08:00 PM
pcweber111's Avatar
Quoted: 30 Post(s)
Liked: 267
How do you get around the 16GB limit? I mean there are ways to make it work but for all intents and purposes I'm correct. MS really doesn't want you adding storage willy nilly to the 360, something they've rectified with the One.
post #5 of 15 Old 07-22-2013, 08:27 PM
Liked: 970
Its 32GB now they allow. I just go to the game and hit move. It moves it over for me just fine. I have yet to try the install from game discs so I am not sure if that works or not.
emartins is offline
post #6 of 15 Old 07-23-2013, 06:56 AM
mboojigga's Avatar
Quoted: 627 Post(s)
Liked: 858
http://support.xbox.com/en-US/xbox-360/accessories/storage
half way down you can see what all your options are for storage. The USB drive is the same function as the hardrive excluding music and original xbox games.
Ripeer likes this.
The 5.0 is here
mboojigga is online now
post #7 of 15 Old 07-23-2013, 07:04 AM
pcweber111's Avatar
Quoted: 30 Post(s)
Liked: 267
Huh that's cool, didn't know that. I was working off old information. Good to know they made it somewhat easier.
post #8 of 15 Old 07-23-2013, 11:08 AM
JuiceRocket's Avatar
Quoted: 50 Post(s)
Liked: 41
Do you have to use the specific Xbox 360 flash drives, and if so, do they have 32gb flash drives?
-JR
JuiceRocket is offline
post #9 of 15 Old 07-23-2013, 11:10 AM
mboojigga's Avatar
Quoted: 627 Post(s)
Liked: 858
-JR
Not at all. Just about any flash drive will do.
The 5.0 is here
post #10 of 15 Old 07-23-2013, 11:24 AM
Quoted: 50 Post(s)
Liked: 41
Awesome, thanks!
-JR
post #11 of 15 Old 07-23-2013, 12:54 PM
onlysublime's Avatar
Quoted: 821 Post(s)
Liked: 1384
I have a 32GB drive and a 16GB drive installed in addition to the 250GB and on-board 512MB. They're okay for playing games from. But man, installing game discs to them is probably the most painful gaming experience ever because of how long it takes to write to typical flash drives.
onlysublime is offline
post #12 of 15 Old 07-23-2013, 02:38 PM
Quoted: 50 Post(s)
Liked: 41
Do you have them just plugged in at all times? I've got a whopping 2.5 gigs left on my Xbox (120gb HD), and it'd be great to move a few of my games on demand loads off the HD.
-JR
post #13 of 15 Old 07-23-2013, 04:07 PM
Quoted: 821 Post(s)
Liked: 1384
-JR
yes, they both are connected 24/7 to the front USB ports of my 360 Jasper. which means I have no free ports anymore since the Kinect takes up the rear USB. So if I ever need to plug something in, I do have to remove one of them and thus lose those games until I plug the stick back in. That's why all my saves are in the cloud or the hard drive.
Luckily, I think the only wired controller I have is the old Guitar Hero white Xplorer. And that only comes out with a full party as I have a couple wireless guitars.
post #14 of 15 Old 07-23-2013, 04:39 PM
Liked: 970
You dont have any USB ports in the back? I have 3 extra ones in the back. Does the kinect block the other 2?
emartins is offline
post #15 of 15 Old 07-23-2013, 04:49 PM - Thread Starter
Ripeer's Avatar
Liked: 46
He has an older Xbox that only has 3 ports. 2 front 1 rear.
Ripeer is offline
Reply Xbox Area
