Surround Sound (5.1) out of DirecTV rec using passthrough isn't real 5.1 sound...correct? - AVS Forum | Home Theater Discussions And Reviews
Old 01-07-2014, 02:15 PM - Thread Starter
siciliano611's Avatar
Quoted: 88 Post(s)
Liked: 36
So I have had the XB1 since launch and I love it but I have always noticed something and have not really seen it brought up much on this forum. I have a DirecTV genie and have it hooked through the XB1 HDMI passthrough to my Denon 1912 receiver. I have the Surround Sound BETA option enabled and 5.1 uncompressed enabled in the xbox settings but ever since day 1 I notice that the 5.1 sound is not legit 5.1 (I know Dolby is not supported yet, maybe this is why). In other words when watching TV through the Xbox all 5 channels work but it doesnt seem like the rear 2 speakers are distinct compared to the front 2. It seems like its almost the same and when I compare it to running the DirecTV straight to my receiver there is a notable difference in distinction of channels. I just wanted to make sure other people notice this too. It could be simply due to the fact that DD isn't yet supported (until they patch it)....thoughts?
siciliano611 is offline
Old 01-07-2014, 03:27 PM
UHD Addict
aaronwt's Avatar
Quoted: 5193 Post(s)
Liked: 3101
I do know the XBOne routes the rear channels incorrectly. So in a 7.1 system, it routes the surrounds to the back surrounds instead. It is still discrete, at least in my testing, just routed to the worng channels.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
Old 01-07-2014, 09:43 PM
erion racer's Avatar
Don't know if this would be the same thing you are referring to but when I play NBA 2K my center channel can barley be heard and the crowd sound in the rear surround speakers fluctuates up in down as if the sound is being interrupted. Could the none Dolby digital by causing my issue also? I notice on my Denon AVR 300 receiver it reads multi channel in for the sound signal for the xbox one.
erion racer is offline
Old 01-08-2014, 06:32 AM
JonCr's Avatar
I have my XB1 connection and settings set the same as you, with the differences being I have a HR24 Directv receiver and a Pioneer 1121 AVR. I have issues with the TV freezing - if I do a XB1 reset, it will do surrund sound fine all day, but when I turn it back on the next day, the TV app won't work. If I uncheck the surround sound (beta) checkbox, it will immediately work or if I re-set the XB1, it will work. I've been trying to figure out where my issue lies. I've been assuming it was an issue with the XB1 choking on the Directv signal, but you seem to have it working with Directv (though a genie instead of regular HR24). I've been playing with turning the items on in different order to see if that resolves it, but no luck. I wonder if the difference between your success and my failure is the genie vs HR-24? Anyone else with either the HR-24 or genie get TV to work consistently with the surround sound (beta) checked?
JonCr is offline
Old 01-08-2014, 08:50 AM
Doug Schiller's Avatar
I thought it was common knowledge that currently the Xbox One plays pass through audio via TV stereo only no matter what option you choose.
It has something to do with the Xbox adding its notifications sounds to the audio.
It basically is converting the DirecTV audio and mixing it with the system sounds and they haven't bothered converting it to 5.1.
I have a nice work around but your receiver needs to support it.
I have a Pioneer VSX-1021 and when I watch DirecTV, I switch my HDMI source from automatic to digital and viola, I get true 5.1 sound from DirecTV.
But I need to manually change it back when I play a game or I will still hear the TV.
Doug Schiller is offline
Old 01-08-2014, 09:06 AM
tsaville's Avatar
Quoted: 163 Post(s)
Liked: 299
I haven't done extensive testing to see if it is true discrete 5.1, but the Surround Sound Beta option definitely switches the output from 2 channel to 5 channel.
tsaville is offline
Old 01-08-2014, 09:46 AM
UHD Addict
aaronwt's Avatar
Liked: 3101
I get discrete 5.1 sound from my Roamio Basic connected to my first XBOne and I also get discrete 5.1 from my TiVo Mini connected to my second XBOne.
I can run netflx on both of those TiVos and run the A/V test video and I get the discrete audio from each channel while going through the XBOne.
Of course I am using the surround sound beta option on the XBOne. Without that option checked then it would just be stereo.
aaronwt is offline
Old 01-08-2014, 11:23 AM
Hmm, not sure.
I think Xbox One just lights up all channels.
My DirecTV shows 5.1 PCM but I know I am not getting that.
When I switch to direct source it sounds 100% better.
Old 01-13-2014, 09:58 AM
Cuda1169's Avatar
Quoted: 24 Post(s)
Liked: 73
I no longer run the surround sound beta option. Selecting that option seemed to make my fios feed stutter. W/O the option it works great in stereo. Any native XB1 app like games or Netflix does a good job with 5.1 surround. Until they work out the kinks with surround sound beta, I will leave that option off.
Cuda1169 is offline
Old 01-14-2014, 07:58 AM
JonCr's Avatar
I'm in the same boat - the surround sound beta freezes up my Directv. I mostly leave it unchecked and listen in stereo and only check it when I'll be watching all day and don't mind going through the reboot process to get it unfroze. I hope they fix it soon as it sounds better with the surround.
JonCr is offline
Old 01-14-2014, 10:00 AM
Symtex's Avatar
Quoted: 120 Post(s)
Liked: 90
on HD or SD channel ? I found that my STB freezes only on SD channel with Surround Sound enable. If I change my STB to Stereo, it all works. They need to fix all the incompatibility issue for sure.
Symtex is offline
Old 01-14-2014, 01:40 PM
JonCr's Avatar
It will work all day after you reboot it, but will freeze the next day when you start it up. Sometimes it will start ok the next day, but freeze the first time you switch from a SD/stereo channel to a HD/Dolby channel. If you switch back to a SD channel, it will often unfreeze.
JonCr is offline
Denon Avr 1912 Receiver , Xbox One Console Standard Edition
