Xbox One 7.1 surround - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-27-2013, 02:54 AM - Thread Starter
I am looking to setup a home theater system, using only my Xbox one. Not really interested in TV or blu ray players, mainly because the Xbox can handle blu rays itself, and not a huge fan of TV anyway
My only hiccup is with surround sound, i believe the Xbox outputs 7.1 surround through it's optical out, not sure about DTS and DTS HD and other codec support...
I am confused as to how i can connect a 7.1 speaker system with the Xbox one. Most AV receivers are grossly overpriced, costing as much if not more than the Xbox itself, for what i want from them, which is effectively just an optical to 7.1 connector.
are there any other options i have to connect the Xbox to a 7.1 surround sound system?
thank you
Sean Bugeja is offline
post #2 of 8 Old 08-27-2013, 07:28 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
The Xbox one will output a max of 5.1 Dolby digital or DTS over optical. You can upmix that to 7.1, but if you want real uncompressed 7.1 or any of the HD codecs, you need to use HDMI.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #3 of 8 Old 08-27-2013, 07:51 AM - Thread Starter
as far as I know, the Xbox one can support up to 7.1 surround sound, (source: http://en.wikipedia.org/wiki/Xbox_One) i agree that HDMI would be the best option, but the X1 will be connected to my optoma HD131x, as far as i know that can't output surround sound no?
post #4 of 8 Old 08-27-2013, 08:04 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
The Xbox one supports 7.1 output over HDMI only. It's not the best option, it's the only option.
Something has to be driving these speakers, if its not a receiver, then what?
bd2003 is offline
post #5 of 8 Old 08-27-2013, 08:11 AM - Thread Starter
heh fair enough, my knowledge is quite limited in these things, i just thought that maybe the sound could just conveniently go from the Xbox into these 8 speakers. i work with computers mainly, and sound is usually as simple as plugging the correct jack hah xD i apologize for my ignorance on the subject,
so i suppose there is no way around an AV receiver? in which case, any suggestions for decent budget receivers?
post #6 of 8 Old 08-27-2013, 08:22 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Well whenever you have speakers, something needs to provide the power to them. Computer speakers are usually self powered or powered by the sub. If you just planned on buying a 7.1 home theater in a box, it probably has its own receiver with it. If youre looking to buy separate components, I'm sure you could find good recommendations in the audio subforums.
bd2003 is offline
post #7 of 8 Old 08-27-2013, 08:26 AM - Thread Starter
cheers for the info m8. i think seperate components is a better option for me, more flexibility in choosing.. i'll take a look at the sub forums. thanks again for your help.
post #8 of 8 Old 08-27-2013, 01:08 PM
UHD Addict
aaronwt's Avatar
Quoted: 5192 Post(s)
Liked: 3099
optical does not handle discrete 7.1 or 6.1 audio. It can handle matrixed 6.1 audio or discrete 5.1 audio. But then optical is also an old legacy format. But certainly still in wide use.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
Reply Xbox Area
