Xbox One Kinect Extender - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 74Likes
post #121 of 884 Old 12-09-2013, 03:25 AM
GazzaS's Avatar
Originally Posted by jagr200 View Post
Hopefully nobody gives to that kickstarter. I feel like that will just be a way for him to snag a system. Monoprice has said early next year. USBfirewire.com has a team working on it. Someone is going to get it going for us. No reason to waste money on a "donor system" for something that will be done professionally soon.
Hi jagr200,
I think that's a little unfair. We are all in the same boat and I am just trying to find a solution.
It will be great if Monoprice produce a cable, however many of us will need custom cables to go behind walls and to trunking (plus it's always good to have several choices). I have CAT6 cable all over the house and will need t balun to pass the signal all over the house. The idea of the kickstarter was to develop a full guide on what the cable consist of, the pin out diagram and guides on how to extend to the 50m point. I need to fund the project as I can't afford to go a buy an xbox one to just destroy which I'm sure a lot of us can't. Of course you are fully entitled to your opinion, but please do not put others down and their projects to try and find solution.
Cheers,
Gary
GazzaS is offline
post #122 of 884 Old 12-09-2013, 03:31 AM
GazzaS's Avatar
Originally Posted by kylenewman View Post
I have to agree with you.
I tore into my kinect was unsuccessful and was able to just solder it back together and it's working fine. There is absolutely no reason to buy an entire system to experiment. There is no risk in screwing up the kinect or xbox one if you know what your doing.
Hi kylenewman,
I thought from your original post that you destroyed the kinect from cutting the cable. Are you saying that soldering it back it all worked? Were you able to simply extend all the wires over a small distances using electrical wire or did nothing work?
Even if it is the case that you soldered it back together and it worked, there is always a risk that I completely destroy the sensor and the xbox one from a mistake. I was also going to completely dismantle the kinect and xbox so I could post images and diagrams of the internals so us and people like us can upgrade, hack and extend the console.
I was also going to say, that if you did destroy the kinect was there any chance you could send it to me so I can investigate.
Cheers,
Gary
GazzaS is offline
post #123 of 884 Old 12-09-2013, 03:37 AM
GazzaS's Avatar
Originally Posted by iakouben View Post
Gary, why take it to kickstarter? If you're going to be doing a guide (and hopefully you manage to do it) post it to instructibles
Hi iakouben,
My idea of the kickstarter was to fund the tear down of the kinect so that I could create guides and instructables on how to take the console and kinect apart, how to extend the Kinect cable (primary goal), how to upgrade/replace components (e.g. hard disk, RAM, fans, disk player) and provide diagrams of the system. I can't afford to just buy an xbox one for this project with the risk of destroying it. My son has one for Christmas, but it would devastate him if I ended up destroying it wink.gif Plus remember, as soon as I cut a cable or open up a device I void the warranty and after my experiences with the 360, the warranty is worth its wait in gold wink.gif
Cheers,
Gary
khackshaw likes this.
GazzaS is offline
post #124 of 884 Old 12-09-2013, 03:53 PM
kylenewman's Avatar
Originally Posted by GazzaS View Post
Hi kylenewman,
Cheers,
Gary
I was able to solder everything back together. It works perfect it is tedious work but if your even a decent solderer it shouldn't be hard.
kylenewman is offline
post #125 of 884 Old 12-10-2013, 04:59 PM
Craer's Avatar
Hi iakouben,
Cheers,
Gary
Ill just leave this here for ya:
Kinect 2
Xbox One
ELMO45 and Onk Yo like this.
Craer is offline
post #126 of 884 Old 12-10-2013, 08:24 PM
kylenewman's Avatar
http://imgur.com/a/HHOj0
Kinect 2.0 for pc is showing up to developers. It includes a kinect 2.0 with usb3 adaptor and external power supply. It would be interesting to see if plugging the pc version into the standard USB port on the xbox one would recognize the kinect like it would on the 360.
post #127 of 884 Old 12-11-2013, 01:54 AM
GazzaS's Avatar
Found a tear down of that as well:
https://i.cloudup.com/0GXiqsIcpa-3000x3000.png
Looks like there is a map to a standard USB 3 connection.
Interesting group that is hacking the Kinect for Windows 2.0:
https://groups.google.com/forum/#!topic/openkinect/zlpXb-S9HSc
Cheers,
Gary
GazzaS is offline
post #128 of 884 Old 12-11-2013, 01:56 AM
GazzaS's Avatar
Thanks Craer. Does not show the level of detail we would need, but is still useful information.
Gary
GazzaS is offline
post #129 of 884 Old 12-11-2013, 09:47 PM
makan01's Avatar
I know we are all trying to get Monoprice, MS, or 3rd party entrepreneurs to build a cable for us. I for one could not wait. My case is a bit particular as I have a good gap in the back of my TV because of the OMNI mount I am using. So I proceeded to build a shelf for the XBOX One behind the TV. I got inspired by an Instructable.com project using a bookend as a shelf and went to staples and bought: http://www.staples.com/MMF-Industries-9-inch-High-Black-Deluxe-Bookends/product_408682 for $10, some Drywall anchor screws, a rail from home depot. Here are the results:
Back
Side
Front
It is not perfect by it has a 100% Wife acceptance factor. As for me I am still waiting for the long cable, but now I can be more patient.
I hope this post helps some of you folks with similar use case.
migraine24-7 and Spartan313 like this.
Toe-Knee
makan01 is offline
post #130 of 884 Old 12-11-2013, 10:42 PM
mboojigga's Avatar
Quoted: 588 Post(s)
Liked: 822
Back
Side
Front
MS specifically stated the One is designed to be horizontal.
The 5.0 is here
mboojigga is offline
post #131 of 884 Old 12-12-2013, 12:56 AM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
LMAO. Nice setup
bori is offline
post #132 of 884 Old 12-12-2013, 03:44 AM
Two Cents's Avatar
Quoted: 17 Post(s)
+1 for innovation but yeah not ideal.
Samsung JS9000. Epson TW-9100, Alienware Alpha i7. Xbox one, Samsung UBD K8500.
Two Cents is offline
post #133 of 884 Old 12-12-2013, 02:11 PM
turls's Avatar
Quoted: 465 Post(s)
Liked: 194
Ok, so now it is looking like it is a USB 3 connection when the decent USB 2.0 extenders that allow us to use regular ethernet cable for Kinect 1.0 still cost over $200? The regular extender cables will not work for me. My conduit is too tight.
Going to be waiting this out or setting up a rack closer to the screen I guess.
Matt
UMR on HDR vs 4K: The benefit of greater saturation and luminance capability is...not very evident in all images unlike more pixels which can be seen in every scene.
turls is offline
post #134 of 884 Old 12-12-2013, 04:00 PM
agnathra's Avatar
Quoted: 28 Post(s)
for me it was
40ft Ultra Slim Series High Performance HDMI® Cable w/ RedMere® Technology http://www.monoprice.com/Product?c_id=102&cp_id=10255&cs_id=1025506&p_id=9431&seq=1&format=2
and
40ft Optical Toslink 5.0mm OD Audio Cable http://www.monoprice.com/Product?c_id=102&cp_id=10229&cs_id=1022901&p_id=6735&seq=1&format=2
-sigh-
- Chris
agnathra is offline
post #135 of 884 Old 12-13-2013, 06:35 AM
DavidinCT's Avatar
Quoted: 243 Post(s)
Liked: 67
Yea, and they pubicly said, do it your own risk...
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
post #136 of 884 Old 12-13-2013, 07:24 AM
ksbarnz's Avatar
[/quote]
Originally Posted by agnathra View Post
for me it was
and
-sigh-
Ended up going the same route as you with two of the 40ft Monoprice HDMI cables mentioned above. Hopefully a real extender cable is released soon, because I do not like having my xbox as the only piece of AV equipment under my 135" screen in my theater room. The ability to use the kinect voice commands is worth it for the time being though.
Subbed for updates on a solution.
ksbarnz is offline
post #137 of 884 Old 12-13-2013, 09:14 AM
bem1's Avatar
bem1 is offline
post #138 of 884 Old 12-14-2013, 03:48 PM
gjlowe's Avatar
Mine would not play Blu-rays or game discs when I placed it vertically. Not recommended though I applaud your innovation.
gjlowe is offline
post #139 of 884 Old 12-14-2013, 10:05 PM
ELMO45's Avatar
He could always just go the digital download route for movies and games. This way he wouldn't need to worry about the vertical issue if he never uses the disc drive, might be worth it for keeping the slick install.
ELMO45 is offline
post #140 of 884 Old 12-15-2013, 06:59 AM
UHD Addict
aaronwt's Avatar
Quoted: 5190 Post(s)
Liked: 3099
But what about the heat exhaust? The XBOne is designed to exhaust the heat straight up. WHich is also another reason why it is supposed to be horizontal.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #141 of 884 Old 12-15-2013, 07:31 AM
ELMO45's Avatar
He has a large enough gap between the TV to vent the Xbox, plus open air all-around, probably better venting than people's AV cabinets or shelves. The only issue is the disc drive for vertical mounting as the fan will vent it no matter what angle as long as the top isn't blocked. Also the hard drive wouldn't be an issue either as that will work vertically as well (just like a external hard drive where the HD is vertical or the last Xbox).
ELMO45 is offline
post #142 of 884 Old 12-15-2013, 08:25 AM
Spartan313's Avatar
I applaud his efforts too, but how ridiculous is it that we have to resort to all of this nonsense. C'mon Monoprice...all I want for Christmas is another 40 feet!!
GazzaS and migraine24-7 like this.
Spartan313 is offline
post #143 of 884 Old 12-15-2013, 07:55 PM
eecyclone's Avatar
Since the kinect cable is removable, I actually think a replacement cable would be better than an extension cable. That way I can run the 30+ foot replacement cable in my wall and not have an extra 9 feet coiled up or have the connection burried in my wall.
Marc Chabot likes this.
eecyclone is offline
post #144 of 884 Old 12-15-2013, 08:41 PM
makan01's Avatar
I agree with you Spartan, it is ridiculous to have to resort to these steps to integrate the XBOX in an environment we worked so hard to keep organized, not to mention, avoid the wrath of our aesthetic committee smile.gif
I just want to clarify that I did play BDs and CDs (I have not tried games yet) on my XBOX in the vertical position but on some CDs I had to try a couple of times to get it right. I agree with you all that it is not ideal but it will have to do until someone comes up with a better solution. As far as heat venting, as ELMO45 said there is enough gap and the placement of the Xbox at the edge of the TV was such that it is dissipating heat away from the TV.
I appreciate the +1s.
Toe-Knee
makan01 is offline
post #145 of 884 Old 12-16-2013, 12:25 PM
DavidinCT's Avatar
Quoted: 243 Post(s)
Liked: 67
Does the cable just unplug from the back of the Kinect ? Wonder if we can get a replacement cable so we can cut up to try things with...if they were like $15-20 I would grab a few to screw around with to see if I could make it work...
-Dave
MCSE 2003
post #146 of 884 Old 12-16-2013, 12:52 PM
eecyclone's Avatar
I don't know about that. I suppose you could call Microsoft Support and tell them your vacuum sucked up your kinect cable or your dog chewed one of the ends off and you need a replacement cable. I'm sure they could send you just the kinect cable.
DavidinCT likes this.
post #147 of 884 Old 12-16-2013, 08:09 PM
kylenewman's Avatar
I'm wondering what happens if you hooked a standard usb3 B cable into the kinect and plug that into the usb3 port and added power separately to the kinect.
I was trying to get someone with a kinect 2.0 pc dev version to plug the usb3 cable into the xbox one. I want to see if it will recognize the kinect over the regular usb3 ports like the Xbox 360 did
post #148 of 884 Old 12-19-2013, 07:58 AM
mikeloxlong's Avatar
Liked: 146
subbed, looking for a Kinect extension cable as well. Here's hoping that it's not as expensive as it looks like it will cost.
I Geez Zeus Me
My life is richer for not knowing what goes on on reality television
mikeloxlong is offline
post #149 of 884 Old 12-24-2013, 02:45 PM
rightintel's Avatar
Quoted: 547 Post(s)
Liked: 185
rightintel is offline
post #150 of 884 Old 12-25-2013, 09:55 AM
jedimastergrant's Avatar
Quoted: 544 Post(s)
Liked: 266
Subbed. Another projector owner with equipment outside of room. I need at least 25' extension. Fingers crossed for mono price to come through soon.
My room is newly finished and what a shame to have the only piece of gear muddying up the stage be the xbox one. I am probably going to go ahead and mount it in my rack and go without the kinect for awhile.......boo.
jedimastergrant is offline
Reply Xbox Area
Xbox One Console Standard Edition
