A minor headset issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-30-2014, 03:58 PM - Thread Starter
GR1MM's Avatar
is there an easier way to take the headset that came with the xone off the controller after its connected? its a real pain to get off.
how do you check your controller battery status?
thanks
XBOX: xxx GR1MM xxx
PS3: GR1MM
GR1MM is offline
post #2 of 3 Old 02-03-2014, 01:23 AM
johnbe's Avatar
Liked: 44
thanks
There is no way to check your battery status. Even though I keep 2 controllers on the charger at all times, I hope this is fixed with an early update. I find that yanking on the cord as hard as I can takes care of removing the headset. Just kidding. tongue.gif I use my thumb on top and middle finger on the bottom where the groove is located and find it comes off pretty easy. Make sure you don't press down on the back where the small catch is located as that is what keeps it attached. Would have been easier if it has some type of ridge to grip. It could have been designed better, no doubt.
johnbe is offline
post #3 of 3 Old 02-03-2014, 03:41 AM
Nickff's Avatar
Quoted: 350 Post(s)
Liked: 221
I struggle everytime I pull the headset puck off. No way to not press the damn buttons. smile.gif
Sony XBR-65A1E | Denon X6300H | Klipsch RF-7ii (x2), RC-64ii, RB-51ii (x4) | SVS PB12-Plus | Xbox One S | WDTV Live | Sony BDP-S6200 | Harmony 670
Nickff is offline
Reply Xbox Area
