Xbox one slow down after gaming? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-09-2013, 08:40 AM - Thread Starter
reyalP's Avatar
I noticed when i play primarily Forza 5 for an hour or so that the system after I go to the xbox home screen seems to be lagging when you scroll through the home screen. I checked to see if it was overheating but it doesn't feel all that hot. Last night it actually took me to the home screen while playing the game. The home screen and everything else worked but it wouldn't let me go back into the game. Once I turned off the Xbox and turned it back on it let me go back into the game.
Any one else having any issues like this? Other than this issue I love this machine.
reyalP is offline
post #2 of 9 Old 12-09-2013, 08:48 AM
UHD Addict
aaronwt's Avatar
Quoted: 5192 Post(s)
Liked: 3099
No lagging issues from the Home screen but I did get kicked back to the home screen last night when I was expecting a Multiplayer race to start. It had gone to the screen that shows where the track was located. But it stayed on that screen for too long, at least 30 seocnds. The next thing I knew I was kicked back to the home screen. And when I went back to Forza 5 I was at the screen where I had to press the A button to start it. So instead I started playing Ghosts single player.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #3 of 9 Old 12-09-2013, 11:57 AM - Thread Starter
reyalP's Avatar
I guess I should restate that it may not be lagging but more like slide show effect. It looks like the UI is running at a very low fps.
reyalP is offline
post #4 of 9 Old 12-09-2013, 12:05 PM
KLUNKDM's Avatar
I've noticed that a few times on my box also. Cannot remember if I was last playing Forza or not, but you can see it when scrolling between the screens at the home screen. I just did a complete power cycle and everything was fine. I look at it like a PC, you just need a good reboot every once and awhile. They need to add "Xbox reboot"
KLUNKDM is offline
post #5 of 9 Old 12-09-2013, 03:17 PM
UHD Addict
aaronwt's Avatar
Liked: 3099
But I don't need to reboot my PCs. I only reboot them when a program install says it needs it. Otherwise I only use standby and hibernation.
post #6 of 9 Old 12-09-2013, 03:24 PM
RampageSTi's Avatar
I've heard multiple theories, but a memory leak (that should be able to be corrected via a patch/update) sounds like what's causing it to me.
RampageSTi is offline
post #7 of 9 Old 12-09-2013, 07:22 PM
onlysublime's Avatar
Quoted: 768 Post(s)
Liked: 1203
After my incidence with not being able to load Dead Rising 3 one time, I now make it a habit to terminate apps or games after I'm done using it. Press the menu button on the controller and select quit on the app. Quit any and all apps. Remember, the One can theoretically run up to 4 apps simultaneously (though I don't know how to test this).
onlysublime is online now
post #8 of 9 Old 12-10-2013, 06:53 AM
UHD Addict
aaronwt's Avatar
Liked: 3099
Isn't the instant resume still in beta?
post #9 of 9 Old 12-10-2013, 09:30 AM
Cuda1169's Avatar
Quoted: 24 Post(s)
Liked: 73
I agree.
Also will "quit" out of an app or game if I am just watching TV for while.
Cuda1169 is offline
Reply Xbox Area
Xbox One Console Standard Edition
