Using OTA signal with Xbox One - AVS Forum
post #1 of 129 Old 11-29-2013, 08:21 PM - Thread Starter
aztony's Avatar
I was wondering if there's a way to use the watch TV feature on the One when using an antenna. Maybe a converter of some type that goes from coaxial to HDMI. TIA
aztony is offline
post #2 of 129 Old 11-30-2013, 11:32 AM
Anthony1's Avatar
Quoted: 31 Post(s)
Liked: 144
I've been reading the Xbox Support Forums in the TV area to try to find an OTA tuner box that will work great with the Xbox One. Unfortunately, there doesn't seem to be a specific tuner box that works really good with the Xbox One yet.
A number of people are using the HW150PVR by HomeWorx. Apparently this device will work, although it seems to be a YMMV type thing with the Xbox understanding the voice commands to change channels. One guy was complaining that when he tries to tell the Xbox to change the channel to 5-1 ( a local digital channel for his area), the Xbox thinks it's 51 instead of 5-1, and the only way he can get to 5-1 is by using the remote control for the HW150PVR, which obviously kinda defeats the purpose.
You need to look at these forums, and see how actual users are getting by with various OTA boxes.
I'm going to continue to wait until I hear about a OTA tuner device that works pretty flawlessly, which while the HW150PVR seems to work, it doesn't work flawlessly, so I'm going to continue to wait.
aztony likes this.
Anthony1 is offline
post #3 of 129 Old 11-30-2013, 12:38 PM
ahartig's Avatar
Liked: 127
Agreed with Anthony 1. There are solutions, but most if not all are less than ideal, I looked into this quite a bit and even bought and returned an Iview cable decoder box.
Best thing to do is wait for msft to release an official ota solution..... Which could be never. frown.gif
XBOX Live ID: HONDEboyMAN
PSN ID: ahartig
ahartig is offline
post #4 of 129 Old 11-30-2013, 01:37 PM
Anthony1's Avatar
Quoted: 31 Post(s)
Liked: 144
Man, if only the XB1 had a built in tuner. It could have been the ultimate cord cutter device. I'm sure Microsoft considered putting a tuner in there, but I'm thinking they decided against it for fear of pissing off all the cable and satellite companies, and also possibly upsetting their relationship with ESPN and HBO Go and stuff like that. I honestly don't think it would have added very much to the cost of the XB1 to include a built in tuner. Probably only about $5 per unit, but MS didn't want to rock the boat so to speak in regards to all the big media companies that they need to have a relationship with.
I know Microsoft used to own about a 20 percent share of Comcast, not sure if they still do or not, so that could have also been part of it.
Still, I just wonder how seamlessly everything could have worked if they had a built in tuner. It would have been even more amazing if they gave you DVR functions for recording OTA programs. They could have truly been my "one input" on my TV.
Anthony1 is offline
post #5 of 129 Old 11-30-2013, 03:33 PM
AVS Club Gold
aaronwt's Avatar
Quoted: 272 Post(s)
Liked: 594
Since OTA only people is a small percentage of the overall use of TV I think it would be better to have a USB add on that can handle OTA or cable with a cable card. At least if they offer some kind of USB add on later then people can still get those capabilities with the XBOne without increasing the cost of the main box.
39TB unRAID1--53TB unRAID2--36TB unRAID3
LED DLP
XBL/PSN: WormholeXtreme
aaronwt is online now
post #6 of 129 Old 12-01-2013, 12:47 AM
onlysublime's Avatar
Liked: 493
Here's a guy's experience with the HW150PVR:
A: Nothing needed on the TV at all, it happens through the xbox, displayed on whatever input you've got the xbox plugged into.
The TV is none the wiser what you're up to.
Edit: I mean, yes, you still have to scan for channels... but that's all handled through the xbox/converter box interface.
Q: Does the Xbox integrate with this well? Does the OneGuide work and can it switch channels? I'm picking up one this week and I'm trying to get it to work with my OTA setup. Thanks
A: Full integration as far as I can tell. I can be playing Forza and say "Xbox, watch Fox". Bam.
Q: Awesome, so no issues whatsover?
A: Zero. Pretty amazing, really. I haven't tried the recording feature of the converter box, but everything else is gravy. You even get an on-screen guide for the channels and everything.
aztony likes this.
onlysublime is offline
post #7 of 129 Old 12-01-2013, 01:41 AM
bori's Avatar
Liked: 70
Anyone looking to buy this box. Go to newegg and enter code for 13.00 off. 32 dollars for box.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882576003
Sent from my SAMSUNG-SGH-I317 using Tapatalk
aztony and thompsonj805 like this.
bori is offline
post #8 of 129 Old 12-01-2013, 12:08 PM
Liked: 493
alright, went ahead and bought the homeworx box. at $35 after tax/shipping, it's worth a gamble.
post #9 of 129 Old 12-01-2013, 04:26 PM - Thread Starter
aztony's Avatar
Crap, I'm so tempted to buy it but deciding if I should wait to see how you make out with it. Sucks that the discount expires today. What to do, what to do? confused.gif
aztony is offline
post #10 of 129 Old 12-01-2013, 07:20 PM
Liked: 493
you can return it.
post #11 of 129 Old 12-02-2013, 04:55 PM - Thread Starter
aztony's Avatar
you can return it.
I decided to wait and see how you make out. I really didn't want to deal with returning it if it didn't work. Didn't know if NewEgg charges a restocking fee or not either. I'll have my fingers crossed that it works.
aztony is offline
post #12 of 129 Old 12-02-2013, 06:52 PM
Liked: 493
I will be the guinea pig! I'll see if I can make a vid of my experience.
post #13 of 129 Old 12-02-2013, 06:57 PM
bori's Avatar
Liked: 70
I bought it too. So hopefully it works.
Sent from my SGH-I317 using Tapatalk
bori is offline
post #14 of 129 Old 12-02-2013, 07:31 PM
Liked: 493
I read this in a thread. since I don't have it yet, I'll post the tip. otherwise, I should get it in a couple days.
"Try setting the manufacturer to Mediasonic, then manually put in your model number. I see some people have had success doing it that way."
hopefully no problems happen. don't want to have to spend significant amount of time digging through google or forums...
post #15 of 129 Old 12-02-2013, 08:14 PM
bori's Avatar
Liked: 70
Do you have a link to the media sonic thread?
bori is offline
post #16 of 129 Old 12-03-2013, 12:01 AM
Liked: 493
i don't remember the links.
here's what i just googled right now (not sure if linking to another forum is frowned upon):
also, the last post is a guy asking how to do subchannels like 3-1, 3-2, etc. I read in another forum (should've bookmarked but forgot to) that a workaround is to say "3" twice to get to 3-2. say it 3 times to get to 3-3. at least that's what I remember. we'll find out soon enough. wonder if you will get it before me.
http://forum.mediasonic.ca/viewtopic.php?f=44&t=2040
some relevant posts:
The HW-150PVR is compatible with the Xbox One. Enter remote code N4076 in TV settings > Troubleshooting > Remote code > Cable box.
I just managed to get the HW150PVR working with Xbox One, One Guide integration, and Kinect voice control. Selecting a channel by voice results in the channel numbers being entered via Kinect/IR. It takes about 5 seconds for the code to be entered (you can see each digit appear as Kinect enters it) and for the HW to then change the channel, but it works.
I visited Xbox One Settings -> TV & OneGuide -> Cable or Satellite Box Model.
I entered Mediasonic as the Cable or Satellite Box Brand.
I entered HW as the Cable or Satellite Box Model, and it searched and gave me HW150PVR as the only choice I could choose.
I just purchased the HW150PVR on Amazon - delivered today - and when I looked at the software (firmware) version it says it is running v14, which I believe is one of the latest (depending on which remote control you have). I'm not sure if the latest firmware is necessary.
Loving it! Browsing by channel names and other OneGuide shortcuts is pretty cool.
I did notice that if the HW is in Timeshift mode (i.e. you pressed pause to start timeshift recording to USB) it doesn't let you change the channel. You have to press Stop to get out of timeshift mode first. I also ensured that the HW was pushed forward in the cabinet for maximum IR coverage.
One key thing that is easily overlooked, make sure you put in the model number. I wasn't able to manually enter the remote code without it, I kept getting the incompatible code error.
Aero 1 and Boston Litigator like this.
post #17 of 129 Old 12-03-2013, 12:27 AM
bori's Avatar
Liked: 70
bori is offline
post #18 of 129 Old 12-03-2013, 12:27 AM
bori's Avatar
Liked: 70
bori is offline
post #19 of 129 Old 12-03-2013, 11:32 AM
Anthony1's Avatar
Quoted: 31 Post(s)
Liked: 144
Damn, I missed out on the deal, but will be looking forward to your impressions with how it works.
Like I posted earlier, one guy was saying that the HW150PVR works, but that when he tried to tell it to switch to channel 5-1, it kept trying to take him to channel 51.
One of my main questions is, can you just say "Fox", "CBS', "NBC", "ABC" "PBS", without having to use the channel numbers ?
If you can record a video of how it all works, that would be really awesome. Also, if you could do a test on Sunday, when a NFL game is on one of the local channels, does it do anything special with that, in regards to the whole NFL thing ?
Anthony1 is offline
post #20 of 129 Old 12-03-2013, 01:59 PM
ctiq21's Avatar
I am very curious about this a well. If someone gets one working or has
I am wondering the same thing. Any more information would be great.
ctiq21 is offline
post #21 of 129 Old 12-03-2013, 02:06 PM
Anthony1's Avatar
Quoted: 31 Post(s)
Liked: 144
The other thing to check is video quality. One nice thing about OTA, is that you can split the signal and loose zero picture quality. So you can run the antenna to the back of the TV, and use it's built in tuner, and you can also run it into the HW150PVR, and run that into the Xbox, and then try doing an A/B comparison between the two.
When I was at my buddies house, his cable box thru the XB1 looked pretty bad. It looked a lot better not going through the XB1. Not sure if that is a firmware issue with his cable box or what.
Ideally, you'd have two indentical TV's, and one of them you would use the built-in OTA tuner, and the other one you run through the HW150PVR and then into the Xbox hdmi in, and get a real, legit comparison to see if there is any video quality issues, but who owns two TV's of the exact same model # ?
Anthony1 is offline
post #22 of 129 Old 12-03-2013, 08:44 PM
Liked: 493
Here's the setup for the antenna for my house. It's located in the attic at the front of the house. The cable funnels down to the central box in the bedroom closet there. That box then runs cables to all the bedrooms. And my room is the master at the back of the house. And yes, my TV signal strength is worse in my bedroom than the rooms closer to the box.
I'm just going to do an eyeball test. I know what the TV picture is supposed to look like so if it passes the eyeball test, that's good enough for me.
post #23 of 129 Old 12-04-2013, 09:52 AM
RafaelSmith's Avatar
Liked: 83
Anyone gotten TiVo Roamio to work with XBOX Oneguide? Not really all that important since the UI for the Tivo is pretty nice from what ive seen.......light years ahead of my crappy cable box. But would be kinda cool to use XB1 voice commands.
I am thinking about dumping cable TV and have been looking at the base Tivo Roamio + OTA Antenna.
Excluding the upfront cost of the Tivo it would cut down my monthly "TV" bill by almost 2/3.
RafaelSmith is offline
post #24 of 129 Old 12-04-2013, 10:33 AM
AVS Club Gold
aaronwt's Avatar
Quoted: 272 Post(s)
Liked: 594
My Roamio works with the XBOne guide. My issue is that it uses remote code zero which controls every TiVo.
LED DLP
post #25 of 129 Old 12-04-2013, 12:30 PM
Liked: 83
Thanks. That is good to hear.
I need to get an antenna and see what kinda OTA signals I get on my system ...its been awhile since ive used OTA.
Sure would be nice to cut the cord......well except the broadband one =P
post #26 of 129 Old 12-04-2013, 01:30 PM
Dizman7's Avatar
Hmmm, tempted to get this. So I just run the antenna into the box, and then the box into the XB1 via HDMI, right?
I have a big Terk HD antenna a friend gave me about 5 or 6yrs ago, it's a powered one. Kinda off topic but I'm wonder if one this big is need nowdays, would a normal indoor one be fine? Like the little "card" looking one they show with that box, or other indoor ones I see at Best Buy and places? Found the pic of the one I have, it's over 4ft long, and screws into a little adapter that gets plugged into the wall, and another coax goes from the adapter to the TV. It doesn't work without the adapter. It's been fine for years though lately Fox HD has been SUPER touchy, like just moving it an inch can determine if I get Fox HD or not, it's really annoying and I have it laying across my living room to try and watch Family Guy or something. Where as anywhere it gets ABC, CBS, etc.
I just use this for "new" shows and watch everything else on Netflix and recently got Hulu. Been doing that for 5 or 6yrs now and works great and saves me a ton of money. I miss Comedy Central on cable, that's about it. The DVR option of the HW150PVR would be really nice, or does it only do "pausing" of live TV? If it does do DVR, can you record one channel while watching another? I'm assuming not but don't really know how that works with OTA.
Dizman7 is offline
post #27 of 129 Old 12-04-2013, 02:34 PM
Spec4's Avatar
FYI I'm pretty sure that Newegg waives the restocking fee on most items during the holidays. Check the specs tab at the bottom to be sure though.
Spec4 is offline
post #28 of 129 Old 12-04-2013, 07:28 PM - Thread Starter
aztony's Avatar
Thanks![/quote
There's only one way to know if the Terk will work and that's to hook it up and try it. There's too many variables to figure in to know if it will work without trying it. How far are the towers from where you live? Are there any tall buildings, trees, etc... All kind of stuff like that. I used to have my antenna in the living room but got tired of having to move it depending on what channel I wanted to watch. Moved the antenna up to the attic and it work's great. My antenna looks something like this: http://www.solidsignal.com/pview.asp?mc=03&p=4220-HD&d=Channel-Master-4220HD-2Bay-HDTVUHF-TV-Antenna-(4220HD)&c=TV%20Antennas&sku=
This website will help you with info on what type of antenna and signal strength for the channels available in your area: http://www.antennaweb.org/
aztony is offline
post #29 of 129 Old 12-05-2013, 03:26 AM
Nickff's Avatar
Quoted: 43 Post(s)
Liked: 81
Help me out. With this box and the One can you record television shows or only watch live via the One?
Mathematics is the reason for the season.
http://www.teacherspayteachers.com/Store/Ogive
Nickff is online now
post #30 of 129 Old 12-05-2013, 11:17 AM
Anthony1's Avatar
Quoted: 31 Post(s)
Liked: 144
The Xbox One itself doesn't record live TV. However, the HW150PVR does have some record abilties if you hook up an external drive to it, but I don't have the thing yet, so have no idea how that part of it works.
Anthony1 is offline
Reply Xbox Area
User Tag List
