xbox one HDMI issue? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-29-2013, 05:08 AM - Thread Starter
AzuluzA's Avatar
Hey guys a quick question for anyone here, I read online that the new Xbox one will not have the option to connect component cables. This being said im not sure if I should do a new HDMI cable run into my ceiling to the projector or if there is a HDMI to Component converter I can use. Any suggestions? Or should I just go in and replace all my lines from component to HDMI for all my other accessories, i.e. TV, 360, ps3?
AzuluzA is offline
post #2 of 5 Old 10-29-2013, 05:48 AM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
Do you own an AVR? Why not buy one that can switch your source with only one HDMI cable to your projector. If you're running a projector I would hope you have a surround setup.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #3 of 5 Old 10-29-2013, 06:32 AM - Thread Starter
AzuluzA's Avatar
yea I have an ONKYO 7*** model, Just dont know how easy the run will be , its in my basement and cable runs through ceiling down to front left of projector screen.
AzuluzA is offline
post #4 of 5 Old 10-29-2013, 10:08 AM
mboojigga's Avatar
Quoted: 590 Post(s)
Liked: 822
I would think the investment would be worth it to add more lines for HDMI for the future products you have coming into the home.
The 5.0 is here
mboojigga is online now
post #5 of 5 Old 10-29-2013, 11:48 AM - Thread Starter
AzuluzA's Avatar
Yea your right man, I guess I will lock myself in my basement this weekend and run the cable through, hopefully its easy enough. Might use one of the existing component cables as my pull string.
AzuluzA is offline
Reply Xbox Area
