XBOX ONE VIDEO SETTINGS (bit depth) - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 77 Old 11-21-2013, 07:05 PM - Thread Starter
sfumat0's Avatar
Quoted: 22 Post(s)
I didnt see a thread for "picture" settings yet, thought I would start one.
I went to support page to get ready for tonight.
I saw a setting for BIT DEPTH, options are 24, 30, 36.
I have a Samsung F8500, should be one of the more capable TV's but cant find what it is capable of bit wise, not sure what setting to use?  Ive looked everywhere for that spec.
Any ideas?  Will setting it to high mess up picture?
What about TV specific settings, Im new to forum, and that 8500 thread is really long and they seem to get tired of gamer questions.. ;)
http://support.xbox.com/en-US/xbox-one/system/improve-video-quality
sfumat0 is offline
post #2 of 77 Old 11-21-2013, 07:23 PM - Thread Starter
sfumat0's Avatar
Quoted: 22 Post(s)
Here is link to the settings Im talking about,
sfumat0 is offline
post #3 of 77 Old 11-21-2013, 07:50 PM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
Wondering same thing. I have the Samsung f7100. I'm thinking our sets can handle 30 or 36. Settings are way different than 360.
matrix123 is offline
post #4 of 77 Old 11-21-2013, 09:09 PM
UHD Addict
aaronwt's Avatar
Quoted: 5107 Post(s)
Liked: 3041
Even my Tvs from several years ago handle 36 bit input.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #5 of 77 Old 11-22-2013, 05:11 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Even if it supports it, I don't think there's any point to enabling it.  Games are all 24-bit and movies with rare exception are all 24-bit.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #6 of 77 Old 11-22-2013, 05:34 AM
UHD Addict
aaronwt's Avatar
Liked: 3041
No different than BD players. There is no 36 bit content but I still have all my players set for 36 bit output. I've not had any issues with my setups and cables, but all my cables from Monoprice can handle 36 bit. If the HDMI cable is not capable then there can be issues. If in doubt 24 bit is fine.
aaronwt is offline
post #7 of 77 Old 11-22-2013, 05:54 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Yeah, the image should look exactly the same either way if the conversion is done correctly. I suppose there is some potential for a tiny bit of lag for that conversion to happen, or for that conversion to be done incorrectly, so I still recommend leaving it off.
bd2003 is offline
post #8 of 77 Old 11-22-2013, 08:24 AM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
So leaving it on 24 bit will reduce lag?
post #9 of 77 Old 11-22-2013, 10:15 AM
UHD Addict
aaronwt's Avatar
Liked: 3041
In my setups with other devices there is no lag difference between 24 bit and 36 bit. Or at least if there is it is certainly not perceptible.
In my main setup I run everything through my DVDO DUO and output it to the TV in 36 bit. I've never noticed any lag difference between outputting 24 bit and 36 bit. For gaming I have always used Game mode though, but that doesn't affect the bit depth of the output.
I am getting anxious for my XBOne delivery, but I am also home sick today which really sucks. Since I can't really mess with 3D movies or FPS games when I feel like this since it will make me feel even worse. So I'm hoping I will feel better by tonight, but so far I feel just as bad as when I woke up this morning.
aaronwt is offline
post #10 of 77 Old 11-22-2013, 10:56 AM
Rage Guy's Avatar
Is there any setting to adjust or correct for overscan? I have an older Sony that still has a beautiful picture, but the overscan is a bit much...
Rage Guy is offline
post #11 of 77 Old 11-22-2013, 11:17 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Theoretically, but I bet it's so tiny you'd need instruments to measure it.  But you're getting zero benefit from 36-bit as far as I can tell, so there's no good reason to enable it.
bd2003 is offline
post #12 of 77 Old 11-22-2013, 11:27 AM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
Ok. I'll check it out on 24. Any ideas on the surround sound side? 5.1 pcm vs DTS?
jak1209 likes this.
post #13 of 77 Old 11-22-2013, 12:38 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Use PCM, DTS is lossy.
matrix123 likes this.
bd2003 is offline
post #14 of 77 Old 11-22-2013, 02:59 PM
helvetica bold's Avatar
Quoted: 381 Post(s)
Liked: 232
I love that it supports deep color! PS3 does but currently the PS4 doesn't.
helvetica bold is offline
post #15 of 77 Old 11-23-2013, 09:02 PM
Birchwood's Avatar
That's true, however I recommend trying the two modes to see which one you like better (provided the game supports DTS). Personally I have never heard a PCM feed that I liked better than DTS or Dolby Digital. I really like the sound of DTS. Try both out and stick with the one you like.
Birchwood.
Birchwood is offline
post #16 of 77 Old 11-23-2013, 11:37 PM
UHD Addict
aaronwt's Avatar
Liked: 3041
I ended up setting my XBOne output for 24 bit. Since I have a TiVo connected to it which sends 24 bit too, I just left it so my video processor would just take it to 36 bit. If I have a device connected to the XBOne that sends 36 bit, like my media player, then I will switch the XBOne output to 36 bit.
aaronwt is offline
post #17 of 77 Old 11-24-2013, 10:00 PM
smithfarmer's Avatar
Liked: 46
Does your Sony have a PC input mode?
smithfarmer is offline
post #18 of 77 Old 11-24-2013, 10:34 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
There should be no reason DTS should ever sound better, it's just a lossy compressed version of the same uncompressed PCM output. I'm sure it'll still sound great, but there's no reason to use DTS if your gear supports PCM.
bd2003 is offline
post #19 of 77 Old 11-25-2013, 01:07 AM
Birchwood's Avatar
Sorry, don't know how to quote:
bd2003
"There should be no reason DTS should ever sound better, it's just a lossy compressed version of the same uncompressed PCM output. I'm sure it'll still sound great, but there's no reason to use DTS if your gear supports PCM."
I understand what you are saying and I don't know how DTS is equalized/encodeded or otherwise; however, when ever I am experimenting in my dedicated home cinema with a blu ray and my Pioneer SC-79 THX Ultra 2 Plus, I have never been satisfied with how uncompressed PCM sounds. I always end up going back to DTS HD Master audio. Likewise I like the DTS sound over the Dolby HD implementation. I'm not a fanboy or anything like that, it just sounds better to me. I know your refering to DTS compressed vs uncompressed PCM, but I still advise listening. Maybe DTS use a different method to encode that flavours the audio in a way that is appealing to me - or at least in some way modifiys the sound. What ever is going on, I prefer it.
That is why I suggested trying the different modes to see which one he likes and not get too hung up on the specs.
JR
Birchwood.
post #20 of 77 Old 11-25-2013, 01:13 AM
Birchwood's Avatar
Does anybody know what range games for the Xbox One are developed in? I have a Sony Bravia that can do all 3 modes the Xbox provides. I know because info reports "1080P" for 24 bit, "1080P 10 bit" for 30 bit and "1080P 12 bit" when 36 bit is engaged.
It occurs to me we should be matching what the games are outputting (video etc aside) to avoid any scaling of the color space - maybe the errors introduces are undetectable? If there is no lag, then wouldn't leaving the Bone at 36 bit be OK?
John
Birchwood.
post #21 of 77 Old 11-25-2013, 04:14 AM
bym051d's Avatar
Anyone noticed the bone being way too dark when deep color is selected?
When it's set to deep color, I can't change my contrast/brightness enough to see the closed eye or sun on the ms images with my PN59D8000.
bym051d is offline
post #22 of 77 Old 11-25-2013, 04:44 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
John
Games are 24-bit.
bd2003 is offline
post #23 of 77 Old 11-25-2013, 07:06 AM
BFJ 96's Avatar
Quoted: 59 Post(s)
Liked: 36
My understanding is the XB-1 Audio chip is made for DTS mixing.
Here's and article about it. Or am I redding this wrong?
http://www.highdefdigest.com/news/show/Xbox_One/PS4/DTS/The_PS4_and_Xbox_One_Utilize_DTS_to_Carry_New_Sound_Formats/13172
Sent from my Galaxy Nexus using Tapatalk
HDtigerN.O. likes this.
BFJ 96 is online now
post #24 of 77 Old 11-25-2013, 07:42 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
It's good to know that they're pushing the boundaries of what optical/DTS is capable of, but it's still just compressing what the Xbox can just send uncompressed in PCM. It's an unnecessary extra step that serves no purpose and can only potentially degrade the sound.
bd2003 is offline
post #25 of 77 Old 11-30-2013, 08:12 PM
Quoted: 381 Post(s)
Liked: 232
According to that article you should select bitstream DTS over LPCM right? So my receiver will decode the DTS-HD signal?
post #26 of 77 Old 11-30-2013, 08:57 PM
UHD Addict
aaronwt's Avatar
Liked: 3041
There is no option to bitstream lossless DTS, only lossy DTS. For lossless audio it will send either 5.1 or 7.1 pcm.
aaronwt is offline
post #27 of 77 Old 12-01-2013, 05:01 PM
Quoted: 381 Post(s)
Liked: 232
So what would be the best audio output setting for the Xbox one going into a 5.1 system?
post #28 of 77 Old 12-01-2013, 09:32 PM
UHD Addict
aaronwt's Avatar
Liked: 3041
5.1 pcm
aaronwt is offline
post #29 of 77 Old 12-02-2013, 06:54 AM
UHD Addict
aaronwt's Avatar
Liked: 3041
DTS-HD is an HD audio format. It is the equivalent of DD+. You need HDMI for HD audio. Optical can only handle legacy dd and DTS. I tried the DTS once on the XBOne HDMI output but didn't notice it being DTS-HD. I guess I should check it out again. But still lossless pcm should be better than lossy DTS-HD.
EDIT: I re-read that article and for some reason it seems to imply that DTS-HD can be sent over optical. I never heard of that before. It should be beyond the spec of SPDIF.
aaronwt is offline
post #30 of 77 Old 12-02-2013, 10:29 AM
Quoted: 381 Post(s)
Liked: 232
I've read several articles that state lossless PCM is as good as DTS-HD. It just depends where you want the audio decoded. I'll stick to PCM but try out DTS as well. I own Sonys new 1040 receiver so it should get the job done either way. smile.gif
Good article
http://reviews.cnet.com/4520-13817_7-6462511-4.html
Reply Xbox Area
Xbox One Console Standard Edition
