Xbox One Kinect Extender - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 77Likes
post #271 of 891 Old 03-27-2014, 08:04 PM
ZaZeeMan's Avatar
Looks like we may be able to use an extension, if the power supply for the Windows version is sold separately. Maybe just with an active USB 3.0 extension? Although I only see a 15 footer on Monoprice... frown.gif
http://blogs.msdn.com/b/kinectforwindows/archive/2014/03/27/revealing-kinect-for-windows-v2-hardware.aspx
Gamertag: Big Turk
ZaZeeMan is offline
post #272 of 891 Old 03-27-2014, 08:08 PM
onlysublime's Avatar
Quoted: 788 Post(s)
Liked: 1257
Microsoft is about to release Kinect 2.0 for Windows. And it comes with a power supply and a standard USB connection for the PC... which means you will soon be able to extend the Kinect for Xbox One as well... It looks like a similar setup to the original Kinect for PC. The proprietary cable will plug into the hub. The USB 3.0 cable plugs in on the other end and it's the standard USB 3.0 that you can extend...
onlysublime is online now
post #273 of 891 Old 03-28-2014, 04:36 AM
Neocleous's Avatar
This seems like the first positive step forward.
I think the only way MS are going to sell this separately though is if we put pressure on them because otherwise I can't see why they would sell this separately
Neocleous is offline
post #274 of 891 Old 03-28-2014, 06:21 AM
Montdj's Avatar
Quoted: 18 Post(s)
Unless the xbox one will take the sensor input on the usb port and not the dedicated port the box would work other wise one would still have to convert it back from usb to the special kinect usb plug.
If all that makes any sense at all. one could use that box to extend it but you would still have a standard usb plug at the xbox end.
Montdj is offline
post #275 of 891 Old 03-28-2014, 06:26 AM
Neocleous's Avatar
That's very true but I think because the Kinnect connection is essentially a USB 3 connection with added power it shouldn't be an issue but I stand to be corrected because there is only one way to find out.
post #276 of 891 Old 03-28-2014, 08:50 AM
Quoted: 788 Post(s)
Liked: 1257
you wouldn't need the pressure. when the kinect power supply first came out for the 360, it was $39.99 from Microsoft. But once it was on the market, the Chinese companies copied it and you could buy it for $9-19 at places like Amazon. I'm sure the Chinese will do it once again when the new hub is out.
post #277 of 891 Old 03-28-2014, 08:52 AM
Quoted: 788 Post(s)
Liked: 1257
the "special" port is not really special. and it'd be like with the 360. If you bought the 360 S, there was no power supply with the kinect and you had to plug it into the dedicated port. However, if you did have the power supply, the Kinect on the 360 worked on the regular USBv2 port as well for the 360 S. you could entirely skip the "special" port on the 360 S and get the Kinect to work.
post #278 of 891 Old 03-28-2014, 10:42 AM
mikeloxlong's Avatar
Liked: 146
I wonder how much this is going to cost.
I Geez Zeus Me
My life is richer for not knowing what goes on on reality television
mikeloxlong is offline
post #279 of 891 Old 03-28-2014, 11:52 AM
newfmp3's Avatar
Quoted: 286 Post(s)
Liked: 259
I'd be willing to bet that Monoprices solution is going to be a power brick and usb 3 extender. Nothing new here, but that above kind of confirms its sorta possible.
wkearney99 and Rebel975 like this.
newfmp3 is offline
post #280 of 891 Old 04-02-2014, 08:45 AM
turls's Avatar
Quoted: 476 Post(s)
Liked: 204
So if you need to convert this to ethernet there is still not going to be any option because there are only converters for USB 1 and USB 2, and the USB 2 ones are still super expensive.
EDIT: I missed this post because I haven't been following the thread.
http://www.avsforum.com/t/1498930/xbox-one-kinect-extender/240#post_24503933
So there is a way to extend USB 3.0 without using USB 3.0 cabling--but it requires fiber ?!
I guess the question is does having the Kinect for Window 2.0 and the power hub help make using that very expensive fiber device easier than without it.
How did we get to _serial_ data for a gaming device requiring fiber...nuts.
Matt
turls is offline
post #281 of 891 Old 04-13-2014, 07:09 PM
newfmp3's Avatar
Quoted: 286 Post(s)
Liked: 259
I am beginning to think this can't be done. Nobody out there has done it yet? Seems odd. I am getting to the point where I am considering selling the Kinect.
newfmp3 is offline
post #282 of 891 Old 04-14-2014, 03:24 AM
DavidinCT's Avatar
Quoted: 245 Post(s)
Liked: 69
What is the point of trying to sell it ? You wont get much for it right now as everyone has one.....
I'm in the same boat, sitting in the box with the plastic still on it....
Has their been any new rumor here ?
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
post #283 of 891 Old 04-29-2014, 11:08 PM
lfenske's Avatar
I'm looking to make my kinect cord shorter. Will I need both of the fertile cores? Are the shields giving you any problems to work with? From what I can see there are only three shields.
P.S. For anyone looking to extend the cord you have to make sure that four wires that are twisted together stay that way. Your extensions need to be tightly twisted clockwise for each of those two wire pairs.
lfenske is offline
post #284 of 891 Old 05-03-2014, 01:12 PM
JPHCCFC's Avatar
Quoted: 12 Post(s)
I finally succumbed to Microsofts advice and moved my av rack closer to my screen. I got fed up waiting for an extender and I actually prefer my setup now. The Kinect is great had some fun with Xbox fitness and the voice commands are pretty good. I like the auto sign in too.
tampabuc likes this.
JPHCCFC is offline
post #285 of 891 Old 05-03-2014, 07:14 PM
newfmp3's Avatar
Quoted: 286 Post(s)
Liked: 259
Good for you.
Sadly not an option for me. Even if I did move it from AV room to the room with my tv, darn cable is still too short to run through wall to tv. It is just too damn short.
newfmp3 is offline
post #286 of 891 Old 05-04-2014, 03:31 PM
JPHCCFC's Avatar
Quoted: 12 Post(s)
Newfmp3 could you put the Xbox in the TV room and then purchase 2 long hdmi cables? One to your TV and then one to your cable box?
JPHCCFC is offline
post #287 of 891 Old 05-11-2014, 05:28 AM
JustBusiness's Avatar
Quoted: 43 Post(s)
No way to extend over Cat anything right now, must be fiber. Costs big $$$$ but should work IF Xbox one will accept Kinect in normal USB port instead of proprietary port.
JustBusiness is offline
post #288 of 891 Old 05-11-2014, 06:16 AM
wkearney99's Avatar
Quoted: 332 Post(s)
Liked: 130
Unless you know of a solution, don't just toss out fiber as an alternative. Other than in pretty rare circumstances it's entirely unnecessary. Going between buildings or through harsh environments are about the only reasons to ever bother with the significantly higher costs of fiber. Not to to mention it'd likely be way too fragile for a consumer electronics gaming situation. Sure, SPDIF audio uses it but even then you're dealing with those ridiculously crappy sockets on all the gear. Fiber gets trotted out all the time as some sort of solution... usually by folks not having actually dealt with supporting it.
Sufficient speeds can be attained using the right combination of copper and circuits. As yet, though, no one has delivered a solution.
wkearney99 is offline
post #289 of 891 Old 05-13-2014, 01:35 PM
Craer's Avatar
Craer is offline
post #290 of 891 Old 05-13-2014, 06:24 PM
BiggAW's Avatar
Quoted: 538 Post(s)
Liked: 137
And the Xbox One is available without a Kinect... Guess the Kinect isn't so important after all...
BiggAW is offline
post #291 of 891 Old 05-14-2014, 12:54 PM
DavidinCT's Avatar
Quoted: 245 Post(s)
Liked: 69
Has anyone found any updates on this ? I have had it, I got a Day One Kinect still sitting in the box because the cable is about 15' too short.... this is getting really old, I would like to play with this with out having to re-lay out my room....WTF...
-Dave
MCSE 2003
post #292 of 891 Old 05-14-2014, 02:19 PM
BiggAW's Avatar
Quoted: 538 Post(s)
Liked: 137
There's nothing... other than the fact that it's not really needed anymore, so that basically solves the problem...
BiggAW is offline
post #293 of 891 Old 05-14-2014, 04:30 PM
UHD Addict
aaronwt's Avatar
Quoted: 5601 Post(s)
Liked: 3393
Nothing changed. It was never required before.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #294 of 891 Old 05-14-2014, 06:38 PM
Backlash's Avatar
Please post a request here: http://forums.xbox.com/xbox_forums/xbox_feedback/f/2606/p/1626988/4716205.aspx#4716205
Per support, this thread is where they look for support updates.
Nunc lento sonitu dicunt, morieris.
Now this bell tolling softly for another, says to me, Thou must die.
-John Donne
My Home Theater (QTVR)
"Thirst is worse than homesickness"
Backlash is offline
post #295 of 891 Old 05-15-2014, 08:41 AM
DavidinCT's Avatar
Quoted: 245 Post(s)
Liked: 69
Not really, as with the new release of the not included Kinect going to be $399, As I see it, I have a $100 item sitting in the box that I cant use because of a stupid cable. Maybe they should provide customers who ordered it and cant use it a $100 refund for it. That would solve the problem.
Been there, done that, Even hit up #XboxSupport on twitter about every month or 2, just hear that "We're listening to your feedback" but, no news or updates....
Ugh...I just want to be able to use a item I paid for, is that really too much to ask ?
-Dave
MCSE 2003
post #296 of 891 Old 05-15-2014, 02:51 PM
BiggAW's Avatar
Quoted: 538 Post(s)
Liked: 137
True, it sucks to be out $100 on a useless piece of junk. They should have thought about that when they designed the thing in the first place. Seems like a pretty obvious problem that people are going to run into.
BiggAW is offline
post #297 of 891 Old 05-15-2014, 04:52 PM
Anthony1's Avatar
Quoted: 593 Post(s)
Liked: 354
Monoprice doesn't have an extender for this thing yet ?
Man, if that's the case, then I guess no reason for me to pick up one of these cheap Kinect 2.0's on Ebay. They are going for only $55 or so shipped. But I'm only interested in getting an extra one to have it in the theater room, but if there is no Kinect extender cable yet, then that won't work. Damn, are you kidding me ? It's like 6 months later now, right ? How could there be no extender ?
Anthony1 is offline
post #298 of 891 Old 05-15-2014, 06:41 PM
newfmp3's Avatar
Quoted: 286 Post(s)
Liked: 259
complaining here isn't going to fix it sadly
newfmp3 is offline
post #299 of 891 Old 05-15-2014, 06:52 PM
UHD Addict
aaronwt's Avatar
Liked: 3393
Really?!?! Only $55? I wouldn't mind picking up an XBOne Kinect for that price. Then I could have it to leave at my GFs house. But then I would still need to wait for a large price drop on a Kinect-less XBOne before I pick up a third system to use for carrying back and forth to her house.
aaronwt is offline
post #300 of 891 Old 05-15-2014, 07:43 PM
totalownership's Avatar
Quoted: 188 Post(s)
Liked: 271
Glad to see you back in the xbox forums since ... never.
So your first time in here just to post these replies. Classy.
AT HAMMOND ROBOTICS WE'RE BRINGING THE FUTURE ... HOME
PROTOCOL 3: PROTECT THE PILOT
totalownership is offline
Reply Xbox Area
Xbox One Console Standard Edition
