Got my xbox one, a few questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-06-2013, 11:25 AM - Thread Starter
Quoted: 303 Post(s)
Liked: 43
Hey guys, just got this bad boy, great device from initial impression, a
Few questions though
How do I completely turn the xbox one off? I noticed that even though I pressed shut down the power brick still had the light on meaning the xbox one is In standby rather than off?
Is there a way to eject the disc without walking to the xbox one and physically pressing the eject button?
Also, when I'm done playing a game, I press the guide button and it takes me out to the xbox home, is this the time when I should go and eject the disc from the xbox one or is there a different more proper way?
Also, I have an Onkyo reciever with a 5.1 speaker setup, what is the best sound setting to choose from available options? 5.1 uncompressed or DTS?
And as for the video display settings, what Bit depth setting should I pick? Any other settings I should modify/change? I have the color range at RGB limited, I don't see a YcB setting which from what I know is better but oh well..
lamonsasa is offline
post #2 of 4 Old 12-09-2013, 06:58 PM
MarkcusD's Avatar
Quoted: 49 Post(s)
Liked: 45
Power off - you have to go to settings and put it in power save mode otherwise the power brick and its tiny little fan are always running.
Eject- should be on the menu when you press the menu button.
psn: markcusd
X1: MarkcusD
MarkcusD is offline
post #3 of 4 Old 12-09-2013, 07:06 PM
onlysublime's Avatar
Quoted: 768 Post(s)
Liked: 1203
you can also completely shut down the xbox by holding your finger over the power button in the front until the xbox turns completely off.
you can eject any time. there's no specific time to eject.
onlysublime is offline
post #4 of 4 Old 12-10-2013, 10:32 AM
Cuda1169's Avatar
Quoted: 24 Post(s)
Liked: 73
5.1 uncompressed should work with your set-up.
I use 24 bit.
Cuda1169 is offline
Reply Xbox Area
Xbox One Console Standard Edition
