Xbox 360 freezes during start up... can't clear the cache - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-27-2014, 03:54 PM - Thread Starter
Anthony1's Avatar
Quoted: 604 Post(s)
Liked: 369
My son's Xbox 360 slim (core unit) all of a sudden started having a problem. Whenever we turn the machine on, it goes through it's normal swoosh routine, and then after that it gets to the screen where it's about to load the dashboard, and it just basically stays on that screen and you can't do anything.
I've been googling today trying to find out what to do, and a lot of the suggestions I get are to clear the cache. However, I can't get to the part where I can select system settings and clear cache, because it doesn't actually get to the point where the dashboard will load. It's before the dashboard has loaded.
Is there any way to clear the cache before the dashboard actually loads ?
Or any other suggestions ? ( it's out of warranty, and spending any $$$ to fix this is probably a bad idea. I'd probably just buy another 360 from Craigslist or something if it came down to it..)
Anthony1 is offline
post #2 of 9 Old 07-27-2014, 03:57 PM
Big Brad's Avatar
Quoted: 395 Post(s)
Liked: 528
Is there a hard drive in the unit? If there is, try taking it out and booting the system up to see if it'll get to the dashboard.
PSN ID/XBOX Live! Gamertag: BiffCo
Big Brad is online now
post #3 of 9 Old 07-27-2014, 04:18 PM - Thread Starter
Anthony1's Avatar
Quoted: 604 Post(s)
Liked: 369
No hard drive. It's one of those 4 gigs of built in storage core systems, or whatever. They did have a couple of USB sticks that they had plugged into it. I tried taking out all those sticks, and I tried it with the sticks inside it. Unfortunately, it just never makes it to the actual dashboard. It does the Xbox Logo splash intro thing, and it actually gets through that just fine, but then after that, it's like this greyish white screen, with a little white circle spinning around, which basically means "please wait", and that circle basically keeps spinning forever. It doesn't totally freeze, it just stays like that for a super long time. It's hanging at a certain point in the dashboard boot up.
I wish there was some way to "reset" the console without needing to get into the dashboard.
Anthony1 is offline
post #4 of 9 Old 07-27-2014, 04:39 PM
Big Brad's Avatar
Quoted: 395 Post(s)
Liked: 528
Have you tried disconnecting the ethernet cable (if you are going wired)?
post #5 of 9 Old 07-27-2014, 04:46 PM - Thread Starter
Anthony1's Avatar
Quoted: 604 Post(s)
Liked: 369
For the kids room, they just use wireless.
I just have to keep doing some google searches on it, might figure out something. Either that or I might try to see how much a repair place would charge to get it back up and running. I could probably buy a used slim like this for like $80 cash, but then I could end up with another one that could break at any given time.
Anthony1 is offline
post #6 of 9 Old 07-30-2014, 09:12 AM
signmastr's Avatar
Quoted: 12 Post(s)
Try 1-800-4MYXBOX. They have all the answers.
signmastr is offline
post #7 of 9 Old 08-06-2014, 08:45 AM
barrelbelly's Avatar
Quoted: 348 Post(s)
Liked: 434
It could be this:
http://gamerant.com/xbox-live-service-issues-360/
I have not experienced any problem with my Xbox 360. And I am currently playing Darksiders 2 pretty hard. Great game and awesome graphics on the Xbox 360. It was hinted in the article that Microsoft was intentionally gimping support for Xbox 360 to force trade up to their new console. I certainly hope they are not doing something that suicidal with their largest install base. Nor do I believe it.
barrelbelly is offline
post #8 of 9 Old 08-06-2014, 01:48 PM
mboojigga's Avatar
Quoted: 645 Post(s)
Liked: 881
Originally Posted by barrelbelly View Post
It could be this:
That would mean they would be targeting individual members which is highly unlikely. Had no sues with my 360s in the home either.
The 5.0 is here
mboojigga is offline
post #9 of 9 Old 08-06-2014, 02:17 PM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Could be an overheat, might need to remove the heat sinks and clean it up, apply new thermal compound and put it back together. They will not always toss a red ring due to overheat.
I have recovered several 360's by doing this but obviously it is not always the issue since there are so many variables.
I read about one that had a similar issue and the guy put a 16gb USB stick in the front and it fired all the way up (that one left me curious but he insisted it worked on his 360 when nothing else did)...?
Best of luck,
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is online now
Reply Xbox Area
