XBOX One and Harmony Universal Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 11-23-2013, 06:02 PM - Thread Starter
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
Hi guys,
I have a couple of questions regarding the Xbox One and controlling it with a Harmony universal remote. I got my Xbox One setup and setup my Harmony One to control it but it doesn't seem to work. I should note that I have disabled Kinect as I find talking to my game console kind of ridiculous and it makes me uncomfortable that Kinect is always on, not just when the Xbox is on like with Kinect on the 360. In any case, I was wondering:
1) Does the console itself have an IR sensor?
2) If not, does Kinect have to be enabled for the IR sensor to pick up a remote command from my Harmony universal remote?
EVT is offline
post #2 of 23 Old 11-23-2013, 08:24 PM
ajax-jp's Avatar
Yes, the xbox one has a true IR receiver.
The harmony devices have all been updated and already support the xbox one.
ajax-jp is offline
post #3 of 23 Old 11-23-2013, 11:44 PM
sirjonsnow's Avatar
Quoted: 121 Post(s)
Liked: 139
My Kinect isn't even hooked up. I have the older Xbox 360 remote and it's working fine - when adding devices, it was "Game device with DVD player". I'm sure the newer remotes that you can update through the website have the correct name.
sirjonsnow is offline
post #4 of 23 Old 11-24-2013, 12:50 PM
bym051d's Avatar
Is there a way to get the xbox to "watch tv" when I turn it on with my harmony? I really need to have this as simple as possible for WAF and hate to make her do extra tasks, like "xbox watch tv."
bym051d is offline
post #5 of 23 Old 11-24-2013, 01:48 PM
spid's Avatar
Quoted: 248 Post(s)
Liked: 748
If your wife has her own account setup on the box then if all she does is watch tv the Kinect will automatically sign her in, and all she has to do is resume tv.
spid is online now
post #6 of 23 Old 11-24-2013, 02:40 PM
DaverJ's Avatar
Quoted: 1030 Post(s)
Liked: 3464
My suggestion would be to use an HDMI splitter on the output of your cable box and have a "watch TV" Harmony activity that goes directly from cable box to your AVR or TV for her, and you can use the Xbox One activity for all the stuff you do.
Cuda1169 likes this.
DaverJ is online now
post #7 of 23 Old 11-24-2013, 05:35 PM - Thread Starter
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
Interesting. Although I did get my Harmony to turn on the Xbox One I find it strange that your 360 remote works as I now have my Harmony controlling both my 360 and One independently. The harmony database seems to have different codes for the 360 and One.
EVT is offline
post #8 of 23 Old 11-24-2013, 05:54 PM
sirjonsnow's Avatar
Quoted: 121 Post(s)
Liked: 139
I did do an update and add it as a separate device.
post #9 of 23 Old 11-28-2013, 05:52 AM
Murilo's Avatar
Quoted: 126 Post(s)
Liked: 30
So where is the IR receiver used to control it? Is it on the kinect itself now?
Murilo is offline
post #10 of 23 Old 11-28-2013, 02:25 PM
sirjonsnow's Avatar
Quoted: 121 Post(s)
Liked: 139
post #11 of 23 Old 11-29-2013, 12:13 AM
Murilo's Avatar
Quoted: 126 Post(s)
Liked: 30
So where is it?
According to the roomie remote team IR receiver is on the kinect, so where is it on the xbox one itself then?
Some of us dont use remotes, im going to use IR over IP, im using my ipad mini in a closed cabinet and will need to put the emitter somewhere from my itach.
Murilo is offline
post #12 of 23 Old 11-29-2013, 12:17 AM
Murilo's Avatar
Quoted: 126 Post(s)
Liked: 30
Here will help my own cause and for anyone else looking.
"Actually there is a sensor on the xbox one itself, its about a inch to the right of the eject button, took me forever to find it but that’s where I attached my sensor and it works great!"
Murilo is offline
post #13 of 23 Old 01-03-2014, 05:16 PM
dago52's Avatar
Quoted: 104 Post(s)
Liked: 63
Did you ever find the sensor? I also have the roomie but I gave up looking for the sensor. If so, would you mine taking a picture of your sensor location?
Denon X4200W
Chane's A5rx-c's Towers
Chane A2rx-c Center
Chane A1.4 Front Heights
EMP Bipoles Surrounds
Epson 2045 with 125" Elite Screen
dago52 is offline
post #14 of 23 Old 01-04-2014, 07:57 AM
Murilo's Avatar
Quoted: 126 Post(s)
Liked: 30
I found that on the roomie forum... The roomie forum team should offer help finding it I would think if you are still having issues.
I wouldnt be surprised if you cant physically see it, have you placed the sensor where the directions above indicate and see if it responds?
Murilo is offline
post #15 of 23 Old 01-04-2014, 08:53 PM
dago52's Avatar
Quoted: 104 Post(s)
Liked: 63
Yes, i tried placing the sensor everywhere on the front panel. You cannot see it with a flash light so I have tried where they recommended.
Can you post a picture?
Denon X4200W
Chane A2rx-c Center
dago52 is offline
post #16 of 23 Old 01-05-2014, 01:56 AM
Murilo's Avatar
Quoted: 126 Post(s)
Liked: 30
I dont own an xbox one yet, I do plan to purchase one when the stores locally get them in stock, have you asked on roomie for them to post a picture? Some people do have this working.
And your sure the codes or the emitter itself might simply not be working? Basically some other reason its not working other then you thinking your unable to find the sensor?
Murilo is offline
post #17 of 23 Old 01-05-2014, 08:35 PM
dago52's Avatar
Quoted: 104 Post(s)
Liked: 63
I have asked but my post didn't even show up on the forums. I may end up purchasing a blaster to see if that helps.
I would just like to see a pic if anyone can help.
Denon X4200W
Chane A2rx-c Center
dago52 is offline
post #18 of 23 Old 01-14-2014, 02:27 PM
SiegeX's Avatar
Quoted: 25 Post(s)
My Xbox One works fine with my Harmony 900 (a harmony one w/ RF). I put the IR blaster right under the eject button and set the XB1 back a bit.
I have two gripes about the XB1 + Harmony:
  1. The non-ability to have the XB1 start up in the TV app. I honestly shouldn't have to buy an HDMI switch to circumvent such an easy software change. I have a feeling that MS will get around to adding it at some point because it definitely fails the wife factor and hell have no wrath...
  2. Because the XB1 does not support the Comcast DVR features I cannot use the remote as simply as I would have liked. If you go into the DVR screens the up/down arrows don't work because those commands are for the XB1. My current solution is to leave the Harmony setup for talking to the Comcast box and then map the XB1 Up,down.left,right, OK buttons to the LCD screen. I've pretty much never use the XB1 Guide screen due to this problem.
SiegeX is offline
post #19 of 23 Old 06-28-2014, 01:37 PM
Zach978's Avatar
Liked: 0
I'm also having trouble getting my IR blaster to work, maybe someone has a picture of the IR sensor location?
Edit: after searching around, I found a comment on Amazon that said you have to put it over the eject button with the IR blaster I used. That ended up working for me, though it's kind of a pain because it's hard to press eject now.
Zach978 is offline
post #20 of 23 Old 09-16-2014, 01:08 PM
jeffbab's Avatar
There is a setting in the Xbox One menus somewhere that allows you to have it go directly to the TV app upon startup. I just set this up last night and it works great.
I have the harmony turn on the satellite receiver and the Xbox One and the Xbox One automatically launches TV when it is turned on.
edit: sorry didn't see how old this thread was.
jeffbab is offline
post #21 of 23 Old 09-16-2014, 01:13 PM
SiegeX's Avatar
Quoted: 25 Post(s)
Yea, this feature was not available at launch but from a bit of searching MS actually did listen to their users and implemented this feature in one of their last updates. Good to know!
SiegeX is offline
post #22 of 23 Old 05-21-2016, 10:09 AM
bodean's Avatar
Quoted: 170 Post(s)
Liked: 42
I have a Harmony Ultimate remote.
I have 2 activities on my remote, Watch TV, and Watch Apple TV.
Both activities work fine. However, if I turn on my xbox one / bose soundbar / tv by saying "Xbox On", and then grab my remote, and hit watch tv, everything turns off, or turns off then back on.
What I would like to happen is, be able to turn on my system using each method, however if Iturn on via VOICE, I would like to immideatly be able to control/change channels with my remote
Ideas or Suggestions?
How do other setup/use their Harmony remotes?
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
post #23 of 23 Old 06-01-2016, 01:37 PM
MALICIOUS ONE's Avatar
Quoted: 20 Post(s)
What I would like to happen is, be able to turn on my system using each method, however if I turn on via VOICE, I would like to immediately be able to control/change channels with my remote.
I found I had the same issue as you did. I just use my Harmony remote to start it up now & don't use my voice.
Samsung UN65JS8500/Samsung UBD-K8500/Onkyo TX-SR608 using 7.1/Xbox One S w/Kinect
XBL Gamertag: MALICIOUS ONE
My Twitter
My Rock Band/Guitar Hero DLC
MALICIOUS ONE is online now
Reply Xbox Area
Xbox One Console Standard Edition , Logitech Harmony One Advanced Universal Remote
