Xbox 360 always on - wireless lan / bluetooth - AVS Forum | Home Theater Discussions And Reviews
Old 08-22-2013, 07:29 AM - Thread Starter
noos@xp37's Avatar
Hello,
It can be considered general knowledge, that a "cable" controller gives a better latency in games than a cordless controller. So I wanted to find out if a cordless controller uses an "USB recharge cable" for communication, if the cable is connected. Therefor I used I a high frequency detector as it will visualize any emissions. Surprise surprise surprise: You will see in the small clips, that the PS3 Controller stops emitting when the USB cable is attached, while the XBOX 360 controller continues to communicate via bluetooth. But but but, that was not the big surprise. The surprise was that both consoles, even if wireless lan was deactivated, where emitting at full strength wlan radiation. Even if the console are in standby! "Always on" - somehow in this console generation too.
Xbox 360 emission test - wireless lan always on:
http://www.youtube.com/edit?ns=1&video_id=Pb9lM5LqUUA
XBOX 360 controller bluetooth emission test for latency optimization:
http://www.youtube.com/watch?v=aCQ84Z-w0WU
PS3 controller bluetooth emission test for latency optimization and wireless lan always on:
http://www.youtube.com/watch?v=AxfGTCaH7lQ
Best regards
noos@xp37 is offline
Old 08-22-2013, 10:26 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Are you sure you just weren't picking up latent wireless signals from all the other devices around when testing the consoles?
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
Old 08-22-2013, 10:27 AM
onlysublime's Avatar
Quoted: 770 Post(s)
Liked: 1204
your 360 controller has bluetooth? amazing!
onlysublime is online now
Old 08-22-2013, 10:34 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
360 controllers run in the same 2.4ghz frequency range as BT, so for the purposes of what he's testing, it doesn't matter what the communications protocol is.
bd2003 is offline
Old 08-22-2013, 12:00 PM - Thread Starter
noos@xp37's Avatar
Good question, but impossible. Signal strength is decreasing with distance from it´s source. The device I use for the tests gives precise readings, especially as is stops working when in contact wih the source (when the singnal strentgh is higher than the device could measure).
Tomb Raider Ps3
