AV receiver problem with Xbox One - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 66 Old 03-17-2014, 10:30 PM
wonkypanda's Avatar
The problem I am having on my VSX 8231 is that 36bit does not allow me to play 24hz on BD. Anyone else have this issue?
wonkypanda is offline
post #62 of 66 Old 03-18-2014, 05:36 AM
UHD Addict
aaronwt's Avatar
Quoted: 6405 Post(s)
Liked: 3960
I don't use 24 hz because anytime the overlay comes up it has to go back to 60Hz. So I just keep it at 1080P60. Unless this behavior has changed since some of the recent updates.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #63 of 66 Old 03-19-2014, 04:59 PM
UHD Addict
aaronwt's Avatar
Liked: 3960
I see 1080P24 is fine now. I'm not sure what update fixed it. I got the April preview update yesterday. When I have it set for BD playback at 1080P24, and I go to the main menu while still playing a BD, it stays at 1080P24 instead of jumping to 1080P60 like it used to.
post #64 of 66 Old 03-19-2014, 06:56 PM
wonkypanda's Avatar
Awesome to hear. Hopefully the April updated addressed the issue plaguing, mainly, Pioneer receivers. It seems to me that there's something going on when the XBone tries to do a handshake with the receiver, which causes the image to come out distorted.
post #65 of 66 Old 07-20-2015, 07:21 AM
Liked: 0
So I am currently having a simaler problem with my Yamaha rxv477. the picture shows menus and games only any time i try to stream Netflix amazon or HBO go i lose the picture. also i replaced multiple HDMI cables which did not work also my Xbox turns my receiver on by itself every time i turn the Xbox one on. the only way that seem to fix the problem was when i plugged it into HDMI 2 on my TV leaving the HDMI one for the input of where the TV plugs in i am very confused any help would be appreciated
Basementdweller04 is offline
post #66 of 66 Old 12-29-2015, 05:40 AM
Stew4HD's Avatar
This is an odd issue. I have a Denon AVR-A100 with a Panny AE8000 projector. I never once had the X1 flickering issue.
My friend connected his X1 to a Denon AVR-X3000 and had the flickering right away. His Denon is feeding an Epson projector. I read the advice on here about setting the pixels to 36 bits and that seems to have fixed the issue though it seems that it's not really a fix but rather a workaround.
Stew4HD is offline
Reply Xbox Area
Xbox One Console Standard Edition , Pioneer Vsx 1022 K 560w 7 Channel A V Receiver
